Thanks for the response Karan.  Is there a reason why Web Path isn't a valid attribute name, when it is an attribute found on the Application Modeller?
Is there a pseudonym I can use as the [attribute name] instead of 'Web Path' which will return the Path?
For context, I am wanting to read in the Path of one element, to dynamically calculate the Path of a related attribute.
The web application i'm using appears to be poorly built (I suspect it's a web front end for a legacy back-end), and using surface automation is just not a realistic alternative to use with this application, as the majority of elements are not necessarily screen visible.
Scott Robson
