Using xpath in xml VBO
AyyoubBenoudina
Hello People
Coul you please tell me how can I use the "get elements with Xpath" in utility-vml-vbo of BluePrism.
It gets elements only if I give "//*"   but If I try to navigate further it gives me nothing like: //soap-env:envelope/soap-env:Body/.
I don't know how to declare name spaces in this utility please help me?
Thanks and best regards,
Ayyoub
Ayyoub Benoudina
Analyst-Sol Development
peterlacken
Level 7
Hi Ayyoub,
be sure you are using the correct syntax for XPath. It can be fiddly to get right.
https://www.w3schools.com/xml/xpath_syntax.asp
Peter
PeterLacken
Ren Røros Intelligent Automation
[email protected]
http://www.rria.no
