Trigger Blue Prism Process from external process (SSIS) ?
JustinPiche
Is there a way to trigger a blue prism process from an external process like a SSIS package or web service call?  We have a broader process that relies on other systems to process first and the timing is unpredictable based on the number of records being processed, we would like our ETL package to call the Blue Prism process as part of the sequence. I did some research but was unable to find a clear answer to this question.  Thanks
Yes you can expose a process as a WS https://portal.blueprism.com/system/files/2017-11/v6%20User%20Guide%20-… https://portal.blueprism.com/system/files/2018-02/v6%20User%20Guide%20-… There is a command line API too, see in-product help for details.
