Resource Pool not appearing in Active Queues
18-05-18 04:17 PM
Hi Team,
I have created one resource pool in system tab of BP. I want to make one Work Queue as Active Queue and need to assign the resource pool for this Queue. I am unable to select the pool which i had created earlier because it is not appearing the list. Please, help me on this issue.
Should i need to enable anything to make that pool available to select in Active Queues.
Thanks & Regards,
Manasa Tanguturu.
18-05-18 07:40 PM
Active Queues is intended to work with resource Groups, which are not the same as Pools. And yes, it is confusing!
21-05-18 10:50 AM
Hi John_Carter,
I had created a resource group in the pools tab of system tab. But the problem, is it is not getting available to select as a resource group while making a work queue as active queue.
Manasa
21-05-18 03:01 PM
Remember Pools and Groups are not the same, but I also think there is a small bug in the BP UI.
1.Go to System > Resources > Management and create a Group.
2. Navigate away from System, to Home.
3. Go to System > Workflow > Work Queues and set up the Active Queue.
Step 2 is the bug - you need to move away from System to force your changes to appear.
