Techinal Error when Bot is running
24-07-18 05:17 PM
Hi All,
When my bot is running then we are getting error like An error occurred while refreshing the environment list:
The parameterized query @status int, @start datetimetime , @local int, @machinename navarchar (40) expects the parameter which was not supplied
Please find the attache file for the same. I think database is getting disconnected and that is why we are getting the errors
Please solve the issue
24-07-18 10:21 PM
It sounds like either your DB is approaching maximum capacity or maybe the app server is struggling to handle the traffic. I suggest you contact Support for advice.
