Surface Automation Query
28-01-20 12:01 AM
Hi All,
Just wanted to ask about a current challenge we're facing in dev.
Bit of background
- Automating a web browser that does not work on IE (Only chrome and firefox)
- Opted to use chrome as firefox plugin was not working nicely with the application.
- Using Version 6.4 (No immediate way to upgrade to the latest versions)
- Basically using surface automation techniques.
Now that the above info has been shared, we've been able to spy and integrate some elements already and so far so good. However we do have encountered a section wherein we need to click on a searchbar for a dropdown to pop up. Challenge is, after the dropdown is available and visible, you cant' send any global keys (Tab, down button etc).so the only option is take a snapshot of it and try read the values.
I've tried using list regions (recongnize with ocr, recognize text etc) and everything i know at least to get to read the values on the table and select it.
Not sure if anyone has any other tricks up their sleeve or has encountered the same
Would be great to hear from the community on how to deal with this
Thanks all
Brian
Brian Gacad
Senior IT Domain Specialist
Australia/Melbourne
