Regarding issue in production of one application
sumitsharma1
To make an account Active from Disable using drop down due to behaviour of the application sometimes its work and sometimes not .I tried through the both the mode AA mode and HTML mode but from the process it working fine but whenever i start the scheduler its showing error .
Something working when ran from the process but failing when ran from control room/schedular - suggest that you have not implemented best practice wait stage logic in your solution or your environment that you are running the task in is not persistent in some way.  I recommend contacting your trainer/mentor to have your solution peer reviewed by someone with experience.  If you are a new user and you do not have a mentor I recommend you raise that with your manager as a project risk - the accreditation training path that all Partner organisations agree with Blue Prism includes mentoring - so it should be in place for you.
