Routing Documents to Decipher IDP Exception Queue
Hi All,
Is there a method for directing specific document types to the Decipher IDP exception queue?
For instance, if I have a Batch Type designated for processing invoices, can documents like purchase orders (POs), timesheets, or bank statements be automatically flagged as exceptions in Decipher when they are pushed pointing to the same Batch Type as invoices?
Athiban Mahamathi - https://www.linkedin.com/in/athiban-mahamathi-544a008b/
Technical Consultant,
SimplifyNext,
Singapore
Best Answers
BenLyons
Hi Athiban,
Due to the potential complexity of exception types in Decipher, these all need to be marked manually and then have a defined human-in-the-loop process for how to proceed. E.g. Wrong document type might need the user to delete the document from the batch and submit it using a different process to the correct document type. But a missing value could be manually added and then be pushed back to Blue Prism.
Ben Lyons
SS&C Blue Prism
UK based
BenLyons
Hi Athiban,
Ben Lyons
SS&C Blue Prism
UK based
Thanks for your input Ben.
SimplifyNext,
Singapore
