UI Mode and UIA Automation ID
25-02-20 06:32 PM
We are working on a web application automation. We used UIA Automation ID and it was working fine. There was a recent change on that Web Application and we don't see UIA Automation ID any more. We used HTML mode and UI mode...but didn't help.
Any workaround for this ? Attcahed are few images to explain it better.
Manas Jena
Sr Analyst
ZimmerBiomet
America/New_York
06-03-20 04:52 PM
the UIA Automation ID attribute is set equal to the value of the ID attribute in the HTML source. Most likely the ID attribute has been removed from that HTML element in the HTML source when the application has been updated. If it's an internal web application, you can ask the product owner team to add that ID value to the HTML code.
Luca Valente
Senior Product Consultant
America/New_York
10-12-20 02:17 PM
Chris Ellenburg
10-12-20 04:33 PM
Not able to recall the exact fix since it is a while now.You May need to compare your lower and upper environment and do a re-spy to avoid this . Would you share more about the issue you are facing ?
Manas Jena
Sr Analyst
ZimmerBiomet
America/New_York
10-12-20 04:39 PM
Chris Ellenburg
10-12-20 04:42 PM
Chris Ellenburg
10-12-20 04:45 PM
From there you can proceed.
Manas Jena
Sr Analyst
ZimmerBiomet
America/New_York
10-12-20 04:57 PM
Chris Ellenburg
06-11-24 05:51 PM
Were you ever able to resolve your issue?
