Using different data item in a loop
HarshithKumar
​Hello Everyone!
I want to know is there a way to use different data item in a loop. suppose I have cal1, cal2, and cal3 as data item which I want to use in calculation while in a loop. so can I dynamically use it buy using a count starting from 1 to 3(col1,col2,col3) and using them instead of using choice.
Thanks in advance.
Harshith Kumar
Graduate Engineering Trainee
Schneider Electric
Not sure I understand the question properly, but if you mean 'can I dynamically calculate references to data items' the answer is no.
John Carter
Professional Services
Got the Answer.
Thank you.
Harshith Kumar
Schneider Electric
