Issue in Code Stage using DataTable as Variable
MohiniShelke
Hi Team,
I am using c# linq query of group in Code Stage,
But, I am getting following error.
Description: Compiler error at line 1: 'System.Data.DataTable' does not contain a definition for 'AsEnumerable' and no extension method 'AsEnumerable' accepting a first argument of type 'System.Data.DataTable' could be found (are you missing a using directive or an assembly reference?)
Repairable: No
Please let me know the solution for this?
Thanks in advance
Mohini Shelke
vElement It
6 REPLIES 6
You're missing a namespace. I think that specific error is if you're missing the generic collections namespace. Can't remember.
Try making sure you have these at least:
External References:
  • System.dll
  • System.Data.dll
  • System.Xml.dll
  • System.Drawing.dll
  • System.Core.dll
  • System.Data.DataSetExtensions.dll
Namespace Imports:
  • System
  • System.Drawing
  • System.Data
  • System.Collections.Generic
  • System.Linq
Edit: One or two of those may be unnecessary depending on what you're doing with it, but it won't hurt to add them all.
Dave Morris
3Ci @ Southern Company
Atlanta, GA
Thank David Morris
It works fine but another error occurs  as follws:
Description: Compiler error at line 0: The out parameter 'ColumnValues' must be assigned to before control leaves the current method
Repairable: No
My Code :
var grouped = from table in InputCollection.AsEnumerable()var grouped = from table in InputCollection.AsEnumerable()group table by new {  placeCol = table["Place"]
} into groupby select new{Value = groupby.Key,ColumnValues = groupby,};
Mohini Shelke
vElement It
Set a default value for variable ColumnValues
Gopal Bhaire
Analyst
Accenture
Hi can you tell me how to define default value to variable ColumnValues ?
I tried ,but not working.
I have already shared the code
Thanks in advance.
Thanks & Regards,
Mohini Shelke
RPA Developer, vElement IT,
Cell : (+91)9503221751
https://velement.io/
------Original Message------
Gopal Bhaire
Analyst
Accenture
What is datatype of ColumnValues?
if it's collection set this at beginning ColumnValues=new System.Data.DataTable();
if it's text set this at beginning ColumnValues=String.Empty;
Gopal Bhaire
Analyst
Accenture
Thanks!
Working fine
Thanks & Regards,
Mohini Shelke
Gopal Bhaire
Analyst
Accenture
