15-02-23 05:14 AM
Hii
Iam new to oledb connections , I want to update data to a excel for a specific cell and sometimes multiple using cell refrence . and can it be done without getting excel into collection any idea's or suggestions on this please
Gowtham Bopaiah
15-02-23 09:03 AM
Hi Gowtham,
Microsoft Access DB engine is the bridge that allows you to connect to any source via OLEDB, without that connecting via a connection string to a data source is not possible.
Babjee Vangipurapu
Senior RPA Developer
Wonderbotz
India
India
15-02-23 06:37 AM
while iam trying to run open action after set connection Iam getting Internal : Could not execute code stage because exception thrown by code stage: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
Gowtham Bopaiah
15-02-23 08:50 AM
Hi Gowtham,
You need to install Microsoft Access DB engine both 32 and 64 bit versions for accessing excel as OLDEB. You can download that in the below link: https://www.microsoft.com/en-us/download/details.aspx?id=54920
Babjee Vangipurapu
Wonderbotz
India
India
15-02-23 08:57 AM
Hii babjee thanks for the reply .But iam using company lap so external download is prohibited , Is there any other option to solave this
Gowtham Bopaiah
15-02-23 09:03 AM
Hi Gowtham,
Babjee Vangipurapu
Wonderbotz
India
India
15-02-23 10:36 AM
Thanks for the suggestion Babjee
Gowtham Bopaiah
01-03-23 07:34 AM
You can try using "Set Cell Value" action related to MS Excel VBO.
Sonam Sharma
Manager, Blue Prism
SS&C
