Read images
01-12-17 12:40 PM
Which of the following Element types is it Possible to read an image from?
1. Win32
2. Active Accessbility
3. HTML
4. Java
A) 1 Only
B) 2 Only
C) All the above
D) None Of the Above
01-12-17 03:19 PM
C
04-12-17 05:47 PM
Are You Sure john seriously we can using all modes we can read images or this is an guessing answer
04-12-17 07:27 PM
I wouldn't guess. Reading an image of an element isn't a single step procedure - you need find the bounds (coords and dimensions)of the element and then use that data to dynamically position a region, then read the screen image.
05-12-17 01:04 PM
Thank You so much john for your answer it is helpful in my giving exam so we can read an image with all the modes which mentioned above.
