Process level access v6
AjayGhodke2
Blue Prism added new feature in it's v6. In this it says we can add process level access to particular user only. How to do this ?
Multi-Team Environments was implemented in 6.3. I saw in your other post that you're on 6.2, so you'd need to upgrade to at least the next minor version of BP to use it.
Also, I would suggest coordinating your efforts with someone from Blue Prism or a consultant because I would not consider implementing MTE a simple matter. I'm not saying it's the hardest thing ever, but it's going to take some planning to ensure that various teams have access to the right common objects/processes as well as having the level of permissions needed and stuff like that.
Dave Morris
3Ci @ Southern Company
Atlanta, GA
8 REPLIES 8
Hello, I think what you are talking about the Roadmap of features that will be in v6 rather than what is already in it?  Group Permissions is what you are talking about and it is still in development, reference the release notes to see what is in v6 so far.
Can you be more specific about which version of BP and which update you mean?
AjayGhodke2
I'm talking about Blue Prism version 6. I heard that in this update we can restrict developer to view and edit only his process not others. Here i'm not talking about developer group because in group we can give access to all developers.I want to restrict each developer from accessing others processes. i.e. developed by other developers.
Are you talking about potential future functionality, rather than something currently in 6.0, 6.1 or 6.2? Check the Release Notes section of the Portal but I'm sure the feature you describe is not yet available.
AjayGhodke2
If this functionality is not available in current version of BP then can we do this through some mechanism may be script or from database. Can we restrict developers from accessing other processes. Or by any other way.
Currently there is no way to add that restriction, but there will be in the future.
Hey, how about now? Maybe it is already implemented? Which version?
Dave Morris
Atlanta, GA
