24-05-19 04:34 PM
Hi guys,
Let's say we have a process that is waiting for 300 seconds to be over but we are in debug mode with changes not saved yet.
Is there a way to stop a process while a sleep is executing in debugging mode without killing it ? I still know we can then use the recovery mode to retrieve the work that was not saved. Is there a less radical way to stop it?
Â
03-08-20 03:26 PM
Hi Francois,
Waiting can cause issues in Blue Prism depending on your setup, where possible the easiest way to "Set Next Stage" at another stage to skip a wait in action.
It's not fully reliable though sadly.
Best regards,
James
James McLintock
Process Analyst and Developer
Best regards,
James
James McLintock
03-08-20 03:26 PM
Hi Francois,
Best regards,
James
James McLintock
Best regards,
James
James McLintock
