PDF Reader VBO
I have attached PDF Reader VBO. If the attachment is not found. Save the below link and import . https://drive.google.com/file/d/0B1fTGvszUOCjQkNySjhOWnlyQkU/view
19 REPLIES 19
Siva_saiM_G
Thanks Vishal and i appreciate it. Keep up the good work.
Thanks Siva 🙂
RenukaR
Good Work Vishal.. Keep it up.
Thanks Renuka
AnilKurapati
thanks vishal
Manohar_SaiBurr
Hai Vishal, First of all thanks for creating but it didnt work well Vishal. I tried it but open PDF into word. even though it shows gibberish and also not getting body into the data item.And also it didnt close it well.Please Check it once and modify it and give me a link. Anyway Thanks Bro.
Hi Manohar, https://portal.blueprism.com/pdf-reader-vbo-user-guide refer this link and use as per instructions
