Problem MS Excel VBO
08-03-18 12:57 AM
I have a problem with the use of MS Excel VBO, where I try to open an excel file, where I get this:
Internal: the code stage could not be executed because the exception was thrown by the code stage: Exception has been thrown by the target of an invocation.
Does anyone have a solution to this problem?
I am working with the 2013 version of Office and enterprise license.
regards, Nicolás
7 REPLIES 7
12-03-18 12:52 PM
Hi Nicolas,
No idea what the issue is.
But a possible work-around:
If you open the excel file via Utility - Environment with as action Start Process , does it then open, and can you attach to it via the Excel VBO?
See this thread for a details explaination:https://portal.blueprism.com/forums/nhs-discussion-forums/general-discu…
29-03-18 03:16 PM
I have the same issue. Anybody can help?
03-04-18 07:35 PM
Same issue here, please assist. Thanks!
09-04-18 02:15 PM
Anybody came up with a solution yet? Thanks!
20-04-18 02:32 PM
Had the same Issue... There are two different Versions of MS Excel VBO, i don't know which one but one worked for me and the other one didn't with the same error you have.
20-04-18 06:22 PM
Same problem here solved by using an old version of Excel VBO object - 5.0.22. Works without any problem.
Best regards.
02-08-18 02:08 PM
Thank you bastiaan.bezemer2
I had the same problem so I replaced the ""MS Excel VBO: Open Workbook"" action with ""Utility - Environment: Start Process"" action and now process works fine.
