What is the advantage and disadvantage of using so many attach Pages in Actions?
RAJESHGOWRABATH
If suppose use the multible Attach actions in Every Page or use the Attach Action in whole object Which one is best for faster the process and give less complexity.
Starting every page with a reference to an Attach page is not technically necessary as you can only perform an Attach once. And when attached the object will not detach itself. It's only recommended as a safeguard in case the process developer forgets to attach the object. Adding the references won't make any real difference to Control Room performance.
