Process Stuck in Warning state
DhanishKothare
Hi Team,
When running through scheduler, sometimes process gets stuck in warning stage. I have pin pointed the place where is gets stuck. I am sending Global send key as  "{Home}{Del 50}"&[dataitem]&"{Enter}" for inserting text in a text box.
Am I doing anything wrong or any changes needs to done for this and how to recover from this error?
Thanks & Regards,
Dhanish Kothare
GopalBhaire
Level 10
You can change the warning threshold on left handside below Stage Logging.
I would suggest you separate out the 3 events[del, write, enter] & try "^a" instead of {del 50}
Gopal Bhaire
Analyst
Accenture
You can redefine the timeout value of warning in the following two ways:
  • By Stage(Navigate/Read/Write):
  • By System Manager:
In both ways, you can disable the function by setting value zero.
Hope this helps.
Tetsuji Junicho
Manager of RPA Practice Grp.
Accenture Japan
Asia/Tokyo
