Run exe using Blueprism
KrishnapriyaMM
Hi all,
Can someone please guide me how to run an exe file using blue prism VBO. Tried using utility environment;start process, when i passed the command in arguments its exiting the stage and the script is not running. Please help.
Thanks in advance
Krishnapriya MM
harish.m
Level 12
HI Krishnapriya,
In general start process will work. can you provide more details  what exe file you are trying to launch? And what is the expected result?
Did you get chance to try with out passing arguments?
Harish M
Lead developer
America/New_York TX
StephanieStrydo
We are experiencing an issue with VBO - Utility Environment, Action: 'Start Process' on version 7.2. On our old version we could send values for 'Application' such as: "msedge" or "msedge.exe" or "notepad" or "chrome" and it would launch those apps. We found that on 7.2 sending a complete file name: "C:\Users\BOT\Desktop\New Text Document.txt" or a URL "https://www.google.com", successfully opens a file or default browser, but we can't send ".exe" or process names any more. However, the action: 'Start Process Read Stderr and Stdout', can still start processes by sending "notepad". We are still trying to get to the bottom of the issue. In general it seems to work if you send complete file names (not file paths to exe's).
Stephanie Strydom
Hi Stephanie Strydom,
I tried to replicate the same on 7.2 and it is launching apps just by passing the name same as ealier. I tried "notepad", "chrome" and "msedge" and all 3 worked for me without passing the full path.
LinkedIn - https://www.linkedin.com/in/tejaskumardarji/
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
Hi Stephanie,
Blue Prism 7.2 Utility environment VBO Issue | Blue Prism Product here you may find your solution. Please have a look at the same.
Amlan Sahoo
Senior RPA Consultant
WonderBotz
Amlan Sahoo
