20-08-19 12:22 PM
I'm having some issues where I try to read a list region with OCR. The list are a bunch of dates seperated by dots (DD.MM.YYYY)
Reading out the dates are no problem, the issues is that Blue Prism fail to read it correctly where 2 end up being read as 7 and 3 being read as 8 and so on.
I have tried setting the font automatically with no luck. I also did try to create my own font, but this did not bring me any closer to success either, sadly.
So far I have had some progress with whitelistening 0-9 and the period sign (.) and setting the scale to different values where I get the correct reading with X scale, but for Y dates it doesn't work properly again.
Any tips would be greatly appreciated!
Robin Jensen
IKT-RÃ¥dgiver / RPA Developer
Tromsø Kommune
Europe/Oslo
20-08-19 05:52 PM
Gopal Bhaire
Analyst
Accenture
20-08-19 05:52 PM
Gopal Bhaire
Analyst
Accenture
21-08-19 07:23 AM
Hello Gopal,
Thank you very much for your suggestion!
As of now this looks to be the perfect solution for my problem - Why I do not know, as I'm not even specifying a font. I'll have to let it run for some time and make sure it works consistently, but for now this looks very promising.
Again, thank you so much. 🙂
EDIT:
After some more testing I have found that I need to specify the font for some fields that I try to read, but others does not require it. Either way - Using Recognise text did the job for me!
Robin Jensen
Tromsø Kommune
Europe/Oslo
