This machine is already performing and archiving process
StevenBlake
Hi all,
We're part way through archiving our session log tables to a network drive.  In error our technology team carried out a system update which resulted in a forced reboot.  Archiving was only 15% complete at the reboot point.
Now, when we try the archive process again we get an error which says 'This machine is already performing an archiving process'
We've tried:
1. Terminating automate.exe​
2. Restarting the VM
3. Logging out/in
4. I have ruled out connection between the archive VM and the database server.
5. bypassed the Application server (that manages connections) and went straight to the SQL Database
I'm guessing there is a field or something in the database with a the True value that an archive is in progress and for some reason the archive process was interrupted.
Would appreciate any input.
Cheers
S
Steven Blake
Process Automation Specialist
Computershare
DaveMorris
Level 14
Yep, you're exactly right. Here's a Support article explaining how change the flag: http://portal.blueprism.com/customer-support/support-center#/path/1141528422
Dave Morris
3Ci @ Southern Company
Atlanta, GA
Thanks David, that's a great help.  Saved us a lot of time I'm sure!​
Steven Blake
Computershare
dfry
Hi Steven
Hi Steven
Did you also check out ether of the following articles in the Blue Prism Support Center, just in case they contain any useful information pertaining to this error?
Please note you would need to be logged into the Blue Prism Portal in order to access these articles.
Thanks very much
dean fry
Content Manager
