Remote Process Execution
SheldonNossel
Hi  I'm trying to run a process programatically using an ASP.NET (C#) web app, is there any way to do this and if so is there anyone who has attempted or built anything similar?
You can start a Blue Prism Process programmatically through CLI commands or by exposing the process as a web service and calling it that way. Some references you'll want: Command Line Interface Go into Blue Prism and press F1 and then search for 'command line' For a more complete list of commands but with less explanation, use the CLI command: automatec /help Web Services https://portal.blueprism.com/documents/standard?title=web+services&cate… Example of a CLI command to run a process: automatec /run ""Process Name"" /sso automatec /run ""Process Name"" /resource /sso automatec /dbconname ""Name of the BP Connection"" /run ""Process Name"" /user The F1 Help in Blue Prism is good for these commands, but I always like to caution that it is missing a few commands and those extra ones are listed in the CLI /help command.
