importing releasefile using AutomateC
27-11-18 12:25 PM
I have a release a file in my local desktop, is there any CMD command which can import this release file into a dbconname.
I need help on the following command from CMD,
AutomateC /sso /dbconname="conName" /import "releaseName"
I am getting error like "......root element id it should be "
Is there any way that I can import whole release in a BP environment rather importing a process.
Thanks and Regards,
sudharsan.
12 REPLIES 12
12-11-19 07:00 PM
Hi Dave, does an automated release using command line work for skills (web APIs)? We tried it a couple of times and the web apis got imported in the system but process actions do not point to those skills. The error message say "skill abc is not installed or is unavailable".
Pritesh Jadhav
Senior Associate
PwC
America/New_York
Pritesh Jadhav
Senior Associate
PwC
America/New_York
20-11-19 05:29 AM
Details of command lines
Vivek Goel
RPA Architect
Asia/Singapore
+6594554364
https://www.rpatools.com/
Vivek Goel
RPA Architect
Asia/Singapore
+6594554364
20-11-19 05:00 PM
You need to open to command prompt in administrator mode. Though you are admin user windows keep one higher login with itself. If you login with that or while using command prompt you can provide admin user name and password you will not get his error
Vishal Jadhav
Vishal Jadhav
- « Previous
- 1
- 2
- Next »
