Visual basic
SridharYadlapal
Hello all
Can anyone say how to learn visual basic for Blue prism or either can I learn C# instead
Sridhar Yadlapalli
Hi Sridhar,
If you want to learn VB .NET or C# for Blue Prism, I would suggest go through Tutorials Point which probably will guide you through the basics.
Also, before directly working on Code Stage, I would highly recommend to install Visual Studio and practice as many use cases as you can then try to implement the same on Blue Prism.
Learning any among C# or VB .NET is fine, it all depends on the business requirement you have. Just focus on one language, preferably start with C# as you will be able to create external DLL's easily on Visual Studio and try to run various use cases on it. Also, many good use cases are available on C# Corner, start practicing those once you are done with basics of the language.
Also, I have a YouTube channel where I have a dedicated playlist for some of the interesting use cases on code stage where I keep posting from time to time: Code Stage Tutorial
Hope this answer helps to clear your doubts
Blueprism 6x Certified Professional
Email: [email protected]
Hi Sridhar,
There is also an e-learning available on Blue Prism University on how to use code stages. Here is the link https://university.blueprism.com/learn/course/16700/Blue%252520Prism%252520Code%252520Stages%252520Training
Shashank Kumar
Singapore
+6581326707
Thank you
Sridhar Yadlapalli
