Spying issues for Quick3270 Emulator Mainframe application
28-09-19 08:38 AM
Hello All,
We are facing issues with Spying the elements on a mainframe application, which is hosted on Quick3270 emulator. Below are the issues -
1. The elements are not aligned to the grid
2. after spying, the co-ordinates are getting dynamically changed once the session is over.
3. The elements once spied, are highlighted correctly in the application modeler, but when we try to perform operations on the spied elements the write operation is performed at different X n Y co-ordinates.
Can anyone suggest solutions to the above queries?
Thanks in advance.
Piyush Dani
Sr. Consultant
Capgemini
Thanks in advance.
Piyush Dani
Sr. Consultant
Capgemini
01-10-19 04:24 PM
Hello DANI,
I suggest to try using tabulation (working with keyboard),
if that's not possible, try to maximize the window before setting the coordinates X and Y ( in this way, I think it will be fix).
I hope that it helped,
Yassine Lamarti
Blue prism designer
Accenture
Africa/Casablanca
Yassine Lamarti
Blue prism designer
Accenture
Africa/Casablanca
02-10-19 08:01 AM
Is your Windows scaling setting higher than 100%?
On your workplace used for development and where you execute the process?
Walter Koller
Solution Manager
Europe/Vienna
Walter Koller
Solution Manager
Europe/Vienna
