Surface Automation Code issue
02-05-18 04:11 PM
The code is running fine in DEV and UAT environment, But the same code getting error in production. We implemented Surface Automation for Citrix applications
1) Using same screen resolution (1024x768) in all three environments
2) Using same application in all three environment
Please let me know what need to be follow while developing the code for citrix based Application
ISSUE: System Exception: Cannot find screen
09-05-18 04:07 AM
Make sure to check if the Prod Citrix Apps are the same from DEV and UAT environment. You may double check on the window title.
