05-10-23 03:41 PM
I am getting random errors as shown below while executing the process in Unattended scenario.
When the process runs in attended mode, it works fine but the issue is only with unattended mode.
I have already gone through other posts in this topic and also followed steps over there as mentioned but no luck so far.
Also would like to highlight that the VM is in Azure Platform and we are using RDP session to login the VMs for process execution. There are no security policies in the VM which can lock the screen so its permanently unlocked. Already verified through RTR latest screen capture option whenever an exception occurs and there is no issue with screen resolution as well because its same in both attended and unattended scenarios.
Blue Prism version is 6.10.5. Kindly help resolving this issue. Screenshots below.
10-10-23 04:38 PM
Hi @Luis Lopez,
The issue has been resolved currently by following the below URL and executing the VM commands as mentioned here. Although Regression testing is ongoing to conclude the unattended Automation Execution in Azure VMs.
05-10-23 06:14 PM
It is hard to help you without knowing what is happening on the screen. You can check the following article "BPE error "Could not identify process owning the current foreground window" when trying to focus an application" here regarding that error.
You can enable an exception to Save a Screen Capture of the moment when it fails. So you can see what is blocking the screen or why the element is not visible.
06-10-23 09:36 AM
Hi @Luis Lopez,
I have already checked the exception screenshot using the screen capture. The screen is not locked and GUI is also in foreground but still random exceptions like element not found and sometimes foreground errors are coming.
06-10-23 04:53 PM
Can you check add before looking for the element that you use, Activate Application, just to be sure the window ready.
10-10-23 04:38 PM
Hi @Luis Lopez,
a month ago
And if it is the Activate Application that is throwing the exception?
a month ago
@EThuer It'd be best to create a new post and describe your scenario in as much detail as you can provide.
In general though, if activate application is throwing an exception, it means either speed of execution is your problem and you need a conditional wait stage beforehand, or the element just doesn't exist that you're targeting for the activate.
4 weeks ago
Hi @esaugos , In Azure Environment the VM's is in idle state for very long time. So when ever you are triggering the main process/Bot kindly use Login agent to activate the VM & wait for 1 to 2 minutes to activate resource PC & trigger your main process. These type of fore ground issues will sort out.
If any scheduler is exist add a task to restart, login, Main process, logout... Definitely this issue will be resolved. Hope this will be helpful.
Reagrds,
Roopkiran.
