Stop process while waiting in debugging mode
franlem2
Hi guys, Let's say we have a process that is waiting for 300 seconds to be over but we are in debug mode with changes not saved yet. Is there a way to stop a process while a sleep is executing in debugging mode without killing it ? I still know we can then use the recovery mode to retrieve the work that was not saved. Is there a less radical way to stop it?
Best Answers
Hi Francois,
Waiting can cause issues in Blue Prism depending on your setup, where possible the easiest way to "Set Next Stage" at another stage to skip a wait in action.
It's not fully reliable though sadly.
Best regards,
James
James McLintock
Process Analyst and Developer
Hi Francois,
Best regards,
James
James McLintock
