Task from inside the scheduler failed to start and left no trace
05-11-21 10:55 AM
I have one automated business process divided into several BluePrism processes that are combined together with schedulers.
On Tuesday, one task from the scheduler did not start. Zero footprint in the control room, no error, no info.
Today (Friday) It did not start two tasks from inside a different scheduler but for the same business process. Also zero trace in control room, no Terminated info, or anything else. As if it was never planned to launch.
I would like to add that the schedulers started flawlessly before Tuesday and, for example, on Wednesday or Thursday.
In my opinion, it is also not a problem with the license, schedulers are set in a cascade, and the problem does not apply to the first task in the scheduler.
It seems to me that the problem started after the release of another business process in this environment.
Anyone have an idea what could be the reason? What is happening and how to check the reason for the lack of such strange launches from the schedulers?
EDIT:
ERRORS FROM [BPAScheduleLogEntry]
Task: Add to Queues - 004_CashPosition - Session creation failed on resource 'VLD-DED-STD-29': Failed to create session on VLD-DED-STD-29 - COMMAND NOT VALID AT THIS TIME - RESOURCE IS STOPPING (WAITING FOR RUNNING SESSIONS TO COMPLETE)
Task: Check OD - 004_CashPosition - Session creation failed on resource 'VLD-DED-STD-29': Failed to create session on VLD-DED-STD-29 - COMMAND NOT VALID AT THIS TIME - RESOURCE IS STOPPING (WAITING FOR RUNNING SESSIONS TO COMPLETE)
Wojciech Rogman
05-11-21 12:35 PM
As per the issue description fond the below steps might help.
1 . Check all processes available in control room
Prasanth Chirukuri
iOPEX Technologies
05-11-21 01:12 PM
Wojciech Rogman
05-11-21 03:44 PM
I recently came across an issue where one of the schedules was not working correctly giving "No sessions were successfully created" error.
After checking all the usual stuff, we were not able to identify what was the issue.
In the end we created a new schedule and it appeared to resolve the problem. Thought I should mention in case you have similar issue.
Pritam Poojari
Solution Architect
Capgemini
05-11-21 04:06 PM
Wojciech Rogman
06-11-21 06:26 AM
Vipul Tiwari
Amazon
08-11-21 12:24 PM
Fail fast on error will stop the runner from invoking subsequent tasks if the previous task failed on any of the assigned RRs. i would not recommend it if there are multiple tasks created under the same schedule. Introducing adequate delays between the tasks should do the trick.
Jerin Jose
Technical Product Owner
EY
*"If you find this post helpful mark it as best answer, .*
08-11-21 05:21 PM
John Carter
Professional Services
09-11-21 06:48 AM
Quote : It seems to me that the problem started after the release of another business process in this environment.
In that case I would have a look in the Reports under Scheduler in the Control ... maybe you find a trace there
Good Luck
Johan
Internet communications are not secure and therefore BGL BNP Paribas does not accept legal responsibility for the contents of this message. The information contained in this e-mail is confidential and may be legally privileged. It is intended solely for the addressee. If you are not the intended recipient, any disclosure, copying, distribution or any action taken or omitted to be taken in reliance on it, is prohibited and may be unlawful. Nothing in the message is capable or intended to create any legally binding obligations on either party and it is not intended to provide legal advice.
