System.ServiceModel.Channels.ReliableRequestSessionChannel, cannot be used for communication because it is in the Faulted state.
11-12-23 03:27 PM
We have noticed VDIs connected to control room disconnecting intermittently from the control room . Some occurrences VDis are coming back to connected state and mostly disconnected from the environment on a permanent basis . While analysing the VDI the resource PC with stopped state . This happening intermittently in our environment. With different VDIs . Please advise.
Sample log
[2023-09-12 14:15:12Z] Initialising (events logged in Coordinated Universal Time)
[2023-09-12 14:15:12Z] ..checking connection 'Staging_V6_SSL'
[2023-09-12 14:15:12Z] ..connected to 'VNW00006869'
[2023-09-12 14:15:12Z] ..initialising AMI
[2023-09-12 14:15:12Z] ..getting business objects
[2023-09-12 14:15:12Z] Startup sequence complete
[2023-09-12 14:15:13Z] Listener started.
[2023-09-12 14:15:33Z] New connection from 10.42.152.31
[2023-09-12 14:15:39Z] New connection from 10.43.152.26
[2023-09-12 14:16:06Z] New connection from 10.42.152.32
[2023-09-12 14:16:07Z] New connection from 10.43.152.28
[2023-09-12 14:16:16Z] New connection from 10.39.17.139
[2023-09-12 14:16:16Z] New connection from 10.43.152.26
[2023-09-12 14:29:20Z] Disconnected 10.39.17.139
[2023-09-12 14:40:43Z] Listener failed : failed to update resourcepc details on the database - System.ServiceModel.CommunicationObjectFaultedException: The communication object,
Server stack trace:
at System.ServiceModel.Channels.ReliableRequestSessionChannel.SyncRequest.WaitForReply(TimeSpan timeout)
at System.ServiceModel.Channels.RequestChannel.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Dispatcher.RequestChannelBinder.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at BluePrism.AutomateAppCore.IServer.RefreshResourcePC(String name, ResourceDBStatus status, Int32 runningSessions, Int32 activeSessions)
at BluePrism.AutomateAppCore.clsListener.RefreshDBWithCurrentState()
[2023-09-12 14:40:43Z] Will retry in 2 minutes
[2023-09-12 14:41:12Z] Server connection restored
[2023-09-12 14:41:12Z] ..connected to 'VNW00006869'
[2023-09-12 14:41:13Z] Listener restarted
[2023-09-12 14:41:13Z] Listener started.
[2023-09-12 14:41:56Z] New connection from 10.43.152.26
[2023-09-12 14:41:57Z] New connection from 10.43.152.26
[2023-09-12 14:41:57Z] New connection from 10.42.152.32
[2023-09-12 14:41:58Z] New connection from 10.43.152.28
[2023-09-12 14:41:59Z] New connection from 10.42.152.31
[2023-09-12 15:22:46Z] Disconnected 10.42.152.31
[2023-09-12 15:23:52Z] New connection from 10.42.152.31
[2023-09-12 16:12:11Z] Disconnected 10.43.152.28
[2023-09-12 16:13:17Z] New connection from 10.43.152.28
[2023-09-12 16:50:16Z] Server connection restored
[2023-09-12 16:50:16Z] ..connected to 'VNW00006869'
[2023-09-12 17:17:17Z] Server connection restored
[2023-09-12 17:17:17Z] ..connected to 'VNW00006869'
[2023-09-12 18:26:24Z] Disconnected 10.43.152.28
[2023-09-12 18:27:30Z] New connection from 10.43.152.28
[2023-09-12 19:47:50Z] Disconnected 10.43.152.26
[2023-09-12 19:48:56Z] New connection from 10.43.152.26
[2023-09-12 21:21:17Z] Listener failed : failed to update resourcepc details on the database - System.ServiceModel.CommunicationException: The underlying secure session has faulted before the
reliable session fully completed. The reliable session was faulted.
Server stack trace:
[2023-09-12 21:21:17Z] Will retry in 2 minutes
[2023-09-12 21:22:17Z] Server connection restored
[2023-09-12 21:22:17Z] ..connected to 'VNW00006869'
[2023-09-12 21:23:15Z] Listener restarted
[2023-09-12 21:23:15Z] Listener started.
[2023-09-12 21:23:19Z] New connection from 10.42.152.31
[2023-09-12 21:23:20Z] New connection from 10.43.152.26
[2023-09-12 21:23:20Z] New connection from 10.42.152.32
[2023-09-12 21:23:23Z] New connection from 10.43.152.26
[2023-09-12 21:23:26Z] New connection from 10.43.152.28
[2023-09-12 21:47:21Z] Server connection restored
[2023-09-12 21:47:21Z] ..connected to 'VNW00006869'
[2023-09-12 22:17:31Z] Disconnected 10.42.152.31
[2023-09-12 22:18:37Z] New connection from 10.42.152.31
[2023-09-12 22:27:17Z] Listener failed : failed to update resourcepc details on the database - System.ServiceModel.CommunicationException: The underlying secure session has faulted before the
Server stack trace:
[2023-09-12 22:27:17Z] Will retry in 2 minutes
[2023-09-12 22:28:18Z] Server connection restored
[2023-09-12 22:28:18Z] ..connected to 'VNW00006869'
[2023-09-12 22:29:15Z] Listener restarted
[2023-09-12 22:29:15Z] Listener started.
[2023-09-12 22:29:17Z] New connection from 10.42.152.31
[2023-09-12 22:29:20Z] New connection from 10.43.152.26
[2023-09-12 22:29:21Z] New connection from 10.42.152.32
[2023-09-12 22:29:21Z] New connection from 10.43.152.26
[2023-09-12 22:29:21Z] New connection from 10.43.152.28
[2023-09-12 22:54:37Z] Disconnected 10.43.152.26 - quit
[2023-09-12 23:54:51Z] New connection from 10.39.17.138
[2023-09-13 00:19:19Z] Listener failed : Exception - The communication object, System.ServiceModel.Channels.ReliableRequestSessionChannel, cannot be used for communication because it is in the
Faulted state.
[2023-09-13 00:19:19Z] Will retry in 2 minutes
[2023-09-13 00:20:19Z] Server connection restored
[2023-09-13 00:20:19Z] ..connected to 'VNW00006872'
[2023-09-13 00:21:16Z] Listener restarted
[2023-09-13 00:21:16Z] Listener started.
[2023-09-13 00:21:17Z] Disconnected 10.39.17.138
[2023-09-13 00:21:20Z] New connection from 10.42.152.32
[2023-09-13 00:21:20Z] New connection from 10.43.152.26
[2023-09-13 00:21:21Z] New connection from 10.43.152.28
[2023-09-13 00:21:21Z] New connection from 10.42.152.31
[2023-09-13 00:21:21Z] Disconnected 10.42.152.31 - quit
[2023-09-13 00:21:26Z] Server connection restored
[2023-09-13 00:21:26Z] ..connected to 'VNW00006872'
[2023-09-13 00:21:41Z] Disconnected 10.42.152.31
[2023-09-13 00:22:12Z] New connection from 10.42.152.31
[2023-09-13 00:23:07Z] Disconnected 10.43.152.28
[2023-09-13 00:24:12Z] Server connection restored
[2023-09-13 00:24:12Z] ..connected to 'VNW00006869'
[2023-09-13 00:28:06Z] Disconnected 10.42.152.32
[2023-09-13 00:33:07Z] Disconnected 10.43.152.26
[2023-09-13 00:43:45Z] New connection from 10.39.17.138
[2023-09-13 01:24:23Z] Disconnected 10.39.17.138
[2023-09-13 01:37:04Z] New connection from 10.39.17.138
[2023-09-13 01:42:11Z] Server connection restored
[2023-09-13 01:42:11Z] ..connected to 'VNW00006869'
[2023-09-13 01:43:17Z] Created session: 475d7a3c-c078-4cb2-be8a-8d9005845556; process: NFT Testing Process; Run Mode: Background
[2023-09-13 01:43:22Z] Session (ID: 475d7a3c-c078-4cb2-be8a-8d9005845556) failed to start. Process Name: ; Reason: System.ServiceModel.CommunicationException: The underlying secure session has
faulted before the reliable session fully completed. The reliable session was faulted.
Server stack trace:
at BluePrism.AutomateAppCore.IServer.SetPendingSessionRunning(Guid gsessionid, DateTimeOffset startDateTime)
at BluePrism.AutomateAppCore.RunnerRecord.RunnerMethod()
[2019-09-13 01:43:26Z] Listener failed : failed to update resourcepc details on the database - System.ServiceModel.CommunicationObjectFaultedException: The communication object,
System.ServiceModel.Channels.ServiceChannel, cannot be used for communication because it is in the Faulted state.
Server stack trace:
at System.ServiceModel.Channels.CommunicationObject.ThrowIfDisposedOrNotOpen()
[2023-09-13 01:43:26Z] Will retry in 2 minutes
[2023-09-13 01:44:19Z] Server connection restored
[2023-09-13 01:44:19Z] ..connected to 'VNW00006869'
[2023-09-13 01:45:16Z] Listener restarted
[2023-09-13 01:45:16Z] Listener started.
[2023-09-13 01:45:26Z] New connection from 10.39.17.138
[2023-09-13 01:45:27Z] New connection from 10.42.152.32
[2023-09-13 01:45:27Z] New connection from 10.43.152.28
[2023-09-13 01:45:27Z] New connection from 10.43.152.26
[2023-09-13 01:45:27Z] New connection from 10.42.152.31
11-12-23 10:05 PM
Hi Ramesh,
What is the version of Blue Prism in which this is occurring and what connection mode are you using? Have you reviewed these Knowledge Base articles about this type of exception as a first step?
- BPE error "Internal : The underlying secure session has faulted before the reliable session fully completed. The reliable session was faulted"
- BPE error "Internal : The underlying secure session has faulted before the reliable session fully completed. The reliable session was faulted" when adding new items to Work Queue
12-12-23 06:22 AM
Hi Steve,
Thanks for your reply. I am using Blue Prism 6.10.5 version and I searched BP Forums and Google, but it did not help. Still I am facing the issue.
12-12-23 03:11 PM
Hi Ramesh,
The solution would likely be dependent on the type of connection mode you're using as well as getting some feedback on if you've tried the documented solutions in the KB articles above (Portal access required).
If implementing the suggestions from the KB articles about this error don't help, I'd recommend you open a Support ticket with us containing the required information and what you've tried to this point so we could investigate further.
13-12-23 05:08 AM
Hi Steve,
Seems I don't have access to portal, hence I couldn't open the links you sent. However, I tried all other options from web. Let me describe more about the issue, it may help solutioning.
My connection to Application Server or DB Servers gets deadly slow, though there is no much load and have load balancer in place. When I see event viewer I see the above error, don't know why it went to faulty state. App & DB servers reboot worked for sometime, but again same issue. I am connecting using WCF connection mode. In case it doesn't solve, sure I will raise a ticket with Blue Prism.
13-12-23 03:03 PM
Hi Ramesh,
Your best bet would be to send an email to support@blueprism.com to get your Portal access sorted out, as our Knowledge Base articles cover this exact scenario when using WCF connection methods, and having Portal access will also allow you to log a ticket directly with us.
