Save file in MS Word
Hi Team,
Good day to everyone.
I have a requirement where I need to make changes in word which opened using a hyperlink. But after making changes I have to save file which then gets uploaded automatically editing version. But in word vbos , there is no save action. And I cannot use save as instead of save. Can you please suggest me alternative methods to achieve my requirement.
Hi @HarithaChekuri97 ,
If you directly use the Close action the MS Word VBO, it should save the document by default as the underlying code has the Document.Saved property marked as True. Let me know if that does not work for you:
