SOAP Webservice Import Issue BPV6
bharratmohan
​Hi,
We were successfully importing a webservice in Blue Prism V5.  After upgrading to Blue Prism V6 , we are facing the below error while trying to import a WSDL ...
"Could not understand the web service described at ....
Object reference not set to an instance of an object"​
Bharrat K Mohan
Check this: http://portal.blueprism.com/customer-support/support-center#/path/1141638272
Otherwise, if you don't find anyone answering your question on the community, it may be that no one has a guess/solution for you. You may want to reach out to support@blueprism.com.
Dave Morris
3Ci @ Southern Company
Atlanta, GA
