Object reference not set to an instance
14-06-17 03:31 PM
Hi Everyone,
Need a help regarding my object reference error
- I have read a column from the excel and put in my collection
- now I have to loop through my collection and get each field (db. tables)and put in to my query and run in my toad
- In my collection I have current values with the column heading
- when in put in my query its not running (collection. Field ) this convention I have used in my query
- but I have not created field manually,.. so when I run my BP not able to read the heading name from my current values instead looking for field name
- So its throwing an error of object reference not set to an instance..
Please help is much appreciated
Leela
14-06-17 03:55 PM
Sounds like the Excel headings contain characters that are not compatible with a BP collection. If the only illegal character is a dot, then there is a function in the collection utility called something like 'Remove dots from Headings'. Otherwise suggest you 'clean' the Excel header row before reading into a collection (by replacing the illegal characters with something else) and close the Excel file without saving changes.
