OLEDB
Niteesh_ReddyBo
When I am using OLEDB action I am getting error like 'Could not find installable ISAM' did anyone knows the solution for this kind of error. Thanks in advance.
Niteesh Reddy Bollu Senior Software Engineer
Lead Assistant Manager
exl service.com (India) Pvt. Ltd.
Gurgaon
9741235369
michaeloneil
Hi @Niteesh_ReddyBo
What is it you are trying to connect to, is it an excel file? If its excel/access then it could be a compatibility issue you can find more info on this error here "Could not find installable ISAM" error when you refresh a data table in Excel - Microsoft Support
Michael ONeil
Technical Lead developer
NTTData
#MVP
Hi...Thanks @Michael ONeil. I got it resolved. Earlier I mistyped my connection string as Provider.Microsoft.ACE.OLEDB.12.0;Data Source={{file_name}};Extended Properties="Excel 12.0 Xml;HDR=YES"; . Now I corrected it to Provider=Microsoft.ACE.OLEDB.12.0;Data Source={{file_name}};Extended Properties="Excel 12.0 Xml;HDR=YES";
Gurgaon
9741235369
Hi niteesh,
It looks like either the file path is invalid or the required driver is not installed.
Check below knowledge base article from blue prism.
https://support.blueprism.com/en/support/solutions/articles/7000078395-bpe-error-could-not-find-installable-isam-error-when-using-data-oledb-to-get-collection-from-an-exc
Harish Mogulluri
Lead developer
America/New_York TX
Harish Mogulluri
