Trouble on input Multi byte characters into Chrome text box.
TAKINO
I have installed BluePrism ver6.3 and tested some simple operation with Chrome bowser while expectation. But, when the RPA input multi byte character into a text box, they are changed to special characters. Does the chrome extension support multi byte character handling ? Or must I set up any configuration ? -------- Ver6.3 is very welcome for us. Multi-Team Environment and Chrome support is necessary.
6 REPLIES 6
Hi Takino,   Are you from Japan?   I think you can not fix this issue. This is an encode issue.   You need to put the text into clipboard and use send key to paste the text which you want to type.
TAKINO
Hi tsai, Yes, I'm from Japan. Thank you for your useful information.   I made it using ""Set Clipboard"" and ""Global Send Keys"".
Hi TAKINO, It's good to hear about that!   I also come from Japan and I consider about the possibility of holding an user camp or seminar to talk about the technical issue. Are you interested in joining this seminar?   Tsai
MetVonghiran
Hello, c.tsai   I'm also very interested in joining such a seminar.     Regards, Met Vonghiran
TAKINO
Hi tsai, I'm off course interested in such a seminar. Thanks so.
Hi Takino and Met,   I appreciate you showing the positive attitude to me.   Are you in Tokyo?   Since I can not afford the price of rent office, maybe I can invite you to my company.   If you still are available and interested in this seminar, please write down your email address here to let me contact you :) (Don't worry about the participation fee. It's free!)
