Mainframe Automation : Can we spy an element in mainframe application which changes location using blue prism
abhisachdev
abhi sachdev
Babjee24
Level 7
Hi Abhi,
If the field changes it's position the way of handling it is, for any value that you read there's a field name associated with it. You can get the field name co-ordinates post which you can play with co-ordinates as per your requirement
Babjee Vangipurapu
Senior RPA Developer
Wonderbotz
India
Babjee Vangipurapu
India
Dear Abhi,
we can spy elements  in mainframe application . First you need to create a session in mainframe and then save it same in desktop or whatever folder you want it.
later create a object and there call a mainframe session path and then select the required mainframe emulator.
After the above step lunch the mainframe via application modeler and then mainframe spying mode will be enabled and then whatever fields you want it you can spy the same.
Best Regards,
Devendran Venkatesh
RPA - Technical Architect |
Riyadh 11413, Kingdom of Saudi Arabia
Phone. +966-556784162
Best Regards, Devendran Venkatesh RPA - Technical Architect | Riyadh 11413, Kingdom of Saudi Arabia
Babjee24
Level 7
Hi Abhi,
Babjee Vangipurapu
Wonderbotz
India
Babjee Vangipurapu
India
Sorry, misunderstood your question, can you please share the screen shot your mainframe application and the field?
Best Regards,
Devendran Venkatesh
Thank you !
abhi sachdev
