Hi All,
I am trying to use the LINQ code in code stage of Blue Prism. Code is having no error but when I am trying to run it is giving following error:
Description: Compiler error at top section line 7: A using namespace directive can only be applied to namespaces; 'System.Data.DataTable' is a type not a namespace
Could you anyone can help me to solve it out.
DLL is use are as follows:
System.Core.dll ; System.dll ; System.Data.dll ; System.Xml.dll ; System.Drawing.dll ; System.Data.DataSetExtensions.dll
Namespaces are as follows:
System ; System.Drawing ;System.Data ; System.Linq ; System.Collections.Generic ; System.Data.DataTable
Code Stage :
Coll2 = new DataTable();
Coll1 = new DataTable();
Coll2 = Coll1.Clone();
var Result = from num in Coll1.AsEnumerable() Select num.ToList(); // to select all the data from Coll1 input collection
foreach(var res in Result)
Coll2.ImportRow(res);
Jatin Kalra
Jatin Kalra
Manager
Genpact
Noida UP
[Phone]
