Retrieve or load from AWS S3 Buckets?
JohnNicholson
Just wondering if anyone has any experience with retrieving or loading from S3 buckets into BP? Is it possible in v5?
A quick google suggests that there is a REST API available for AWS S3, could you create your own code stage VBO to use that? A google search also suggests that there are tools out there (some paid for?) that allow you to map AWS as a local network drive, which presumably would mean you could use the File Management VBO.
