Work Queue Reporting
21-03-17 07:39 PM
I'm trying to extract EOD queue data using the built in action called "Get Report Data". I've provided it with the queue name, loaded start/end datetime and a flag of true for completed items. I keep getting an internal error stating " Internal : Invalid column name 'state'. Anyone able to provide an insight into this?
5 REPLIES 5
21-03-17 08:19 PM
It might be worth reaching out to any contact you have in the Blue Prism PS team (Trusted Advisor/Delivery Enablement Manager) - as they have some standard reports that you can use as your basis for this.
21-03-17 08:21 PM
Hi Aodhan - I think that's a bug I'm afraid, and if you contact the support team they will probably advise you to upgrade to a higher version of BP. I appreciate that isn't a simple job, so as a work around you could try using Get Completed Items and Get Exception Items instead. Like Get Report Data they will output a collection of item IDs that you can loop through calling Get Item Data.
22-03-17 12:33 AM
Hi Denis/John
I'll reach out to our point of contact regarding what version we are running. In the meantime I'll try the Get Item Data with a loop and that should solve it.
Thanks for the quick response on this guys
05-10-17 04:30 PM
hi Aodhan
I am too facing the same issue .
please let me know how did you resolved this issue ?
08-10-17 05:41 PM
Hi
I think almost all the data could be derived from data of Get Completed/Exception Items.
