Pause Key - Global Send Key Events - Remote Desktop Connection
Hi, has anyone successfully executed sending the Pause key via Global Send Key Events (even better if sent to Remote Desktop Connection)? I am sending €œ{PAUSE}€ and receive Blue Prism error: Unsupported key. This is the same syntax I am using to send "{ENTER}" and "{TAB}" which are sending successfully. I would also like to know how to send the Break key as well.
Not a keystroke I have every needed to use before - wont ask what you are trying to do with RDC (shivers....).  If no body has an answer for you here it might be worth doing a wider internet search for pause+user32.dll
