AutomateC Import Process Issue
ChrisBrook
I'm currently building a tool which will automate the release management process with some additional bits involving GitHub.
As part of this I'm trying to import a single process file via the AutomateC command line - however hitting a constant error.
I'm currently importing into a local instance of BP without SSO enabled and this is the command line I'm passing:
"C:\Program Files\Blue Prism Limited\Blue Prism Automate\AutomateC.exe" /dbconname "BP_6_10_2_LOCAL" /user admin password /import "C:\Temp\ProcessName.xml" /overwrite​
The error I'm then getting is 'Error: No matching files found' - even though there is the exact file referenced in the command line in the exact location mentioned in the command line and it's a valid file I can open.
Any suggestions?
Chris
11 REPLIES 11
JohnCowell
That's very odd Chris. I've done pretty much the same as your example and it works fine. I can get it to fail in the same way as you if I use a filename that I know doesn't exist. What version is that? My test VM is on 6.10.2.
Maybe try copying the XML file into C:\Program Files\Blue Prism Limited\Blue Prism Automate and try the import when running the same command from that folder and see if you get the same error. If that works, move the file to the C:\Temp folder and see if that works.
John Cowell Senior Software Support Analyst Blue Prism
ewilson
Hi @ChrisBrook,
I believe in version v6.9 we introduced new file extensions for VBOs (.bpobject) and processes (.bpprocess). Are you sure your file has a .XML extension and not the newer .bpprocess extension? .XML still works though. Just want to make sure it's not something obvious.
Have you tried moving the file directly into the BP Automate folder to see if there's some weird permissions issue stopping BP from reading from your Temp folder?
Eric​
ChrisBrook
Thanks @ewilson @John Cowell - so to confirm 2 things:
1)  it's definitely xml, but that's because I'm creating it as xml (will explain more below)
2) BP version 6.10.2 - and yeah didn't work when moving the file
The tool I'm building effectively takes a .bprelease file and extracts all components i.e. processes, objects, EVs and queues and displays them to the user (similar to how the bp interface works).
It'll then allow someone to select the bits they want to import (listbox multiselect) and then will extract the specific process or object xml elements from the overall .bprelease file and save it as a seperate .xml file.
That's then the basis for the import command and also what gets pushed to a GitHub repository. Now you could say 'well the file might be corrupt' - however if I manually import that file via the interface it works absolutely fine...​​
ewilson
@ChrisBrook,
Thanks for the additional information. A few things I'd suggest.
  1. Make sure the application that's creating the new .XML file isn't hanging on to a file pointer. If the file is seen as being open by another application AutomateC may not like that (seeing it as locked).
  2. I would export the process that you imported manually and compare it against the one you created using your tool to see if there are any minor differences in the XML. In theory, if you can import it manually via the Interactive Client then AutomateC should be happy with it. However, that's an assumption I would validate. 🙂
Eric​
ChrisBrook
This is weird!
So did as suggested, double checked that the stream was closed and the file wasn't open anywhere else - and it was closed and not open anywhere else.
Then exported it and other than some simple xml differences because the original .bprelease file was from 6.4 it was all fine.
So then I plugged the exported file into the command line and got exactly the same error...
ewilson
@ChrisBrook,
To be clear, the process that you manually imported, and then exported, is now throwing the same error from AutomateC? What happens if you try to manually import it again?
Eric​
ChrisBrook
Correct, and manually imports fine!!
And it's the same regardless of whether cmd.exe is opened as administrator or as a normal user.
ewilson
@ChrisBrook,
I've run several tests trying to recreate your issue, but I've been unsuccessful. The only thing I can think is that there is something in the XML differences that AutomateC isn't happy about, but that the Interactive Client doesn't care about.
I created a test process in a v6.4 environment and manually exported it. Then I attempted to import it into a v6.10.2 environment using AutomateC, and everything worked fine.
Can you send me a copy of your process XML?
Eric​
ChrisBrook
See below. There's no confidential data or anything so fine sharing this:
<process name="COE – SCA ACH – Additional Card Holders.01.Master" version="1.0" bpversion="6.4.0.8445" narrative="The process is responsible for the updating the Mobile Phone Number of Alternate Card Holders across all brands (Lloyds, Halifax, Bank of Scotland &amp; MBNA) from a twice daily csv input file in the Vision+ application. This Master process will contain all required business logic to complete this activity." byrefcollection="true"><view><camerax>345</camerax><cameray>405</cameray><zoom version="2">0.9375</zoom></view><preconditions><condition narrative="N/A" /></preconditions><endpoint narrative="N/A" /><subsheet subsheetid="68ad4f62-d0ab-4106-a72b-6a79fef7e4cb" type="Normal" published="False"><name>1. Start Up</name><view><camerax>0</camerax><cameray>-21</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="db0a31d1-a3aa-489e-8e85-91f3deea50f6" type="Normal" published="False"><name>1.1 Control Applications</name><view><camerax>75</camerax><cameray>525</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="4f58220f-de37-4011-8c1d-8e4c64b79bf3" type="Normal" published="False"><name>1.1.1 Start IBC</name><view><camerax>0</camerax><cameray>165</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="31bf5df4-1d9d-49f4-92f4-b96e2e524f1d" type="Normal" published="False"><name>1.1.2 Start Vision+</name><view><camerax>96</camerax><cameray>399</cameray><zoom version="2">0.625</zoom></view></subsheet><subsheet subsheetid="06db150d-d3f5-4c6c-bddf-d0b8a0841b6c" type="Normal" published="False"><name>1.1.3 Maintain IBC</name><view><camerax>0</camerax><cameray>0</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd" type="Normal" published="False"><name>1.1.4 Maintain Vision+</name><view><camerax>0</camerax><cameray>0</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="68d93676-eb08-48bb-be21-d51abf5c2e59" type="Normal" published="False"><name>1.1.5 Exit IBC</name><view><camerax>0</camerax><cameray>105</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="d72f787b-00d1-4bd9-aa91-be39f5007ff9" type="Normal" published="False"><name>1.1.6 Exit Vision+</name><view><camerax>0</camerax><cameray>165</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="059ac15f-cd8e-42f1-a3e3-bba2987cd702" type="Normal" published="False"><name>2. Create Loop Data</name><view><camerax>0</camerax><cameray>-135</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="1e5325c1-b03d-4dad-8487-c5cb1fcc6d09" type="Normal" published="False"><name>3. Validate Mobile Number</name><view><camerax>44</camerax><cameray>375</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="d12139ff-715c-4ebe-8a87-3be8b5e7ec41" type="Normal" published="False"><name>4. Retrieve OCIS ID</name><view><camerax>135</camerax><cameray>105</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="cac99af1-dcbf-48bd-b310-e90a5e99917d" type="Normal" published="False"><name>5. Vision+ Search &amp; Update</name><view><camerax>453</camerax><cameray>-15</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce" type="Normal" published="False"><name>5.1 Go To Table</name><view><camerax>-63</camerax><cameray>465</cameray><zoom version="2">0.9375</zoom></view></subsheet><subsheet subsheetid="e1f35caa-a327-4bcf-91a2-870bcd6851c8" type="Normal" published="False"><name>5.2 Read Row</name><view><camerax>0</camerax><cameray>99</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="c9ccc708-a0df-4309-8e81-393f66cf5314" type="Normal" published="False"><name>5.3 Check ACH</name><view><camerax>-43</camerax><cameray>45</cameray><zoom version="2">0.9375</zoom></view></subsheet><subsheet subsheetid="1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91" type="Normal" published="False"><name>5.4 Update ACH</name><view><camerax>-27</camerax><cameray>165</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="6f6fb598-b7c6-4705-976b-14191d9d2bab" type="Normal" published="False"><name>6. Mark Item as Completed</name><view><camerax>0</camerax><cameray>0</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="853c5533-4f26-4c01-976d-b19981861ac0" type="Normal" published="False"><name>7. Mark Item as Exception</name><view><camerax>0</camerax><cameray>45</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="0b444530-73f6-4830-92d5-b46382507891" type="Normal" published="False"><name>7.1 Notify Termination</name><view><camerax>0</camerax><cameray>42</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="c835a1b2-5b34-4481-8929-b5c9c3e423bf" type="Normal" published="False"><name>8. Reset Global Data</name><view><camerax>0</camerax><cameray>105</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="c2e2ca54-d379-4238-8b26-f7afd958d4f6" type="Normal" published="False"><name>9. Close Down</name><view><camerax>0</camerax><cameray>0</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52" type="Normal" published="False"><name>10. Poll</name><view><camerax>0</camerax><cameray>125</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="7725a2f9-38a1-42c9-8bcd-8b2156e457f9" type="Normal" published="False"><name>Send Email</name><view><camerax>0</camerax><cameray>0</cameray><zoom version="2">1.25</zoom></view></subsheet><subsheet subsheetid="a69fe59a-cbfa-4ddb-b84f-175b62d7a2af" type="Normal" published="False"><name>Set Custom Status</name><view><camerax>0</camerax><cameray>0</cameray><zoom version="2">1.25</zoom></view></subsheet><stage stageid="b3ad06a7-b8ed-466a-b111-4e843d048455" name="Start" type="Start"><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-210</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="time" name="Stop After Time" narrative="The time to stop the process running at" stage="S_Stop After Time" /><input type="number" name="Stop After Items" narrative="How many worked items to end the process after" stage="S_Stop After Items" /></inputs><onsuccess>71d7a79b-ec73-4611-9872-2bede6964e55</onsuccess></stage><stage stageid="cfd98111-c426-4ca8-97a9-89e6ba14c8e9" name="End" type="End"><loginhibit /><narrative></narrative><displayx>690</displayx><displayy>-195</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="3a47f168-14e7-426d-9593-5b3d38697543" name="Stage1" type="ProcessInfo"><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>-90</displayy><displaywidth>240</displaywidth><displayheight>150</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="89ff8afd-3315-4d6e-afab-c90c23758f61" name="1.1 Control Applications" type="SubSheetInfo"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative>Maintains target applications by starting, restarting, closing down or just keeping a session from timing out.When not working a queue item this normally will mean returning an application back to it's 'ready' state.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>180</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="dc8dcd89-06d4-48d3-aded-68a005c62b82" name="10. Poll" type="SubSheetInfo"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative>Waits for new work to be loaded</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="0d5db25c-30eb-460d-8a1e-0c93826e9e4b" name="6. Mark Item as Completed" type="SubSheetInfo"><subsheetid>6f6fb598-b7c6-4705-976b-14191d9d2bab</subsheetid><loginhibit /><narrative>Marks item as complete once all stages have been finished</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="9ab0c308-5b43-4ecc-812f-7ccc5f5f29f3" name="Start" type="Start"><subsheetid>6f6fb598-b7c6-4705-976b-14191d9d2bab</subsheetid><loginhibit /><preconditions><condition narrative="Item incomplete" /></preconditions><postconditions><condition narrative="Item complete" /></postconditions><narrative></narrative><displayx>-30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b341a65f-2a57-4b28-a6e6-326aa5ba1f5b</onsuccess></stage><stage stageid="005bf533-99cb-4f76-950e-3fd6ac0ab65e" name="End" type="End"><subsheetid>6f6fb598-b7c6-4705-976b-14191d9d2bab</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="199230e2-83fc-4394-b75a-a2d3c38aa92c" name="7. Mark Item as Exception" type="SubSheetInfo"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative>Marks item as either a Business or System exception. Also manages logic on whether to terminate due to consecutive exceptions.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="4667dc2d-acf9-43a3-b48d-31b35b31a784" name="Start" type="Start"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><preconditions><condition narrative="Item incomplete" /></preconditions><postconditions><condition narrative="Item marked as exception" /></postconditions><narrative></narrative><displayx>-30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>4004ca7e-2000-4a63-b26c-dc29de19babd</onsuccess></stage><stage stageid="2fac624a-2fcf-4316-bf27-bfa3002e41da" name="7.1 Notify Termination" type="SubSheetInfo"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative>Provides a Controller notification that the process has terminated.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="44672e6e-45f6-4bd6-923b-4e1a405a4987" name="Start" type="Start"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>15</displayx><displayy>-105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>27eb1492-be1f-49e6-b31c-812d9c832686</onsuccess></stage><stage stageid="c2315a64-3474-4bc2-819a-f8927e5c2884" name="Send Email" type="SubSheetInfo"><subsheetid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</subsheetid><loginhibit /><narrative>Sends an email to the required recipient based on a number of inputs.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="6524865e-2236-4885-bd30-83cc7a162218" name="End" type="End"><subsheetid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="1aed222b-434a-4857-b60f-ef1f6ccfc23e" name="8. Reset Global Data" type="SubSheetInfo"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Resets all Global Data Items to their original values.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="a0e24e57-48f2-443d-b63f-8b359f942f12" name="Start" type="Start"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>-30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>89fd555d-ed2c-4f53-b3ac-a6206e60e282</onsuccess></stage><stage stageid="89fd555d-ed2c-4f53-b3ac-a6206e60e282" name="End" type="End"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="804fcf27-afd8-4ffb-89e8-7b3930f27650" name="1.1.1 Start IBC" type="SubSheetInfo"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative>This page provides the ability to launch the IBC application and login to the application as required.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="650e70bb-ec35-468f-9b43-145bb1c3dcef" name="Start" type="Start"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><preconditions><condition narrative="IBC Closed" /></preconditions><postconditions><condition narrative="IBC Launched" /></postconditions><narrative></narrative><displayx>0</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>6d7ac860-ed4c-414a-a79f-b4a2687937e3</onsuccess></stage><stage stageid="80e1c4d9-7cff-40e3-8225-f665043ca25a" name="1.1.2 Start Vision+" type="SubSheetInfo"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative>This page provides the ability to launch the Vision+ application and login to the application as required.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="a4056774-b0a0-4796-8c45-ad3fd6cfa45b" name="Start" type="Start"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><preconditions><condition narrative="Vision+ Closed" /></preconditions><postconditions><condition narrative="Vision+ Launched" /></postconditions><narrative></narrative><displayx>15</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>a2e1ceeb-ee7c-4856-aa3e-65f4a3359f0b</onsuccess></stage><stage stageid="5ae08a7e-edcc-4f98-b1c9-2c6a02ace396" name="1.1.3 Maintain IBC" type="SubSheetInfo"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><narrative>This page provides the ability to reset the IBC application to the screens required.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="4af0d72f-8f71-4a11-8e2f-087c655e1ef2" name="Start" type="Start"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><preconditions><condition narrative="IBC open but on incorrect page" /></preconditions><postconditions><condition narrative="IBC on correct page" /></postconditions><narrative></narrative><displayx>-15</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>3e07402b-5258-419f-8168-76ee86b22b62</onsuccess></stage><stage stageid="cab01e86-89f3-411e-909b-ec91e3308a19" name="End" type="End"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><narrative></narrative><displayx>-15</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="bb2ead8b-06b3-4e1d-9380-264354ffe913" name="1.1.4 Maintain Vision+" type="SubSheetInfo"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative>This page provides the ability to reset the Vision+ application to the screens required.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="d37d026e-182a-4c8b-ab74-54786f1854e5" name="Start" type="Start"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><preconditions><condition narrative="Vision+ open but on incorrect page" /></preconditions><postconditions><condition narrative="Vision+ open and on correct page" /></postconditions><narrative></narrative><displayx>0</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>5fb3a84c-0b2c-412b-ad10-425477398773</onsuccess></stage><stage stageid="7f60d293-5a83-4eca-9e7d-891641527904" name="End" type="End"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="1a937118-2af1-4eb1-876f-f107643a166e" name="1.1.5 Exit IBC" type="SubSheetInfo"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative>Provides the ability to soft close and hard close IBC where required</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="f8d1dcf0-d5f2-410d-9f5b-1d76c6553bd6" name="Start" type="Start"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><preconditions><condition narrative="IBC Open" /></preconditions><postconditions><condition narrative="IBC Closed" /></postconditions><narrative></narrative><displayx>30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>258f4cd5-4ac3-4c9d-88eb-6fddfba6b57a</onsuccess></stage><stage stageid="938e4e94-1e86-4ff8-837c-81f7e4b844b1" name="1.1.6 Exit Vision+" type="SubSheetInfo"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative>Provides the ability to soft close and hard close Vision+ as required</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="bf4adaae-e09a-4bf0-b972-ab41dab94f82" name="G_Process Name" type="Data"><loginhibit /><narrative>The name of the process</narrative><displayx>-195</displayx><displayy>30</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="0000FF" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="c0459696-7555-49a0-9ca4-a367398fd791" name="G_Queue Name" type="Data"><loginhibit /><narrative>The name of the queue</narrative><displayx>-195</displayx><displayy>60</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="0000FF" /><datatype>text</datatype><initialvalue xml:space="preserve">COE - SCA ACH</initialvalue><alwaysinit /></stage><stage stageid="542eb06f-7fe2-4f7b-a2e5-8350168eda36" name="Stop After Consecutive Exceptions" type="Data"><loginhibit /><narrative>Flag on whether a stop should occur when 3 consecutive exceptions have occured</narrative><displayx>-195</displayx><displayy>360</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="FF9900" /><datatype>flag</datatype><initialvalue>False</initialvalue><alwaysinit /></stage><stage stageid="d1c1ba2b-2699-4a98-bd3f-d6b43cee8aab" name="Exception Control Settings" type="Block"><loginhibit /><narrative></narrative><displayx>-285</displayx><displayy>330</displayy><displaywidth>180</displaywidth><displayheight>120</displayheight><font family="Tahoma" size="10" style="Regular" color="FF9900" /></stage><stage stageid="5fb32eae-af2e-4ce4-bb19-7c57efc55b0c" name="Session Variables" type="Block"><loginhibit /><narrative></narrative><displayx>-285</displayx><displayy>195</displayy><displaywidth>180</displaywidth><displayheight>120</displayheight><font family="Tahoma" size="10" style="Regular" color="FF0000" /></stage><stage stageid="1e1dbc70-a1ad-4835-9915-e47d324c77eb" name="Process Settings" type="Block"><loginhibit /><narrative></narrative><displayx>-285</displayx><displayy>0</displayy><displaywidth>180</displaywidth><displayheight>180</displayheight><font family="Tahoma" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="c84979bc-d4a8-46a8-ba3c-c154e0ff1860" name="S_Stop After Time" type="Data"><loginhibit /><narrative>Used by the process to decide whether to keep working or close itself down. This value can be modified from Control Room to bring a session to an early finish.</narrative><displayx>-195</displayx><displayy>225</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><datatype>time</datatype><initialvalue>20:00:00</initialvalue><exposure>Session</exposure><alwaysinit /></stage><stage stageid="7e2d45f3-a217-4e93-b656-fb875a18b18b" name="S_Stop After Items" type="Data"><loginhibit /><narrative>Used by the process to decide whether to keep working or close itself down. This value can be modified from Control Room to bring a session to an early finish.</narrative><displayx>-195</displayx><displayy>255</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><datatype>number</datatype><initialvalue>9999999999</initialvalue><exposure>Session</exposure><alwaysinit /></stage><stage stageid="55fed3c0-0212-4851-b362-d7e267ab75e5" name="1. Start Up" type="SubSheetInfo"><subsheetid>68ad4f62-d0ab-4106-a72b-6a79fef7e4cb</subsheetid><loginhibit /><narrative>Sets up any global values specific to the running environment (Dev/Test/Live), checks for any potential environental problems, and then logs into the applications.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="5962ae92-b84b-4f89-a7b4-31a8feeeb253" name="Start" type="Start"><subsheetid>68ad4f62-d0ab-4106-a72b-6a79fef7e4cb</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>15</displayx><displayy>-105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>cf9caa0e-02a1-4d0c-9a9c-42c40b6633c5</onsuccess></stage><stage stageid="0557a731-751d-4f0c-9a39-da9d3d4fbb90" name="End" type="End"><subsheetid>68ad4f62-d0ab-4106-a72b-6a79fef7e4cb</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /></stage><stage stageid="cf9caa0e-02a1-4d0c-9a9c-42c40b6633c5" name="START All" type="MultipleCalculation"><subsheetid>68ad4f62-d0ab-4106-a72b-6a79fef7e4cb</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-30</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><onsuccess>93e8b79a-2dca-483f-bc86-a50af876dfc0</onsuccess><steps><calculation expression="&quot;START&quot;" stage="G_IBC Control" /><calculation expression="&quot;START&quot;" stage="G_Vision+ Control" /></steps></stage><stage stageid="93e8b79a-2dca-483f-bc86-a50af876dfc0" name="1.1 Control Applications" type="SubSheet"><subsheetid>68ad4f62-d0ab-4106-a72b-6a79fef7e4cb</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>0557a731-751d-4f0c-9a39-da9d3d4fbb90</onsuccess><processid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</processid></stage><stage stageid="e296ae32-4cb6-49fa-afca-39ebe7408b52" name="Global Variables" type="Block"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>360</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="5e062ec0-cb6d-4921-a901-218f88028ec8" name="G_IBC Control" type="Data"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Used to  instruct to the Control Applications page to affect an application. The available instructions are START, RESTART and EXIT. The default value (blank) indicates that the application should simply be maintained/returned to the 'ready' position/kept alive.</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="367da180-e750-4a2b-afbd-56b1fbfc4e35" name="G_Vision+ Control" type="Data"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Used to  instruct to the Control Applications page to affect an application. The available instructions are START, RESTART and EXIT. The default value (blank) indicates that the application should simply be maintained/returned to the 'ready' position/kept alive.</narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="c1b06f7c-7b12-4782-87f4-5aaed88166dd" name="G_Exception Type" type="Data"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Used to store the result of the ExceptionType() function for use when not in Recovery Mode.</narrative><displayx>-195</displayx><displayy>45</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="92cd00b9-88aa-4b89-b32c-9b45ca2202a6" name="G_Exception Detail" type="Data"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Used to store the result of the ExceptionDetail() function for use when not in Recovery Mode.</narrative><displayx>-195</displayx><displayy>75</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="81bccc41-977d-482d-9533-8fb3126410d6" name="G_Item ID" type="Data"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Item ID as per BP</narrative><displayx>-195</displayx><displayy>105</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="2572381e-ed21-41cc-b867-fc2feb706039" name="G_Item Data" type="Collection"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Item queue data as per BP</narrative><displayx>-195</displayx><displayy>210</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>collection</datatype><alwaysinit /></stage><stage stageid="7da32db9-73eb-442f-9e55-f5fec0711d4e" name="G_Item Status" type="Data"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Item status</narrative><displayx>-195</displayx><displayy>135</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="b337581f-381a-4a51-ab7f-fab28c398691" name="G_Item Attempts" type="Data"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Attempts to work</narrative><displayx>-195</displayx><displayy>165</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue /><alwaysinit /></stage><stage stageid="a3352a65-4cc3-45b6-b0dc-8a944b7bb6ef" name="Start" type="Start"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>75</displayx><displayy>-120</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>72935ac8-6eed-4eed-82ce-6ad575b98f96</onsuccess></stage><stage stageid="4dc88020-eaff-4102-964b-2b9adb3e4cff" name="Wait Interval" type="Data"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative>The number of seconds to wait between restart attempts.</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>10</initialvalue><private /><alwaysinit /></stage><stage stageid="46682a9a-d5c2-44f1-b0b7-24695a015ef4" name="Maintain" type="Block"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>0</displayy><displaywidth>210</displaywidth><displayheight>105</displayheight><font family="Tahoma" size="10" style="Regular" color="808080" /></stage><stage stageid="28c2f1e9-61b7-4703-8369-431c9fb1f0dc" name="Recover" type="Recover"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>a6defec1-a4df-476a-8a1e-9b634427f235</onsuccess></stage><stage stageid="93439f59-71f3-46b7-8675-86a8037ca70a" name="Resume" type="Resume"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>390</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>ed7fb169-db0d-4205-812b-9b268ab92ab5</onsuccess></stage><stage stageid="a6defec1-a4df-476a-8a1e-9b634427f235" name="Exception Data" type="MultipleCalculation"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>285</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>93439f59-71f3-46b7-8675-86a8037ca70a</onsuccess><steps><calculation expression="ExceptionType()" stage="G_Exception Type" /><calculation expression="ExceptionDetail()" stage="G_Exception Detail" /></steps></stage><stage stageid="5f7b0d97-bc02-4419-a0f6-0abade2c70b9" name="anchor9" type="Anchor"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>945</displayx><displayy>150</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>4f785082-f35f-45fc-acde-81c2c6a0a551</onsuccess></stage><stage stageid="67c70b78-be2a-4a06-b990-873cfb82eb5c" name="Restart" type="Block"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>555</displayx><displayy>0</displayy><displaywidth>525</displaywidth><displayheight>105</displayheight><font family="Tahoma" size="10" style="Regular" color="FF6600" /></stage><stage stageid="9eed6520-7279-4dcb-8e4f-5f4017c0a477" name="Recover" type="Recover"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1035</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>e7c9b650-abe8-484d-abc6-60c6185240dd</onsuccess></stage><stage stageid="225e276e-22c4-4a17-8632-437f5837c898" name="Re-Throw" type="Exception"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1275</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><exception type="" detail="" usecurrent="yes" /></stage><stage stageid="2b31b5eb-2997-49f5-86d9-7e753dbd220c" name="Note8" type="Note"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative>Keep trying to restart</narrative><displayx>1155</displayx><displayy>-120</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="0000FF" /><onsuccess>3a2177af-148c-4a07-adcc-0818a8215fd1</onsuccess></stage><stage stageid="72935ac8-6eed-4eed-82ce-6ad575b98f96" name="Default?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>-45</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><decision expression="Trim(Upper([G_IBC Control]))&lt;&gt;&quot;RESTART&quot; AND Trim(Upper([G_IBC Control]))&lt;&gt;&quot;START&quot; AND Trim(Upper([G_IBC Control]))&lt;&gt;&quot;EXIT&quot;" /><ontrue>29a7076f-7967-432b-b470-ed9328577df8</ontrue><onfalse>6a71646a-bf69-47b9-aaed-2eebe809a310</onfalse></stage><stage stageid="3a2177af-148c-4a07-adcc-0818a8215fd1" name="Resume" type="Resume"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1035</displayx><displayy>-120</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>0128373b-a97f-425e-b308-f7ffa0ed84cd</onsuccess></stage><stage stageid="0d6968de-c251-4268-ac3f-f8e67dcf04a1" name="1.1.5 Exit IBC" type="SubSheet"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>615</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>196bc120-40a8-43ac-b1b2-76b2fb1411ea</onsuccess><processid>68d93676-eb08-48bb-be21-d51abf5c2e59</processid></stage><stage stageid="a574d0ae-0692-4ad0-8f31-b9396b8dccf8" name="1.1.1 Start IBC" type="SubSheet"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>945</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>5f7b0d97-bc02-4419-a0f6-0abade2c70b9</onsuccess><processid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</processid></stage><stage stageid="2dff9581-c630-4b05-b495-75c3292675ef" name="Wait" type="Action"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>840</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="[Wait Interval]" /></inputs><onsuccess>a574d0ae-0692-4ad0-8f31-b9396b8dccf8</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="0128373b-a97f-425e-b308-f7ffa0ed84cd" name="Wait" type="Action"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>840</displayx><displayy>-120</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="[Wait Interval]" /></inputs><onsuccess>f8db0cbd-0478-47ca-a581-541507d41a42</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="6a71646a-bf69-47b9-aaed-2eebe809a310" name="Restart?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>495</displayx><displayy>-45</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><decision expression="Trim(Upper([G_IBC Control]))=&quot;RESTART&quot;" /><ontrue>ed7fb169-db0d-4205-812b-9b268ab92ab5</ontrue><onfalse>ae430b77-03f5-4ba9-8e9e-4f74e7e2dd2c</onfalse></stage><stage stageid="ae430b77-03f5-4ba9-8e9e-4f74e7e2dd2c" name="Exit?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>615</displayx><displayy>-45</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><decision expression="Trim(Upper([G_IBC Control]))=&quot;EXIT&quot;" /><ontrue>0d6968de-c251-4268-ac3f-f8e67dcf04a1</ontrue><onfalse>26719e1f-03d1-4c8a-991a-05f0d855400d</onfalse></stage><stage stageid="26719e1f-03d1-4c8a-991a-05f0d855400d" name="Note10" type="Note"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative>Must be Start</narrative><displayx>945</displayx><displayy>-45</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="0000FF" /><onsuccess>a574d0ae-0692-4ad0-8f31-b9396b8dccf8</onsuccess></stage><stage stageid="196bc120-40a8-43ac-b1b2-76b2fb1411ea" name="Exit?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>735</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><decision expression="Trim(Upper([G_Vision+ Control]))=&quot;EXIT&quot;" /><ontrue>4f785082-f35f-45fc-acde-81c2c6a0a551</ontrue><onfalse>2dff9581-c630-4b05-b495-75c3292675ef</onfalse></stage><stage stageid="4f785082-f35f-45fc-acde-81c2c6a0a551" name="anchor22" type="Anchor"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>735</displayx><displayy>150</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>555ca3f4-951a-4efd-95df-07873dff1d72</onsuccess></stage><stage stageid="f8db0cbd-0478-47ca-a581-541507d41a42" name="anchor27" type="Anchor"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>495</displayx><displayy>-120</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>6a71646a-bf69-47b9-aaed-2eebe809a310</onsuccess></stage><stage stageid="209eadac-0a19-46a9-95af-6bdce1401235" name="Recover" type="Recover"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>435</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>ed4be1ef-8698-4ab5-84ce-fc71ccd009bc</onsuccess></stage><stage stageid="e65f451a-1924-47ef-a000-57b46b1942bd" name="Resume" type="Resume"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>390</displayx><displayy>435</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>3108d7a8-f2c8-4708-9964-29d0e42500d5</onsuccess></stage><stage stageid="03abd095-b0b4-4d5c-9535-1be1eb471979" name="anchor9" type="Anchor"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>945</displayx><displayy>525</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>5902aa7d-86ec-46e5-8a9e-fe89389b66cc</onsuccess></stage><stage stageid="60295ac0-2b6b-44b1-afa4-74da1e310517" name="Restart" type="Block"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>555</displayx><displayy>375</displayy><displaywidth>525</displaywidth><displayheight>105</displayheight><font family="Tahoma" size="10" style="Regular" color="FF6600" /></stage><stage stageid="b2f2361b-5425-4190-9ab8-935a161f982a" name="Recover" type="Recover"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1035</displayx><displayy>435</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>3fddba0f-5942-4c74-ac0e-cfdaf139e7bd</onsuccess></stage><stage stageid="ff4a5729-9a75-4bab-8140-a56143a69366" name="Re-Throw" type="Exception"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1275</displayx><displayy>435</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><exception type="" detail="" usecurrent="yes" /></stage><stage stageid="83f92ca0-35fd-4be1-8829-1fd12954217a" name="Note8" type="Note"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative>Keep trying to restart</narrative><displayx>1155</displayx><displayy>255</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="0000FF" /><onsuccess>a0e0a1f8-0bce-470f-ac60-699c36c078b2</onsuccess></stage><stage stageid="d34252a2-f188-4fe3-8ee2-35581ec54354" name="Default?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>330</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><decision expression="Trim(Upper([G_Vision+ Control]))&lt;&gt;&quot;RESTART&quot; AND Trim(Upper([G_Vision+ Control]))&lt;&gt;&quot;START&quot; AND Trim(Upper([G_Vision+ Control]))&lt;&gt;&quot;EXIT&quot;" /><ontrue>760e9048-e410-4d8a-9637-2622786cc02f</ontrue><onfalse>7f4724ad-e9f3-4212-af87-a884d55630eb</onfalse></stage><stage stageid="a0e0a1f8-0bce-470f-ac60-699c36c078b2" name="Resume" type="Resume"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1035</displayx><displayy>255</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>52dafee5-4cb7-443c-8f5a-18a6cbc24880</onsuccess></stage><stage stageid="44d1ebf5-1636-4f11-a4bb-119c3b568ec3" name="1.1.6 Exit Vision+" type="SubSheet"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>615</displayx><displayy>435</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>3ed383a9-f773-4fb0-a2e8-08dd049adcf9</onsuccess><processid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</processid></stage><stage stageid="85238a94-3ed6-4820-9b75-3f432e89e4e2" name="1.1.2 Start Vision+" type="SubSheet"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>945</displayx><displayy>435</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>03abd095-b0b4-4d5c-9535-1be1eb471979</onsuccess><processid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</processid></stage><stage stageid="b185585f-8c3f-4e4f-839e-f2c5042b0422" name="Wait" type="Action"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>840</displayx><displayy>435</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="[Wait Interval]" /></inputs><onsuccess>85238a94-3ed6-4820-9b75-3f432e89e4e2</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="52dafee5-4cb7-443c-8f5a-18a6cbc24880" name="Wait" type="Action"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>840</displayx><displayy>255</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="[Wait Interval]" /></inputs><onsuccess>9b893bc3-239d-4676-acb8-b6bfc0068fbc</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="7f4724ad-e9f3-4212-af87-a884d55630eb" name="Restart?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>495</displayx><displayy>330</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><decision expression="Trim(Upper([G_Vision+ Control]))=&quot;RESTART&quot;" /><ontrue>3108d7a8-f2c8-4708-9964-29d0e42500d5</ontrue><onfalse>4a5a5a68-f95e-4197-bd2d-848433b8c00d</onfalse></stage><stage stageid="4a5a5a68-f95e-4197-bd2d-848433b8c00d" name="Exit?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>615</displayx><displayy>330</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><decision expression="Trim(Upper([G_Vision+ Control]))=&quot;EXIT&quot;" /><ontrue>44d1ebf5-1636-4f11-a4bb-119c3b568ec3</ontrue><onfalse>747911ef-b259-4635-9612-bec742e5a1a9</onfalse></stage><stage stageid="747911ef-b259-4635-9612-bec742e5a1a9" name="Note10" type="Note"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative>Must be Start</narrative><displayx>945</displayx><displayy>330</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="0000FF" /><onsuccess>85238a94-3ed6-4820-9b75-3f432e89e4e2</onsuccess></stage><stage stageid="3ed383a9-f773-4fb0-a2e8-08dd049adcf9" name="Exit?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>735</displayx><displayy>435</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><decision expression="Trim(Upper([G_Vision+ Control]))=&quot;EXIT&quot;" /><ontrue>5902aa7d-86ec-46e5-8a9e-fe89389b66cc</ontrue><onfalse>b185585f-8c3f-4e4f-839e-f2c5042b0422</onfalse></stage><stage stageid="5902aa7d-86ec-46e5-8a9e-fe89389b66cc" name="anchor22" type="Anchor"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>735</displayx><displayy>525</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>9b9a36e2-303d-4850-8ff7-1b814c9ee9f2</onsuccess></stage><stage stageid="9b893bc3-239d-4676-acb8-b6bfc0068fbc" name="anchor27" type="Anchor"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>495</displayx><displayy>255</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>7f4724ad-e9f3-4212-af87-a884d55630eb</onsuccess></stage><stage stageid="89132137-0864-419d-9220-9f415c3d2ed0" name="Maintain" type="Block"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>375</displayy><displaywidth>210</displaywidth><displayheight>105</displayheight><font family="Tahoma" size="10" style="Regular" color="808080" /></stage><stage stageid="2a23316f-b604-4ad1-adfe-2e1a1aea73ce" name="End7" type="End"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>600</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /></stage><stage stageid="555ca3f4-951a-4efd-95df-07873dff1d72" name="Reset COMMAND" type="Calculation"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>150</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><onsuccess>81da0f73-8a3b-4daf-9e84-9e92062d358e</onsuccess><calculation expression="&quot;&quot;" stage="G_IBC Control" /></stage><stage stageid="9b9a36e2-303d-4850-8ff7-1b814c9ee9f2" name="Reset COMMAND" type="Calculation"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>525</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><onsuccess>2a23316f-b604-4ad1-adfe-2e1a1aea73ce</onsuccess><calculation expression="&quot;&quot;" stage="G_Vision+ Control" /></stage><stage stageid="bf9e7f6a-815c-4dcf-8d66-b34b5902b724" name="Local Variables" type="Block"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>-285</displayx><displayy>-45</displayy><displaywidth>180</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="ed7fb169-db0d-4205-812b-9b268ab92ab5" name="Anchor1" type="Anchor"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>495</displayx><displayy>60</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>0d6968de-c251-4268-ac3f-f8e67dcf04a1</onsuccess></stage><stage stageid="3108d7a8-f2c8-4708-9964-29d0e42500d5" name="Anchor2" type="Anchor"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>495</displayx><displayy>435</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>44d1ebf5-1636-4f11-a4bb-119c3b568ec3</onsuccess></stage><stage stageid="29a7076f-7967-432b-b470-ed9328577df8" name="1.1.3 Maintain IBC" type="SubSheet"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>555ca3f4-951a-4efd-95df-07873dff1d72</onsuccess><processid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</processid></stage><stage stageid="760e9048-e410-4d8a-9637-2622786cc02f" name="1.1.4 Maintain Vision+" type="SubSheet"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>435</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>9b9a36e2-303d-4850-8ff7-1b814c9ee9f2</onsuccess><processid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</processid></stage><stage stageid="ead2f9b9-cf88-4d1e-8bb0-e4dcd71dd064" name="Password" type="Data"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative>System password</narrative><displayx>-195</displayx><displayy>45</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>password</datatype><initialvalueenc></initialvalueenc><private /><alwaysinit /></stage><stage stageid="285f2442-6cae-40ec-b4ee-76a0dd1994e6" name="Username" type="Data"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative>System username</narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="c81f532e-6abd-4306-8f16-7beba1fff6af" name="Expiry Date" type="Data"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative>Credential expiry date</narrative><displayx>-195</displayx><displayy>105</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>date</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="33eaa6bb-291f-4839-b9a9-b5c367178fa1" name="Status" type="Data"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative>Credential status</narrative><displayx>-195</displayx><displayy>75</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="fb98f22e-58b6-46f3-8182-dbd042799200" name="Authentication" type="Block"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>210</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="d8540e8d-43f2-47bb-8e2c-d7ffa8acc414" name="Credential name" type="Data"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative>Name of the credential in BP</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="9fd5be17-a384-4ec2-994a-4b1b78c950fc" name="Get Credentials" type="Action"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Credentials Name" narrative="The name of the credentials to get" expr="[Credential name]" /></inputs><outputs><output type="password" name="Password" narrative="The password" stage="Password" /><output type="text" name="Username" narrative="The user name" stage="Username" /><output type="date" name="Expiry Date" narrative="The expiry date" stage="Expiry Date" /><output type="text" name="Status" narrative="The status" stage="Status" /></outputs><onsuccess>0e6f7dae-5d95-40b1-ad5b-75112ce609ac</onsuccess><resource object="Blueprism.Automate.clsCredentialsActions" action="Get" /></stage><stage stageid="0e6f7dae-5d95-40b1-ad5b-75112ce609ac" name="Credential valid?" type="Decision"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Status]=&quot;Valid&quot;" /><ontrue>eb46e137-fc8e-450f-bf94-c9d519d0c784</ontrue><onfalse>ebf0206c-7c78-4123-b925-9113d3d3ec44</onfalse></stage><stage stageid="ebf0206c-7c78-4123-b925-9113d3d3ec44" name="SE - Invalid credential" type="Exception"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>105</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="System Exception" detail="&quot;The credential '&quot; &amp;[Credential name]&amp;&quot;' is marked as invalid&quot;" /></stage><stage stageid="6d7ac860-ed4c-414a-a79f-b4a2687937e3" name="Set IBC credential name" type="Calculation"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-75</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>9fd5be17-a384-4ec2-994a-4b1b78c950fc</onsuccess><calculation expression="&quot;COE-IBC-&quot;&amp;Left(GetResourceName(),8)" stage="Credential name" /></stage><stage stageid="eb46e137-fc8e-450f-bf94-c9d519d0c784" name="Launch IBC" type="Action"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>be5da094-c460-4e2f-94d5-ff84ae19a0bb</onsuccess><resource object="COE-IBC-Basic Actions" action="Launch" /></stage><stage stageid="1ebd1f8c-5aaa-441f-855d-0276359a345c" name="Login to IBC" type="Action"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>240</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Brand" expr="&quot;Lloyds Banking Group&quot;" /><input type="text" name="User ID" expr="[Username]" /><input type="password" name="Password" expr="[Password]" /></inputs><outputs><output type="flag" name="Already Logged In" stage="" /></outputs><onsuccess>a22afe3b-d69d-4741-9d73-56bde54581d6</onsuccess><resource object="COE-IBC-Basic Actions" action="Login" /></stage><stage stageid="2d086ffd-5477-4da0-a239-2aadcb381b3e" name="ReThrow" type="Exception"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>285</displayx><displayy>240</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="" detail="" usecurrent="yes" /></stage><stage stageid="6aa93053-2202-4589-bdde-45b671fc2042" name="Recover" type="Recover"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>240</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b900b3d8-b655-4e0a-9a2e-91511abacd72</onsuccess></stage><stage stageid="5ff8b0bb-cc6a-462e-9d35-ac7a274fcec3" name="Login" type="Block"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>-45</displayx><displayy>210</displayy><displaywidth>180</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="a22afe3b-d69d-4741-9d73-56bde54581d6" name="End" type="End"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>315</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="43d18aca-a1dc-497a-883c-acc2d89f2027" name="Retry Count" type="Data"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative>Login count</narrative><displayx>-195</displayx><displayy>135</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>1</initialvalue><private /><alwaysinit /></stage><stage stageid="b900b3d8-b655-4e0a-9a2e-91511abacd72" name="Retry Login?" type="Decision"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>240</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Retry Count]&lt;3" /><ontrue>1dbb4c17-9455-4c79-8960-3b912d5acd7a</ontrue><onfalse>2d086ffd-5477-4da0-a239-2aadcb381b3e</onfalse></stage><stage stageid="1dbb4c17-9455-4c79-8960-3b912d5acd7a" name="Increase Retry Count" type="Calculation"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>76f16fe9-1800-4866-9834-252e14583804</onsuccess><calculation expression="[Retry Count]+1" stage="Retry Count" /></stage><stage stageid="be5da094-c460-4e2f-94d5-ff84ae19a0bb" name="Anchor3" type="Anchor"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>165</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>1ebd1f8c-5aaa-441f-855d-0276359a345c</onsuccess></stage><stage stageid="a2e1ceeb-ee7c-4856-aa3e-65f4a3359f0b" name="Launch PCOMM" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-75</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Session File Path" narrative="The full path of the required session file" expr="&quot;C:\Program Files (x86)\IBM\Personal Communications\private\zSeries PCOM Session files\VisionPlus\Visionplus.ws&quot;" /></inputs><onsuccess>ae6ec7a6-fb99-4d44-a6ad-d21e191e1889</onsuccess><resource object="COE - PCOMM - Vision Plus" action="Launch" /></stage><stage stageid="7f957549-7eb2-4994-8e6a-b155ed4e52b7" name="Process already exists" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative>Flag on whether process already exists</narrative><displayx>-195</displayx><displayy>135</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="771b3f24-e553-4886-927c-4c6d86cde10e" name="End9" type="End"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>885</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="9ceb5003-fbeb-4f9a-9452-1a43dba80027" name="Get Credentials" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>480</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Credentials Name" narrative="The name of the credentials to get" expr="[Credential name]" /></inputs><outputs><output type="password" name="Password" narrative="The password" stage="Password" /><output type="text" name="Username" narrative="The user name" stage="Username" /><output type="date" name="Expiry Date" narrative="The expiry date" stage="Expiry Date" /><output type="text" name="Status" narrative="The status" stage="Status" /></outputs><onsuccess>fa8008d8-a16c-44ba-bde3-d74b98a37036</onsuccess><resource object="Blueprism.Automate.clsCredentialsActions" action="Get" /></stage><stage stageid="fa8008d8-a16c-44ba-bde3-d74b98a37036" name="Credential valid?" type="Decision"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>540</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Status]=&quot;Valid&quot;" /><ontrue>1084c719-77ab-4331-8bb3-f7717cc1bdca</ontrue><onfalse>17fc0995-b01c-43c9-bbd7-217f6fa08777</onfalse></stage><stage stageid="17fc0995-b01c-43c9-bbd7-217f6fa08777" name="SE - Invalid credential" type="Exception"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>540</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="System Exception" detail="&quot;The credential '&quot; &amp;[Credential name]&amp;&quot;' is marked as invalid&quot;" /></stage><stage stageid="142e82bf-52e6-441e-81d0-987919e4c3a9" name="Local Variables" type="Block"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>270</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="1d2fe131-bde1-4825-95cd-9a22c6d0cc0f" name="Set Reflection credential name" type="Calculation"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>420</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>9ceb5003-fbeb-4f9a-9452-1a43dba80027</onsuccess><calculation expression="&quot;COE-Vision+-&quot;&amp;Left(GetResourceName(),8)" stage="Credential name" /></stage><stage stageid="811ad0aa-f1e4-4f42-96db-c24f7ec84bb4" name="On WSWE" type="Decision"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>840</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Screen Name] = &quot;WSWE&quot;" /><ontrue>771b3f24-e553-4886-927c-4c6d86cde10e</ontrue><onfalse>8c627ca7-9abe-4411-b227-4e96de65840c</onfalse></stage><stage stageid="8c627ca7-9abe-4411-b227-4e96de65840c" name="SE - Unable to locate WSWE" type="Exception"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>840</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="System Exception" detail="&quot;Unable to locate WSWE&quot;" /></stage><stage stageid="5b6ce99c-110d-4b05-83f7-cf3349737df0" name="E_COE - Vision+ - Session File" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative>Filepath of the the required session file</narrative><displayx>-195</displayx><displayy>270</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><exposure>Environment</exposure><private /><alwaysinit /></stage><stage stageid="20c712a8-8bcf-4ac6-9a4b-ed7b627555da" name="Environment Variable" type="Block"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>240</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="CCFFCC" /></stage><stage stageid="112626ae-e6b4-4d22-9da4-f96642e2c39f" name="End" type="End"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>345</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="0bc4ea16-14d6-4bab-8b36-db77ea3208a8" name="Logout of IBC" type="Action"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>d54feca8-a15e-4175-a3ca-ec22ec3d63f7</onsuccess><resource object="COE-IBC-Basic Actions" action="Logoff" /></stage><stage stageid="f04ccb6f-9377-4649-8c0a-246829eabe32" name="Block" type="Block"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>-15</displayx><displayy>30</displayy><displaywidth>195</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="d54feca8-a15e-4175-a3ca-ec22ec3d63f7" name="Terminate IBC" type="Action"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>150</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>424804e8-e6b3-435c-9118-3d3077a6afc2</onsuccess><resource object="COE-IBC-Basic Actions" action="Terminate" /></stage><stage stageid="0857a6b0-5f33-4a60-93e7-dba5a9876527" name="Recover" type="Recover"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>fedf683a-c224-4a54-8c4c-9877ba6d92a1</onsuccess></stage><stage stageid="fedf683a-c224-4a54-8c4c-9877ba6d92a1" name="Resume" type="Resume"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>150</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>d54feca8-a15e-4175-a3ca-ec22ec3d63f7</onsuccess></stage><stage stageid="e4ca8b72-277b-4c05-bf23-c941dcc49a4d" name="Block" type="Block"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>-120</displayx><displayy>120</displayy><displaywidth>195</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="424804e8-e6b3-435c-9118-3d3077a6afc2" name="Process Exists (IBC)" type="Action"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>225</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Process Name" narrative="The name of the process" expr="&quot;iexplore&quot;" /></inputs><outputs><output type="flag" name="Exists" narrative="True if the process exists" stage="Process Exists" /></outputs><onsuccess>4b0f3664-210b-428f-838d-c864dbb719bc</onsuccess><resource object="Utility - General" action="Process Exists" /></stage><stage stageid="db78f947-f567-490a-abe3-f0ebd76c1d42" name="Process Exists" type="Data"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative>Whether process already exists</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue>True</initialvalue><private /><alwaysinit /></stage><stage stageid="87d1bd05-b64c-4a65-b16b-0cca5eb89cc9" name="Recover" type="Recover"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>-60</displayx><displayy>150</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>75e9e870-0975-4b8f-8a50-644c8a9a2da6</onsuccess></stage><stage stageid="75e9e870-0975-4b8f-8a50-644c8a9a2da6" name="Resume" type="Resume"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>-60</displayx><displayy>225</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>424804e8-e6b3-435c-9118-3d3077a6afc2</onsuccess></stage><stage stageid="4b251ea6-0fd5-468f-9e92-5f79ab4d00be" name="Variables" type="Block"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="4b0f3664-210b-428f-838d-c864dbb719bc" name="Process exists?" type="Decision"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>285</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Process Exists]" /><ontrue>d8948fa7-4bca-4564-9306-da38f8c8fa50</ontrue><onfalse>112626ae-e6b4-4d22-9da4-f96642e2c39f</onfalse></stage><stage stageid="d8948fa7-4bca-4564-9306-da38f8c8fa50" name="Kill process" type="Action"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>285</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Process Name" narrative="The name of the process to kill" expr="&quot;iexplore&quot;" /></inputs><onsuccess>ba8bce05-a3e2-44f4-b7c3-d552681e058d</onsuccess><resource object="Utility - Environment" action="Kill Process" /></stage><stage stageid="ba8bce05-a3e2-44f4-b7c3-d552681e058d" name="Anchor11" type="Anchor"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>345</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>112626ae-e6b4-4d22-9da4-f96642e2c39f</onsuccess></stage><stage stageid="258f4cd5-4ac3-4c9d-88eb-6fddfba6b57a" name="Process Exists (IBC)" type="Action"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Process Name" narrative="The name of the process" expr="&quot;iexplore&quot;" /></inputs><outputs><output type="flag" name="Exists" narrative="True if the process exists" stage="Process Exists" /></outputs><onsuccess>8d39b21f-cb06-4aad-bd25-e21237befbde</onsuccess><resource object="Utility - General" action="Process Exists" /></stage><stage stageid="8d39b21f-cb06-4aad-bd25-e21237befbde" name="Process exists?" type="Decision"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Process Exists]" /><ontrue>0bc4ea16-14d6-4bab-8b36-db77ea3208a8</ontrue><onfalse>2a35ab0e-83fa-4710-96ca-b65bda83e9f9</onfalse></stage><stage stageid="2a35ab0e-83fa-4710-96ca-b65bda83e9f9" name="End" type="End"><subsheetid>68d93676-eb08-48bb-be21-d51abf5c2e59</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="23759ea7-8f2f-453d-986f-b74c18308bc4" name="Start" type="Start"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><preconditions><condition narrative="Vision+ open" /></preconditions><postconditions><condition narrative="Vision+ closed" /></postconditions><narrative></narrative><displayx>0</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>af9608b3-8c16-424e-9c08-39cfd5b61a17</onsuccess></stage><stage stageid="d87701d0-900f-4f26-a281-fb10c29d327f" name="Process Exists" type="Data"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative>Flag on whether process exists</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue>False</initialvalue><private /><alwaysinit /></stage><stage stageid="06676cae-6721-4afe-9c38-4e0d0009ec59" name="Variables" type="Block"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="af9608b3-8c16-424e-9c08-39cfd5b61a17" name="Process Exists " type="Action"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-75</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Process Name" narrative="The name of the process" expr="&quot;pcsws&quot;" /></inputs><outputs><output type="flag" name="Exists" narrative="True if the process exists" stage="Process Exists" /></outputs><onsuccess>5121d180-c5e5-4484-b816-55a42f5359c8</onsuccess><resource object="Utility - General" action="Process Exists" /></stage><stage stageid="5121d180-c5e5-4484-b816-55a42f5359c8" name="Process Exists?" type="Decision"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Process Exists]" /><ontrue>933e4c88-562f-4125-922a-6ef82dafbdbc</ontrue><onfalse>dfb1b827-d733-4269-bfff-1725cd92df5b</onfalse></stage><stage stageid="dfb1b827-d733-4269-bfff-1725cd92df5b" name="End8" type="End"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>105</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="7b6b5ec6-0420-4312-9fb5-c187c6409a59" name="Block1" type="Block"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>-60</displayx><displayy>15</displayy><displaywidth>195</displaywidth><displayheight>180</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="b45905b0-9515-4804-bbdb-461fb3063384" name="Recover1" type="Recover"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>7f2e4940-27f2-49a7-876a-bb5fa3167cf4</onsuccess></stage><stage stageid="7f2e4940-27f2-49a7-876a-bb5fa3167cf4" name="Resume1" type="Resume"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>225</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>eaedce9e-dc16-4730-8850-660452a14a45</onsuccess></stage><stage stageid="eaedce9e-dc16-4730-8850-660452a14a45" name="End1" type="End"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>225</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="3ab2d860-0f55-42f4-a984-a8132d7453b0" name="Environment Variables" type="Block"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="CCFFCC" /></stage><stage stageid="a36943ca-9b26-4647-ac2b-b7aef65c653f" name="E_COE - SCA ACH - Control Notification" type="Data"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><exposure>Environment</exposure><private /><alwaysinit /></stage><stage stageid="66e365d4-5d79-47e1-bd32-b966a2a996c0" name="Environment Variables" type="Block"><subsheetid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="CCFFCC" /></stage><stage stageid="550cd4e7-50ae-47a6-8620-d5407ce58435" name="E_COE - SCA ACH - Outlook Profile" type="Data"><subsheetid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><exposure>Environment</exposure><private /><alwaysinit /></stage><stage stageid="5e1ced05-1fd4-4d58-b632-4539a10dcd0b" name="1. Start Up" type="SubSheet"><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-75</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>90124908-5028-49fe-b89e-0d4d96959df1</onsuccess><processid>68ad4f62-d0ab-4106-a72b-6a79fef7e4cb</processid></stage><stage stageid="90124908-5028-49fe-b89e-0d4d96959df1" name="Load Queue" type="Process"><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>0</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Number of Files to Load" narrative="Number of files to load (will load ALL files by default if left blank)" expr="99999" /></inputs><onsuccess>6d37d945-7503-4b6f-9802-8e61b14a17db</onsuccess><processid>d03e35ba-31ad-4df5-87ee-3123242979a0</processid></stage><stage stageid="6d37d945-7503-4b6f-9802-8e61b14a17db" name="Get next item" type="Action"><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Queue Name" narrative="The name of the queue" expr="[G_Queue Name]" /><input type="text" name="Key Filter" narrative="Optionally, a key value to filter by. Only items with this key value will be considered." expr="" /><input type="text" name="Tag Filter" narrative="Optionally, a tag mask to filter by. This can consist of any number of tag searches - each term can be separated by a semi-colon and they are all applied to the search (ie. they are AND'ed terms not OR'ed terms). For example, &quot;Account: Joint; -Balance: Overdrawn; Card: *Visa*&quot; will include any items which match all the terms, ie. every item must have an 'Account: Joint' tag applied, no item can have a 'Balance: Overdrawn' tag applied, every item must have a tag applied which starts with 'Card: ' and then contains the text 'Visa'." expr="" /></inputs><outputs><output type="text" name="Item ID" narrative="The ID of the item retrieved - empty if there are none available." stage="G_Item ID" /><output type="collection" name="Data" narrative="The data associated with the item - a single collection row." stage="G_Item Data" /><output type="text" name="Status" narrative="The status of the item." stage="G_Item Status" /><output type="number" name="Attempts" narrative="The number of attempts already made to work this item." stage="G_Item Attempts" /></outputs><onsuccess>b85e7e54-a1d0-455b-8729-48f362259df9</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Get Next Item" /></stage><stage stageid="b85e7e54-a1d0-455b-8729-48f362259df9" name="Got item?" type="Decision"><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[G_Item ID]&lt;&gt;&quot;&quot;" /><ontrue>f5834995-e47d-4078-bc45-2880e36f8592</ontrue><onfalse>b4a207ca-029f-43ff-9fdb-2de46cb50f8c</onfalse></stage><stage stageid="7094c6be-13ff-46f6-aa71-4077e70bd65e" name="3. Validate Mobile Number" type="SubSheetInfo"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative>Validates that the telephone number from the Global Data Item is in a valid format</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="cecb01b9-7722-4a9c-84ad-34cfe84158b1" name="3. Validate Mobile Number" type="SubSheet"><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>3c2f0bc0-2052-45e5-af32-94d00df06911</onsuccess><processid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</processid></stage><stage stageid="a826a628-3c9c-459a-bc7e-726b5fe4f02b" name="4. Retrieve OCIS ID" type="SubSheetInfo"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative>Utilises IBC to locate a customer and return their OCIS Master ID. Will retry a maximum of 3 times if there are any issues.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="af85652d-6a9f-4965-a131-adeb6a4bffd9" name="Start" type="Start"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>-15</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>69ff83ba-806d-49a8-b296-51ab50d50e00</onsuccess></stage><stage stageid="3c2f0bc0-2052-45e5-af32-94d00df06911" name="4. Retrieve OCIS ID" type="SubSheet"><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>315</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>e7e2df1b-6876-46ef-a763-c1b8b3a3d829</onsuccess><processid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</processid></stage><stage stageid="6c0eda71-9717-46fd-badb-c72b68ab8081" name="5. Vision+ Search &amp; Update" type="SubSheetInfo"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Searches for the required customer and returns all relevant search results.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="e7e2df1b-6876-46ef-a763-c1b8b3a3d829" name="5. Vision+ Search &amp; Update" type="SubSheet"><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>95ebb4ab-3a35-43a4-be34-9f8d11c42ec1</onsuccess><processid>cac99af1-dcbf-48bd-b310-e90a5e99917d</processid></stage><stage stageid="55893b51-7867-4ecf-99e6-0f69250f6ff1" name="Block2" type="Block"><loginhibit /><narrative></narrative><displayx>150</displayx><displayy>90</displayy><displaywidth>120</displaywidth><displayheight>435</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="40308a97-9eec-412b-b8cd-59e70a661c5e" name="Recover2" type="Recover"><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>495</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>f6441b58-11db-4199-b043-94e342908bd9</onsuccess></stage><stage stageid="f6441b58-11db-4199-b043-94e342908bd9" name="Save exception data" type="MultipleCalculation"><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>570</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>58537ccd-96ff-424f-b6db-c36546588465</onsuccess><steps><calculation expression="ExceptionType()" stage="G_Exception Type" /><calculation expression="ExceptionDetail()" stage="G_Exception Detail" /></steps></stage><stage stageid="58537ccd-96ff-424f-b6db-c36546588465" name="Resume2" type="Resume"><loginhibit /><narrative></narrative><displayx>480</displayx><displayy>570</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>10fc3053-afc7-4d8a-8fa1-3a428f89e49b</onsuccess></stage><stage stageid="10fc3053-afc7-4d8a-8fa1-3a428f89e49b" name="7. Mark Item as Exception" type="SubSheet"><loginhibit /><narrative></narrative><displayx>480</displayx><displayy>495</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>080a8b47-b055-4474-a8b9-b9cb3c6ac073</onsuccess><processid>853c5533-4f26-4c01-976d-b19981861ac0</processid></stage><stage stageid="080a8b47-b055-4474-a8b9-b9cb3c6ac073" name="8. Reset Global Data" type="SubSheet"><loginhibit /><narrative></narrative><displayx>480</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>3672ed95-90b0-4eb2-be21-38c66662e0f3</onsuccess><processid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</processid></stage><stage stageid="3672ed95-90b0-4eb2-be21-38c66662e0f3" name="Count items" type="Calculation"><loginhibit /><narrative></narrative><displayx>585</displayx><displayy>405</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>196e3524-4655-4c62-a3ff-881b984be0c0</onsuccess><calculation expression="[G_Item Count] + 1" stage="G_Item Count" /></stage><stage stageid="5d357372-b1db-46a5-aecd-86dc1900fd2a" name="G_Item Count" type="Data"><loginhibit /><narrative>A count of worked items</narrative><displayx>-195</displayx><displayy>90</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="0000FF" /><datatype>number</datatype><initialvalue>0</initialvalue><alwaysinit /></stage><stage stageid="32d5da99-b3d0-47be-b432-046b5948e9cb" name="Stop requested?" type="Decision"><loginhibit /><narrative></narrative><displayx>690</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="IsStopRequested() OR [G_Item Count]&gt;= [S_Stop After Items] OR LocalTime()&gt;[S_Stop After Time]" /><ontrue>9881247a-acde-44f2-a839-09923d428747</ontrue><onfalse>782f47fb-13c5-47dd-8ca7-3130e70b224b</onfalse></stage><stage stageid="782f47fb-13c5-47dd-8ca7-3130e70b224b" name="1.1 Control Applications" type="SubSheet"><loginhibit /><narrative></narrative><displayx>570</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>c1fb4e8e-4d85-49ba-a621-6790d6e89a00</onsuccess><processid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</processid></stage><stage stageid="12144d88-6b75-48b1-bc67-850976994bee" name="Get next item" type="Action"><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Queue Name" narrative="The name of the queue" expr="[G_Queue Name]" /><input type="text" name="Key Filter" narrative="Optionally, a key value to filter by. Only items with this key value will be considered." expr="" /><input type="text" name="Tag Filter" narrative="Optionally, a tag mask to filter by. This can consist of any number of tag searches - each term can be separated by a semi-colon and they are all applied to the search (ie. they are AND'ed terms not OR'ed terms). For example, &quot;Account: Joint; -Balance: Overdrawn; Card: *Visa*&quot; will include any items which match all the terms, ie. every item must have an 'Account: Joint' tag applied, no item can have a 'Balance: Overdrawn' tag applied, every item must have a tag applied which starts with 'Card: ' and then contains the text 'Visa'." expr="" /></inputs><outputs><output type="text" name="Item ID" narrative="The ID of the item retrieved - empty if there are none available." stage="G_Item ID" /><output type="collection" name="Data" narrative="The data associated with the item - a single collection row." stage="G_Item Data" /><output type="text" name="Status" narrative="The status of the item." stage="G_Item Status" /><output type="number" name="Attempts" narrative="The number of attempts already made to work this item." stage="G_Item Attempts" /></outputs><onsuccess>b85e7e54-a1d0-455b-8729-48f362259df9</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Get Next Item" /></stage><stage stageid="c1cdafc6-c376-4120-bf76-42f715c0b012" name="Session Report" type="Process"><loginhibit /><narrative></narrative><displayx>690</displayx><displayy>-135</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="datetime" name="Reporting From" narrative="Datetime of when to start the reporting period" expr="[Start Time]" /><input type="datetime" name="Reporting To" narrative="Datetime of when to cease the reporting period" expr="[End Time]" /><input type="flag" name="Summary Report" narrative="Flag on whether a high level metric report should be produced" expr="False" /><input type="flag" name="Detailed Report" narrative="Flag on whether a detailed exception report should be produced" expr="True" /></inputs><onsuccess>cfd98111-c426-4ca8-97a9-89e6ba14c8e9</onsuccess><processid>fbcb809d-0117-44df-a59c-240116b9199e</processid></stage><stage stageid="bff0abd0-066f-443e-bd2c-a8d3b4641bb3" name="9. Close Down" type="SubSheetInfo"><subsheetid>c2e2ca54-d379-4238-8b26-f7afd958d4f6</subsheetid><loginhibit /><narrative>Closes all applications.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="4e51c1d6-4092-4793-afaf-842c9eb65305" name="Start" type="Start"><subsheetid>c2e2ca54-d379-4238-8b26-f7afd958d4f6</subsheetid><loginhibit /><preconditions><condition narrative="Applications Open" /></preconditions><postconditions><condition narrative="Applications Closed" /></postconditions><narrative></narrative><displayx>-30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>bf869d37-af4e-48e4-b383-8dc3b0c92979</onsuccess></stage><stage stageid="1b047ed8-0c3b-4741-8aa3-d786b64321d9" name="End" type="End"><subsheetid>c2e2ca54-d379-4238-8b26-f7afd958d4f6</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="bf869d37-af4e-48e4-b383-8dc3b0c92979" name="EXIT All" type="MultipleCalculation"><subsheetid>c2e2ca54-d379-4238-8b26-f7afd958d4f6</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><onsuccess>bc0e09ba-d9ec-4eff-9ee0-487fbcc2c9cc</onsuccess><steps><calculation expression="&quot;EXIT&quot;" stage="G_IBC Control" /><calculation expression="&quot;EXIT&quot;" stage="G_Vision+ Control" /></steps></stage><stage stageid="bc0e09ba-d9ec-4eff-9ee0-487fbcc2c9cc" name="1.1 Control Applications" type="SubSheet"><subsheetid>c2e2ca54-d379-4238-8b26-f7afd958d4f6</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>30</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>1b047ed8-0c3b-4741-8aa3-d786b64321d9</onsuccess><processid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</processid></stage><stage stageid="9881247a-acde-44f2-a839-09923d428747" name="9. Close Down" type="SubSheet"><loginhibit /><narrative></narrative><displayx>690</displayx><displayy>0</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b31bd38b-d064-4683-9ca9-5f556f1988bf</onsuccess><processid>c2e2ca54-d379-4238-8b26-f7afd958d4f6</processid></stage><stage stageid="0f02fa38-9fa8-4830-ae98-1a0c5077ad95" name="Start" type="Start"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>-30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>5b5fd74c-d65b-4ad0-bd1b-248bdd43734e</onsuccess></stage><stage stageid="d7a3fc28-1e63-412d-9463-7441ac7e9400" name="Variables" type="Block"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="c386fb20-5c07-420e-b34e-dfd3a8c38933" name="Formatted Phone Number" type="Data"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative>Post Regex telephone number</narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="70902221-9591-4ff2-9dce-41591f1cccf8" name="Match" type="Data"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative>Flag on whether telephone matches</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue>False</initialvalue><private /><alwaysinit /></stage><stage stageid="b81af524-5f11-4a3b-8994-cac868e1de87" name="End" type="End"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>375</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="264ab691-39d4-4633-b5dc-b2027d4bf6bb" name="Test Mobile Number" type="Action"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Regex Pattern" narrative="The regex pattern to apply" expr="&quot;^\+?(44)?\(?0?\)?7\d{9}&quot;" /><input type="text" name="Target String" narrative="The target string to which apply the pattern and extract values" expr="[G_Loop Data.Mobile Number]" /></inputs><outputs><output type="flag" name="Matched?" narrative="Whether or not the regex match" stage="Match" /></outputs><onsuccess>ff8a05d8-b06b-4106-8a52-62452af8c43d</onsuccess><resource object="Utility - Strings" action="Test Regex Match" /></stage><stage stageid="ff8a05d8-b06b-4106-8a52-62452af8c43d" name="Match?" type="Decision"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Match]" /><ontrue>420f9735-3a22-42c9-896d-704f50ae8f33</ontrue><onfalse>a9ca8368-9082-4329-b23d-0e1c9241b4fa</onfalse></stage><stage stageid="fdf9d9a1-f795-41ee-857a-ee547038afbd" name="End" type="End"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>600</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="e31eadfc-bc0f-4d7a-be53-314ce1b40f3d" name="Search for customer" type="Action"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>195</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="User ID" expr="" /><input type="text" name="Internal ID" expr="[G_Item Data.INTERNAL_USER_ID]" /><input type="text" name="CID Persid on IB" expr="" /><input type="text" name="Spending Reward ID" expr="" /><input type="text" name="Sort code " expr="" /><input type="text" name="Account Number " expr="" /><input type="text" name="Card number " expr="" /><input type="text" name="Transaction Monitoring ID" expr="" /><input type="text" name="Loan Sort code " expr="" /><input type="text" name="Loan Account Number " expr="" /><input type="text" name="Loan Reference Number " expr="" /><input type="text" name="Mortgage Reference Number " expr="" /><input type="text" name="Brand Context" expr="[Brand]" /><input type="text" name="Channel Context" expr="" /></inputs><outputs><output type="flag" name="Multiple Customers Found" stage="Multiple Customers Found" /></outputs><onsuccess>70ada802-1ef5-42b2-93be-f2ba322ed1bf</onsuccess><resource object="COE-IBC-Search Customers" action="Search Customer" /></stage><stage stageid="b78c07ec-7cec-4df7-a6d3-7ad504377b7a" name="Recover" type="Recover"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>255</displayx><displayy>195</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>f9d68a18-e8f7-4acb-ba04-7d6103ab4441</onsuccess></stage><stage stageid="6229a8d5-5f87-44e3-a4a8-eb8c2e441636" name="Blank OCIS Master CID Persid?" type="Decision"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>420</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len(Trim([G_OCIS Master CID Persid])) = 0" /><ontrue>852c935f-7cc9-4846-bf3b-dd1ecf6aa382</ontrue><onfalse>c65d183b-8b28-4b4e-a34b-104802b25862</onfalse></stage><stage stageid="852c935f-7cc9-4846-bf3b-dd1ecf6aa382" name="BE - OCIS Master CID is unavailable" type="Exception"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>255</displayx><displayy>420</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="Business Exception" detail="&quot;OCIS Master CID is unavailable.&quot;" /></stage><stage stageid="168e262a-450f-4c44-9c46-cf3d54aaaf47" name="Search For Customer" type="Block"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>165</displayy><displaywidth>225</displaywidth><displayheight>150</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="0eba01b9-641e-458c-a8b0-178955ed655a" name="Rethrow" type="Exception"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>465</displayx><displayy>195</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="" detail="" usecurrent="yes" /></stage><stage stageid="dd098e59-b322-4e23-8a50-0a2c8409e103" name="Increase Retry Count" type="Calculation"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>c0d3c904-8d8d-46a1-9ed5-f58fde535245</onsuccess><calculation expression="[Retry Count] + 1" stage="Retry Count" /></stage><stage stageid="58d6e9a3-1a2d-40c6-a7b4-9eb403c31ad8" name="Brand" type="Data"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative>Input brand</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="69ff83ba-806d-49a8-b296-51ab50d50e00" name="Set Brand and Channel" type="ChoiceStart"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>-15</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><groupid>8b4eba85-17af-4b70-8550-2743a669395a</groupid><choices><choice expression="[G_Item Data.BRAND] = &quot;LLOYDS&quot;"><name>Lloyds TSB</name><distance>45</distance><ontrue>ada3264a-3191-42eb-9c36-f3978fce2f9b</ontrue></choice><choice expression="[G_Item Data.BRAND] = &quot;BOS&quot;"><name>Bank of Scotland</name><distance>90</distance><ontrue>c113ec5c-9cf5-4d65-85a8-cce8ff158ea3</ontrue></choice><choice expression="[G_Item Data.BRAND] = &quot;HALIFAX&quot;"><name>Halifax</name><distance>135</distance><ontrue>fa596ef1-4b58-4740-b52e-5a2b3b47371a</ontrue></choice><choice expression="[G_Item Data.BRAND] = &quot;MBNA&quot;"><name>MBNA</name><distance>180</distance><ontrue>399955a9-f35f-482d-9d44-eeb96b51c0bb</ontrue></choice></choices></stage><stage stageid="e8e73584-868a-4b9d-b624-90c6a636392f" name="Otherwise" type="ChoiceEnd"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>-15</displayx><displayy>150</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>65725a7d-49d6-4904-84ba-13eb2ff8859a</onsuccess><groupid>8b4eba85-17af-4b70-8550-2743a669395a</groupid></stage><stage stageid="6827f1d8-965e-4eb6-8533-99326e81ebb5" name="Anchor24" type="Anchor"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>-30</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>df510ac8-c57a-4886-8a24-88288218e1b0</onsuccess></stage><stage stageid="df510ac8-c57a-4886-8a24-88288218e1b0" name="Anchor27" type="Anchor"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>15</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>c4ff7fb1-0750-4dcc-a492-e7a7e2365b49</onsuccess></stage><stage stageid="c4ff7fb1-0750-4dcc-a492-e7a7e2365b49" name="Anchor28" type="Anchor"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>60</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>7af6f220-20c2-4fc6-bcb0-f426c22447e8</onsuccess></stage><stage stageid="7af6f220-20c2-4fc6-bcb0-f426c22447e8" name="Anchor29" type="Anchor"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>105</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>e31eadfc-bc0f-4d7a-be53-314ce1b40f3d</onsuccess></stage><stage stageid="65725a7d-49d6-4904-84ba-13eb2ff8859a" name="BE - Unrecognised brand" type="Exception"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>-15</displayx><displayy>195</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="Business Exception" detail="&quot;Unrecognised brand.&quot;" /></stage><stage stageid="18fa37ba-5cc0-434a-a6b8-49f5da253d33" name="Local Variables" type="Block"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>150</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="c0d3c904-8d8d-46a1-9ed5-f58fde535245" name="Session timed out." type="Decision"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="InStr(ExceptionDetail(), &quot;timed out&quot;) &gt; 0" /><ontrue>2dc051cb-4b74-4bb2-97a5-02047eb32e04</ontrue><onfalse>41df6cf8-f90c-4830-8e27-be13978c87de</onfalse></stage><stage stageid="41df6cf8-f90c-4830-8e27-be13978c87de" name="Resume1" type="Resume"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>4dfa4420-905d-466b-b4e8-8d53eb5dd5cb</onsuccess></stage><stage stageid="c9b35a35-8d49-475d-a937-6641f7f2e29a" name="1.1.5 Exit IBC" type="SubSheet"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>450</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b7b9474f-7540-4235-9d1d-3c2a40748287</onsuccess><processid>68d93676-eb08-48bb-be21-d51abf5c2e59</processid></stage><stage stageid="b7b9474f-7540-4235-9d1d-3c2a40748287" name="1.1 Launch IBC" type="SubSheet"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>450</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>4dfa4420-905d-466b-b4e8-8d53eb5dd5cb</onsuccess><processid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</processid></stage><stage stageid="aee7cf0a-e4cf-4e56-8690-277399340ac6" name="Multiple Customers Found" type="Data"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative>Flag to whether multiple customers found in search</narrative><displayx>-195</displayx><displayy>45</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="30fe1753-c8d2-46c5-a3a4-1ae38fbfce3b" name="Select Channel" type="Action"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>255</displayx><displayy>240</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Surname" expr="" /><input type="text" name="First name" expr="" /><input type="text" name="Date of birth" expr="" /><input type="text" name="Channel" expr="[Channel]" /></inputs><onsuccess>8341645d-fa48-417c-bffb-9a7bfc50262c</onsuccess><resource object="COE-IBC-Search Customers" action="Select Customer from Browse Customers Table" /></stage><stage stageid="30e6d2e5-56eb-4973-947b-30e5623f2223" name="Channel" type="Data"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative>Input channel</narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="70ada802-1ef5-42b2-93be-f2ba322ed1bf" name="Mutiple Customers Found" type="Decision"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>240</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Multiple Customers Found]" /><ontrue>30fe1753-c8d2-46c5-a3a4-1ae38fbfce3b</ontrue><onfalse>b4017c6f-1401-4797-80df-bad30a77ebdf</onfalse></stage><stage stageid="b4017c6f-1401-4797-80df-bad30a77ebdf" name="Get Details customer" type="Action"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>285</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><outputs><output type="text" name="Customer Status" stage="" /><output type="text" name="Internal User Id" stage="" /><output type="text" name="Password Status" stage="" /><output type="text" name="Transaction Monitoring ID" stage="" /><output type="text" name="Surname " stage="" /><output type="text" name="First names " stage="" /><output type="text" name="Other names" stage="" /><output type="text" name="DOB" stage="" /><output type="text" name="CID Persid on IB" stage="" /><output type="text" name="OCIS Id" stage="" /><output type="text" name="OCIS Master CID Persid" stage="G_OCIS Master CID Persid" /><output type="text" name="Home Tel No" stage="" /><output type="text" name="Work Tel No" stage="" /><output type="text" name="Mobile Tel No" stage="" /></outputs><onsuccess>de43a263-81e3-41ef-a894-e4a47aa21672</onsuccess><resource object="COE-IBC-Search Customers" action="Read Customer Details" /></stage><stage stageid="8341645d-fa48-417c-bffb-9a7bfc50262c" name="Anchor9" type="Anchor"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>255</displayx><displayy>285</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b4017c6f-1401-4797-80df-bad30a77ebdf</onsuccess></stage><stage stageid="ada3264a-3191-42eb-9c36-f3978fce2f9b" name="Lloyds" type="MultipleCalculation"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>-30</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>6827f1d8-965e-4eb6-8533-99326e81ebb5</onsuccess><steps><calculation expression="&quot;Lloyds TSB&quot;" stage="Brand" /><calculation expression="&quot;&quot;" stage="Channel" /></steps></stage><stage stageid="c113ec5c-9cf5-4d65-85a8-cce8ff158ea3" name="Bank of Scotland" type="MultipleCalculation"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>df510ac8-c57a-4886-8a24-88288218e1b0</onsuccess><steps><calculation expression="&quot;Bank of Scotland&quot;" stage="Brand" /><calculation expression="&quot;Bank of Scotland Retail&quot;" stage="Channel" /></steps></stage><stage stageid="fa596ef1-4b58-4740-b52e-5a2b3b47371a" name="Halifax" type="MultipleCalculation"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>c4ff7fb1-0750-4dcc-a492-e7a7e2365b49</onsuccess><steps><calculation expression="&quot;Halifax&quot;" stage="Brand" /><calculation expression="&quot;&quot;" stage="Channel" /></steps></stage><stage stageid="399955a9-f35f-482d-9d44-eeb96b51c0bb" name="MBNA" type="MultipleCalculation"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>7af6f220-20c2-4fc6-bcb0-f426c22447e8</onsuccess><steps><calculation expression="&quot;MBNA&quot;" stage="Brand" /><calculation expression="&quot;&quot;" stage="Channel" /></steps></stage><stage stageid="ebf54ef6-e3a4-439a-b847-04cce568449e" name="Retry Count" type="Data"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative>Count of rety attempts</narrative><displayx>-195</displayx><displayy>75</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="f9d68a18-e8f7-4acb-ba04-7d6103ab4441" name="Retry?" type="Decision"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>195</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Retry Count]&lt;3" /><ontrue>dd098e59-b322-4e23-8a50-0a2c8409e103</ontrue><onfalse>0eba01b9-641e-458c-a8b0-178955ed655a</onfalse></stage><stage stageid="2dc051cb-4b74-4bb2-97a5-02047eb32e04" name="Resume1" type="Resume"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>450</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>c9b35a35-8d49-475d-a937-6641f7f2e29a</onsuccess></stage><stage stageid="4dfa4420-905d-466b-b4e8-8d53eb5dd5cb" name="Anchor5" type="Anchor"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>-75</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>69ff83ba-806d-49a8-b296-51ab50d50e00</onsuccess></stage><stage stageid="23a8a837-6390-4f5a-9958-c175bd5efb7d" name="Set Custom Status" type="SubSheetInfo"><subsheetid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</subsheetid><loginhibit /><narrative>This page uses an input 'I_Status Message' to update the current queue item status.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="d8c94444-2dc8-4d93-8efd-b96ff92dbd1b" name="Start" type="Start"><subsheetid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>-30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Status Message" stage="I_Status Message" /></inputs><onsuccess>36005ddf-2563-49d4-bb44-321f525c3929</onsuccess></stage><stage stageid="346f4ef5-486d-4039-8922-981b007295fe" name="End" type="End"><subsheetid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="8eaa1620-df4e-4f58-804f-1603819f5d4f" name="Input" type="Block"><subsheetid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="008000" /></stage><stage stageid="36005ddf-2563-49d4-bb44-321f525c3929" name="Update Queue Item Status" type="Action"><subsheetid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the item to mark" expr="[G_Item ID]" /><input type="text" name="Status" narrative="The new status - 255 characters maximum." expr="[I_Status Message]" /></inputs><onsuccess>346f4ef5-486d-4039-8922-981b007295fe</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Update Status" /></stage><stage stageid="417ef916-5f3a-44ae-9837-8dc61b021b8b" name="I_Status Message" type="Data"><subsheetid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</subsheetid><loginhibit /><narrative>Status to set</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="0cd0433a-fc8c-4d18-ac83-d23f0f1d2fce" name="Set Custom Status" type="SubSheet"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>315</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Status Message" expr="&quot;01 – Telephone Number Validated&quot;" /></inputs><onsuccess>b81af524-5f11-4a3b-8994-cac868e1de87</onsuccess><processid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</processid></stage><stage stageid="d992cfae-d6f4-4c11-a2ef-0ee547e47556" name="Set Custom Status" type="SubSheet"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>540</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Status Message" expr="&quot;02 – OCIS ID Retrieved&quot;" /></inputs><onsuccess>fdf9d9a1-f795-41ee-857a-ee547038afbd</onsuccess><processid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</processid></stage><stage stageid="efbe3ffa-fc65-4684-9c8a-ccab295c0cdd" name="Notify Termination Subject" type="Data"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative>Email subject</narrative><displayx>-195</displayx><displayy>90</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="29af97a9-6995-43d8-8a70-6ba5704ed31a" name="Notify Termination Message" type="Data"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative>Email message</narrative><displayx>-195</displayx><displayy>120</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="4f2af10d-7d82-49ad-9141-85df58977597" name="Notify Termination CC" type="Data"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative>CC email address</narrative><displayx>-195</displayx><displayy>60</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="fe9061c4-3e94-4a1b-b25d-141d6900bb11" name="Local Variables" type="Block"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>30</displayy><displaywidth>150</displaywidth><displayheight>120</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="3461ddcf-202b-4401-beea-fa74b1026d4c" name="Start" type="Start"><subsheetid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>-30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><inputs><input type="text" name="To" stage="Email Item Data.To" /><input type="text" name="CC" stage="Email Item Data.CC" /><input type="text" name="Subject" stage="Email Item Data.Subject" /><input type="text" name="Message" stage="Email Item Data.Message" /><input type="text" name="Attachments" stage="Email Item Data.Attachments" /><input type="text" name="Classification" stage="Email Item Data.Classification" /></inputs><onsuccess>b8fded96-ae11-4a4f-a0a1-79927a51d64e</onsuccess></stage><stage stageid="6cb3b2a0-9174-4bf0-9295-7bb948155e0d" name="Email Item Data" type="Collection"><subsheetid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</subsheetid><loginhibit /><narrative>Used to hold email message details</narrative><displayx>-195</displayx><displayy>60</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>collection</datatype><private /><alwaysinit /><collectioninfo><field name="To" type="text" /><field name="CC" type="text" /><field name="Subject" type="text" /><field name="Message" type="text" /><field name="Attachments" type="text" /><field name="Item Key" type="text" /><field name="Classification" type="text" /></collectioninfo><initialvalue><row><field name="To" type="text" value="" /><field name="CC" type="text" value="" /><field name="Subject" type="text" value="" /><field name="Message" type="text" value="" /><field name="Attachments" type="text" value="" /><field name="Item Key" type="text" value="" /><field name="Classification" type="text" value="" /></row></initialvalue></stage><stage stageid="31f40fe3-3ef6-46a6-b78b-cc199ec4479d" name="Local Variables" type="Block"><subsheetid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>30</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="b8fded96-ae11-4a4f-a0a1-79927a51d64e" name="Send Email" type="Action"><subsheetid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="To" narrative="Mandatory. Any alphanumeric value allowed. Single Recipient = &quot;Name1@emaill.com&quot;; Multi Recipient = &quot;Name1@emaill.com; Name2@email.com&quot;" expr="[Email Item Data.To]" /><input type="text" name="CC" narrative="Optional. Any alphanumeric value allowed. Single Recipient = &quot;Name1@emaill.com&quot;; Multi Recipient = &quot;Name1@emaill.com; Name2@email.com&quot;. Default blank" expr="[Email Item Data.CC]" /><input type="text" name="BCC" narrative="Optional. Any alphanumeric value allowed. Single Recipient = &quot;Name1@emaill.com&quot;; Multi Recipient = &quot;Name1@emaill.com; Name2@email.com&quot;. Default blank" expr="" /><input type="text" name="Subject" narrative="Optional. Any alphanumeric value allowed." expr="[Email Item Data.Subject]" /><input type="text" name="Message" narrative="Optional, HTML or plain text" expr="[Email Item Data.Message]" /><input type="text" name="Attachments" narrative="Optional, Comma-separated file paths. Default blank." expr="[Email Item Data.Attachments]" /><input type="text" name="AIP Classification" expr="[Email Item Data.Classification]" /></inputs><onsuccess>6524865e-2236-4885-bd30-83cc7a162218</onsuccess><resource object="COE Utility - MS Outlook with Classification" action="Send Email" /></stage><stage stageid="49be92c6-fb4d-473a-afa2-0500fa250909" name="Mark completed" type="Action"><subsheetid>6f6fb598-b7c6-4705-976b-14191d9d2bab</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the item to mark" expr="[G_Item ID]" /></inputs><onsuccess>215df87d-9b2e-4b65-a6e5-1f97015c4a73</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Mark Completed" /></stage><stage stageid="b341a65f-2a57-4b28-a6e6-326aa5ba1f5b" name="Set status to completed" type="Action"><subsheetid>6f6fb598-b7c6-4705-976b-14191d9d2bab</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the item to mark" expr="[G_Item ID]" /><input type="text" name="Status" narrative="The new status - 255 characters maximum." expr="&quot;99 - Case Completed&quot;" /></inputs><onsuccess>49be92c6-fb4d-473a-afa2-0500fa250909</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Update Status" /></stage><stage stageid="215df87d-9b2e-4b65-a6e5-1f97015c4a73" name="Reset consecutive exception count" type="Calculation"><subsheetid>6f6fb598-b7c6-4705-976b-14191d9d2bab</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>005bf533-99cb-4f76-950e-3fd6ac0ab65e</onsuccess><calculation expression="0" stage="G_Consecutive exception count" /></stage><stage stageid="fdf662f3-334e-43b6-82b7-cc5d44745961" name="O_New Item ID" type="Data"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative>New Item ID</narrative><displayx>-195</displayx><displayy>60</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="f539e49a-f60a-4cf1-b6db-6068abc3b441" name="Output" type="Block"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>30</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="00CCFF" /></stage><stage stageid="f5a7a44a-d95b-48e7-a35d-199348e6e2b0" name="Current Status" type="Data"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative>Current item status</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="5e6374e4-f883-4f53-9e59-d569eec85300" name="G_Consecutive exception count" type="Data"><loginhibit /><narrative>The count of cases which have consecutive exceptions</narrative><displayx>-195</displayx><displayy>390</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Bold" color="FF9900" /><datatype>number</datatype><initialvalue>0</initialvalue><alwaysinit /></stage><stage stageid="4004ca7e-2000-4a63-b26c-dc29de19babd" name="Get Current Status" type="Action"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the item to get data from. An error will be raised if this item does not exist." expr="[G_Item ID]" /></inputs><outputs><output type="text" name="Key" narrative="The key value of the item." stage="" /><output type="number" name="Priority" narrative="The priority of the item" stage="" /><output type="text" name="Status" narrative="The status of the item." stage="Current Status" /><output type="number" name="Attempts" narrative="The number of attempts already made to work this item." stage="" /><output type="timespan" name="Worktime" narrative="The total time spent on this item (including previous attempts)" stage="" /><output type="timespan" name="Attempt Worktime" narrative="The amount of time spent on this particular attempt of the item" stage="" /><output type="datetime" name="Loaded DateTime" narrative="The date and time at which this item was first loaded into the queue." stage="" /><output type="datetime" name="Deferred DateTime" narrative="The date and time at which this item has been deferred to. Empty if this item has not been deferred." stage="" /><output type="datetime" name="Completed DateTime" narrative="The date and time at which this item was marked as complete. Empty if this item has not been marked as complete" stage="" /><output type="datetime" name="Exception DateTime" narrative="The date and time at which this item was marked as an exception. Empty if there has never been an exception on this item." stage="" /><output type="text" name="Exception Reason" narrative="The exception reason recorded against this item." stage="" /><output type="text" name="Tags" narrative="The semi-colon separated set of tags which apply to the item. " stage="" /><output type="collection" name="Data" narrative="The data associated with the item - a single collection row." stage="" /></outputs><onsuccess>9d642638-137c-4382-880f-2e9e7d23b2af</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Get Item Data" /></stage><stage stageid="a5fdc4cf-4392-4a2c-9a01-42101331d343" name="Mark exception - Retry" type="Action"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the item to mark" expr="[G_Item ID]" /><input type="text" name="Exception Reason" narrative="A description of the reason for the exception" expr="&quot;System Exception: &quot; &amp; [G_Exception Detail]" /><input type="flag" name="Retry" narrative="Whether or not to retry the item, up to the maximum number of attempts specified for the queue. Optional - if not specified, the item will be retried" expr="True" /><input type="flag" name="Keep Locked" narrative="Whether or not the clone of the item should remain locked after the exception has been registered and the item is retried. Optional - default is False" expr="False" /></inputs><outputs><output type="text" name="New Item ID" narrative="The Item ID of the newly cloned item. This item will be locked if 'Keep Locked' is True. This will be empty if no item was cloned (ie. the item was not retried." stage="O_New Item ID" /></outputs><onsuccess>ffa615ba-4f4f-4287-a56d-41e8ce0e618c</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Mark Exception" /></stage><stage stageid="9d642638-137c-4382-880f-2e9e7d23b2af" name="System/ Internal Exception?" type="Decision"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Lower([G_Exception Type])=&quot;system exception&quot; OR Lower([G_Exception Type])=&quot;internal&quot;" /><ontrue>bda498f3-377f-4e05-8277-1b621527b842</ontrue><onfalse>36e32e27-bf1f-4cc5-ac6e-3e640453eb7d</onfalse></stage><stage stageid="bda498f3-377f-4e05-8277-1b621527b842" name="Tag Item" type="Action"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the queue item to add the tag to" expr="[G_Item ID]" /><input type="text" name="Tag" narrative="The tag to add to the item. Note that this cannot start with a '+' (plus) or '-' (minus) character, and cannot contain ';' (semi-colon) characters" expr="&quot;System Exception&quot;" /></inputs><onsuccess>6c550b1c-1043-4349-b991-4b0add8a215a</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Tag Item" /></stage><stage stageid="6c550b1c-1043-4349-b991-4b0add8a215a" name="Update Status" type="Action"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the item to mark" expr="[G_Item ID]" /><input type="text" name="Status" narrative="The new status - 255 characters maximum." expr="&quot;Last Stage Completed - &quot; &amp; [Current Status]" /></inputs><onsuccess>a5fdc4cf-4392-4a2c-9a01-42101331d343</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Update Status" /></stage><stage stageid="ac96ee99-ba37-4417-9ec9-d5a4b52a5297" name="Tag Item" type="Action"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the queue item to add the tag to" expr="[G_Item ID]" /><input type="text" name="Tag" narrative="The tag to add to the item. Note that this cannot start with a '+' (plus) or '-' (minus) character, and cannot contain ';' (semi-colon) characters" expr="&quot;Business Exception&quot;" /></inputs><onsuccess>54f6f7d7-db8e-43b9-bf28-74f31432c67d</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Tag Item" /></stage><stage stageid="54f6f7d7-db8e-43b9-bf28-74f31432c67d" name="Update Status" type="Action"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the item to mark" expr="[G_Item ID]" /><input type="text" name="Status" narrative="The new status - 255 characters maximum." expr="&quot;Last Stage Completed - &quot; &amp; [Current Status]" /></inputs><onsuccess>76efb7d1-5cad-4d0a-a1b0-b0105728d353</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Update Status" /></stage><stage stageid="36e32e27-bf1f-4cc5-ac6e-3e640453eb7d" name="Anchor33" type="Anchor"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>-15</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>ac96ee99-ba37-4417-9ec9-d5a4b52a5297</onsuccess></stage><stage stageid="ffa615ba-4f4f-4287-a56d-41e8ce0e618c" name="Same as Previous?" type="Decision"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[G_Previous Exception Details]=[G_Exception Detail]" /><ontrue>b72567d9-948a-4581-af1d-3d65fb95a65a</ontrue><onfalse>eb541b1f-e138-4b37-bf02-f0b126969ad9</onfalse></stage><stage stageid="b72567d9-948a-4581-af1d-3d65fb95a65a" name="Count" type="Calculation"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>285</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>1a06ea05-8589-46d6-b392-67d00f513ff9</onsuccess><calculation expression="[G_Consecutive exception count]+1" stage="G_Consecutive exception count" /></stage><stage stageid="1a06ea05-8589-46d6-b392-67d00f513ff9" name="Limit Reached?" type="Decision"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>345</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[G_Consecutive exception count]&gt;=3" /><ontrue>5be6c68a-81a9-4ad0-8a2d-c971ae491f6c</ontrue><onfalse>47d62918-7b80-4b97-94d9-44af8a4cb9d7</onfalse></stage><stage stageid="eb541b1f-e138-4b37-bf02-f0b126969ad9" name="Reset Consecutive Exception Indicators" type="MultipleCalculation"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>225</displayy><displaywidth>120</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>47d62918-7b80-4b97-94d9-44af8a4cb9d7</onsuccess><steps><calculation expression="[G_Exception Detail]" stage="G_Previous Exception Details" /><calculation expression="0" stage="G_Consecutive exception count" /></steps></stage><stage stageid="76efb7d1-5cad-4d0a-a1b0-b0105728d353" name="Mark exception - no retry" type="Action"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the item to mark" expr="[G_Item ID]" /><input type="text" name="Exception Reason" narrative="A description of the reason for the exception" expr="&quot;Business Exception: &quot; &amp; [G_Exception Detail]" /><input type="flag" name="Retry" narrative="Whether or not to retry the item, up to the maximum number of attempts specified for the queue. Optional - if not specified, the item will be retried" expr="False" /><input type="flag" name="Keep Locked" narrative="Whether or not the clone of the item should remain locked after the exception has been registered and the item is retried. Optional - default is False" expr="False" /></inputs><outputs><output type="text" name="New Item ID" narrative="The Item ID of the newly cloned item. This item will be locked if 'Keep Locked' is True. This will be empty if no item was cloned (ie. the item was not retried." stage="O_New Item ID" /></outputs><onsuccess>76bd3276-1705-4df3-988d-1a8688e72556</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Mark Exception" /></stage><stage stageid="76bd3276-1705-4df3-988d-1a8688e72556" name="Anchor35" type="Anchor"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>165</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>53f75a60-c299-4058-a752-7e57e8fbb26d</onsuccess></stage><stage stageid="5be6c68a-81a9-4ad0-8a2d-c971ae491f6c" name="Exception" type="Exception"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>405</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="" detail="&quot;3 consecutive incidents of &quot; &amp; [G_Exception Type] &amp; &quot;: &quot; &amp; [G_Exception Detail]" /></stage><stage stageid="0a740bea-aab5-4774-8ad3-0227174d8346" name="End1" type="End"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>405</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="ed4be1ef-8698-4ab5-84ce-fc71ccd009bc" name="Exception Data" type="MultipleCalculation"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>285</displayx><displayy>435</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>e65f451a-1924-47ef-a000-57b46b1942bd</onsuccess><steps><calculation expression="ExceptionType()" stage="G_Exception Type" /><calculation expression="ExceptionDetail()" stage="G_Exception Detail" /></steps></stage><stage stageid="76f16fe9-1800-4866-9834-252e14583804" name="Resume3" type="Resume"><subsheetid>4f58220f-de37-4011-8c1d-8e4c64b79bf3</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>be5da094-c460-4e2f-94d5-ff84ae19a0bb</onsuccess></stage><stage stageid="47d62918-7b80-4b97-94d9-44af8a4cb9d7" name="Anchor6" type="Anchor"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>345</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>0a740bea-aab5-4774-8ad3-0227174d8346</onsuccess></stage><stage stageid="ac764df3-353b-4109-b556-a645d340ad9a" name="G_Previous Exception Details" type="Data"><loginhibit /><narrative>Exception details for previous exceptions</narrative><displayx>-195</displayx><displayy>420</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Bold" color="FF9900" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="088b18c9-451a-406a-997a-da17c508167f" name="Notify Termination" type="SubSheet"><loginhibit /><narrative></narrative><displayx>930</displayx><displayy>150</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>2ebe2177-841a-4fb2-8e27-2e13ee277ef9</onsuccess><processid>0b444530-73f6-4830-92d5-b46382507891</processid></stage><stage stageid="efcd20d1-c82a-4192-855d-afcabd5d504b" name="Re-Throw" type="Exception"><loginhibit /><narrative></narrative><displayx>930</displayx><displayy>15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="" detail="" usecurrent="yes" /></stage><stage stageid="62df1d30-e7c5-4eee-9a3b-78c4b62c2b4b" name="Recover5" type="Recover"><loginhibit /><narrative></narrative><displayx>930</displayx><displayy>300</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>2d82156d-7850-4d43-9256-7bcd995b5ad9</onsuccess></stage><stage stageid="2ebe2177-841a-4fb2-8e27-2e13ee277ef9" name="Close Down" type="SubSheet"><loginhibit /><narrative></narrative><displayx>930</displayx><displayy>75</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>efcd20d1-c82a-4192-855d-afcabd5d504b</onsuccess><processid>c2e2ca54-d379-4238-8b26-f7afd958d4f6</processid></stage><stage stageid="2d82156d-7850-4d43-9256-7bcd995b5ad9" name="Exception Data" type="MultipleCalculation"><loginhibit /><narrative></narrative><displayx>930</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>088b18c9-451a-406a-997a-da17c508167f</onsuccess><steps><calculation expression="ExceptionType()" stage="G_Exception Type" /><calculation expression="ExceptionDetail()" stage="G_Exception Detail" /></steps></stage><stage stageid="05e774e3-44c4-41b1-8cc6-99b74c114b8a" name="End" type="End"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="b2739268-6020-4cb4-99c4-8963b309c95e" name="Send Email" type="SubSheet"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="To" expr="[E_COE - SCA ACH - Control Notification]" /><input type="text" name="CC" expr="[Notify Termination CC]" /><input type="text" name="Subject" expr="[Notify Termination Subject]" /><input type="text" name="Message" expr="[Notify Termination Message]" /><input type="text" name="Attachments" expr="" /><input type="text" name="Classification" expr="&quot;Confidential&quot;" /></inputs><onsuccess>05e774e3-44c4-41b1-8cc6-99b74c114b8a</onsuccess><processid>7725a2f9-38a1-42c9-8bcd-8b2156e457f9</processid></stage><stage stageid="06b97422-b2eb-464c-b0b9-894ef645add8" name="Message" type="Calculation"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-15</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b2739268-6020-4cb4-99c4-8963b309c95e</onsuccess><calculation expression="&quot;The &quot;&amp;[G_Process Name]&amp;&quot; process running on &quot;&amp;GetResourceName()&amp;&quot; has terminated. The following exception occurred.&quot;&amp;Chr(10)&#xA;&amp;Chr(10)&amp;&quot;Exception Type: &quot;&amp;[G_Exception Type]&#xA;&amp;Chr(10)&amp;&quot;Exception Detail: &quot;&amp;[G_Exception Detail]" stage="Notify Termination Message" /></stage><stage stageid="27eb1492-be1f-49e6-b31c-812d9c832686" name="Subject" type="Calculation"><subsheetid>0b444530-73f6-4830-92d5-b46382507891</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>06b97422-b2eb-464c-b0b9-894ef645add8</onsuccess><calculation expression="&quot;Blue Prism Termination - &quot;&amp;[G_Process Name]" stage="Notify Termination Subject" /></stage><stage stageid="99b47ba8-d12c-481e-aadf-6b1d8716c7f2" name="G_OCIS Master CID Persid" type="Data"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Master OCIS ID as per IBC extraction</narrative><displayx>-195</displayx><displayy>285</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><alwaysinit /></stage><stage stageid="9a7b4b67-944b-4db3-be43-b26670f3efd9" name="Format &amp; Populate Output" type="MultipleCalculation"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>264ab691-39d4-4633-b5dc-b2027d4bf6bb</onsuccess><steps><calculation expression="Replace(Replace([G_Item Data.ACH_1_MOBILE_NUMBER], &quot; &quot;, &quot;&quot;), &quot;-&quot;, &quot;&quot;)" stage="Formatted Phone Number" /><calculation expression="[Formatted Phone Number]" stage="G_Loop Data.Mobile Number" /></steps></stage><stage stageid="a9ca8368-9082-4329-b23d-0e1c9241b4fa" name="Set False" type="Calculation"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>105</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>2091c168-ba0e-4a17-b235-c4f73e60f7d2</onsuccess><calculation expression="False" stage="G_Loop Data.Mob No Status" /></stage><stage stageid="420f9735-3a22-42c9-896d-704f50ae8f33" name="Set True" type="Calculation"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b247c8cb-9e54-4025-9019-0ff1e3fc3763</onsuccess><calculation expression="True" stage="G_Loop Data.Mob No Status" /></stage><stage stageid="b247c8cb-9e54-4025-9019-0ff1e3fc3763" name="Anchor7" type="Anchor"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>210</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b1d82273-c0ce-40a2-8a62-5e413ec531fb</onsuccess></stage><stage stageid="2091c168-ba0e-4a17-b235-c4f73e60f7d2" name="Anchor8" type="Anchor"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>210</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b247c8cb-9e54-4025-9019-0ff1e3fc3763</onsuccess></stage><stage stageid="076ad6e3-af76-4e7d-96bf-0784f5a0697a" name="G_Loop Data" type="Collection"><subsheetid>c835a1b2-5b34-4481-8929-b5c9c3e423bf</subsheetid><loginhibit /><narrative>Created ACH loop data</narrative><displayx>-195</displayx><displayy>255</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>collection</datatype><alwaysinit /><collectioninfo><field name="Client No" type="number" /><field name="First Name" type="text" /><field name="Surname" type="text" /><field name="DOB" type="text" /><field name="Last 4 CC" type="text" /><field name="Mobile Number" type="text" /><field name="Mob No Status" type="flag" /><field name="Update Status" type="flag" /><field name="Initialled Name" type="flag" /></collectioninfo></stage><stage stageid="b0aef269-4e1e-43c8-954d-e82250e37fb9" name="Start" type="Start"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><preconditions><condition narrative="Unknown Vision+ details" /></preconditions><postconditions><condition narrative="Vision+ details found and updated" /></postconditions><narrative></narrative><displayx>90</displayx><displayy>-165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>cc4c59a0-c9e7-469c-8090-a052d01544ab</onsuccess></stage><stage stageid="e04d8e24-bdc2-4a0a-a8da-0a4600a8355c" name="Variables" type="Block"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>630</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="293f06a2-77cb-45fb-890b-6a96fa601926" name="Current Page" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Current page count</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="33ee816d-372c-40df-b190-a8f85370685b" name="Current Row" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Current row count</narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="36f3a136-0f73-4a31-929a-bc1a05613b2a" name="Card Holder Code" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Retrieved card holder code</narrative><displayx>-195</displayx><displayy>75</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="d32694f3-12ba-4be8-bee0-99986c0f8bf9" name="Block Code" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Retrieved block code</narrative><displayx>-195</displayx><displayy>45</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="045cc7d6-52ad-4539-9d87-88a7a0729960" name="Prohibited Block Codes" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Codes which are prohibited</narrative><displayx>-195</displayx><displayy>315</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue xml:space="preserve">CLDRWXYZ</initialvalue><private /><alwaysinit /></stage><stage stageid="6b2658bc-4029-4a0f-9144-5ee80a1a8a8c" name="Page Indicator" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Current page indicator</narrative><displayx>-195</displayx><displayy>105</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="41b4f628-db42-4eac-aa24-2afd09082fb3" name="Current Page ++" type="Calculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>efe9c504-3348-4856-a770-dfda21c26c7d</onsuccess><calculation expression="[Current Page]+1" stage="Current Page" /></stage><stage stageid="efe9c504-3348-4856-a770-dfda21c26c7d" name="Reset Current Row" type="Calculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>105</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>34f2f8e9-e322-43eb-bce8-08105d713844</onsuccess><calculation expression="0" stage="Current Row" /></stage><stage stageid="16eacce5-03e5-4a74-9c50-1c4951bdd488" name="Anchor14" type="Anchor"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>45</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>41b4f628-db42-4eac-aa24-2afd09082fb3</onsuccess></stage><stage stageid="44623145-06d5-4f3b-9a00-c0a2610115ca" name="Number of ACH Updated" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Count on how many ACHs updated</narrative><displayx>-195</displayx><displayy>405</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="4d9b7f44-87d5-4d8b-b356-08be75a1f562" name="ACH Applicable" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Whether the applicable ACH has been found</narrative><displayx>-195</displayx><displayy>135</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue>False</initialvalue><private /><alwaysinit /></stage><stage stageid="b1dfe336-5e17-469e-a496-4f55d3d7b3d5" name="Fax Phone" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Retrieved Fax Phone number</narrative><displayx>-195</displayx><displayy>195</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="e11649ec-520c-4a06-b20e-944f4362a7ee" name="Home Phone" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Retrieved Home Phone number</narrative><displayx>-195</displayx><displayy>165</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="293f7ac9-6b67-4141-922b-afbf12bf853f" name="Updated" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Whether already updated</narrative><displayx>-195</displayx><displayy>255</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="d8ae42c0-bc64-4be6-8c13-bb322e5fc5ea" name="Mobile Phone" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>Retrieved Mobile Phone number</narrative><displayx>-195</displayx><displayy>225</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="218d7c07-cf78-48bb-9c26-3ef659c7aaf6" name="5.1 Go To Table" type="SubSheetInfo"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative>Access the search results and reads output</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="296bd614-1552-47e7-b8ad-ef91e81a6fe3" name="Start" type="Start"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><preconditions><condition narrative="No known Vision+ record" /></preconditions><postconditions><condition narrative="Vision+ record found and extracted" /></postconditions><narrative></narrative><displayx>0</displayx><displayy>-195</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Page" stage="I_Page Increment" /></inputs><onsuccess>2b776f05-18d3-4a0d-addb-9f7730c9af8a</onsuccess></stage><stage stageid="d5ad5286-1abb-41b9-b74a-75fe1e1e6712" name="Variables" type="Block"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="489c2cc0-8054-489b-a97b-709453fcbfa8" name="I_Page Increment" type="Data"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative>Page increment number</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="2dc6c6ae-f6db-4b1b-b41a-f456cf2c8c6e" name="5.2 Read Row" type="SubSheetInfo"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative>Reads a row from the vision+ screen</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="dd3befbc-6c01-45bb-9668-0d24cf33b1fd" name="Start" type="Start"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><preconditions><condition narrative="Unknown row data" /></preconditions><postconditions><condition narrative="Row data extracted" /></postconditions><narrative></narrative><displayx>30</displayx><displayy>-120</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Current Row" stage="I_Current Row" /></inputs><onsuccess>ea7bb54b-1451-4ab3-8129-b33969f5e770</onsuccess></stage><stage stageid="1c0de11e-f3a9-4804-84b2-7e5fe413faa9" name="End" type="End"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><outputs><output type="text" name="Block Code" stage="O_Block Code" /><output type="text" name="Card Holder Code" stage="O_Card Holder Code" /></outputs></stage><stage stageid="29feac11-ccd1-4f3f-b8aa-0b142b9fe12f" name="I_Current Row" type="Data"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative>Current row count</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>1</initialvalue><private /><alwaysinit /></stage><stage stageid="0ee5ff35-3f47-4a38-8f09-3b85164e32a7" name="Variables" type="Block"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>30</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="058bfe24-959a-4a03-9b1f-a0339d9dd254" name="Y Value" type="Data"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative>The Y co-ordinate value</narrative><displayx>-195</displayx><displayy>60</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>6</initialvalue><private /><alwaysinit /></stage><stage stageid="aeeb7958-2df1-4d3e-bacb-f05c9822b055" name="Input" type="Block"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="2c678b20-d5d0-42ca-9b31-12eb9b914ed7" name="O_Block Code" type="Data"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative>Read block code</narrative><displayx>-195</displayx><displayy>135</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="e75a98e5-f904-4ba2-8623-1c4c2654e5b6" name="O_Card Holder Code" type="Data"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative>Read cardholder code</narrative><displayx>-195</displayx><displayy>165</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="e96f079e-fd8e-4483-a7d6-d66947a87cf1" name="Output" type="Block"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="1dd45417-1ec4-40a3-8b9b-4b73bbc08fd6" name="5.3 Check ACH" type="SubSheetInfo"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Validates the ACH data from Vision+ and the input file</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="664ee1ca-9906-491e-bab6-261bdd352f53" name="Start" type="Start"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><preconditions><condition narrative="ACH found but unvalidated" /></preconditions><postconditions><condition narrative="ACH found and validated" /></postconditions><narrative></narrative><displayx>30</displayx><displayy>-435</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Current Row" stage="I_Current Row" /></inputs><onsuccess>ab1016e1-0f19-429d-92f5-a016df2f48aa</onsuccess></stage><stage stageid="e78405e7-1759-434e-ac21-01950a3c0ae3" name="Input" type="Block"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="e3dfa9ec-ddc4-4292-b4cd-312e9151e38c" name="Command_Read Details" type="Collection"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Read command</narrative><displayx>-195</displayx><displayy>390</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>collection</datatype><private /><alwaysinit /><collectioninfo><field name="Command" type="text" /><field name="Input Text" type="text" /><field name="Input Password" type="password" /><field name="Parameters" type="text" /></collectioninfo><initialvalue><row><field name="Command" type="text" value="Send Keys" /><field name="Input Text" type="text" value="{ENTER}" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="1,0" /></row><row><field name="Command" type="text" value="Text Write" /><field name="Input Text" type="text" value="ARQN" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="9,1" /></row><row><field name="Command" type="text" value="Send Keys" /><field name="Input Text" type="text" value="{ENTER}" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="0,0" /></row><row><field name="Command" type="text" value="Read" /><field name="Input Text" type="text" value="" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="20,5,41,5" /></row><row><field name="Command" type="text" value="Read" /><field name="Input Text" type="text" value="" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="20,6,41,6" /></row><row><field name="Command" type="text" value="Send Keys" /><field name="Input Text" type="text" value="{ENTER}" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="0,0" /></row><row><field name="Command" type="text" value="Read" /><field name="Input Text" type="text" value="" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="17,19,27,19" /></row><row><field name="Command" type="text" value="Read" /><field name="Input Text" type="text" value="" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="17,20,27,20" /></row><row><field name="Command" type="text" value="Read" /><field name="Input Text" type="text" value="" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="17,21,27,21" /></row><row><field name="Command" type="text" value="Send Keys" /><field name="Input Text" type="text" value="{ENTER}" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="0,0" /></row><row><field name="Command" type="text" value="Read" /><field name="Input Text" type="text" value="" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="33,5,40,5" /></row></initialvalue></stage><stage stageid="aa3f7318-69cf-442a-bae8-d494cede6fe9" name="Details" type="Collection"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Read details</narrative><displayx>-195</displayx><displayy>60</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>collection</datatype><private /><alwaysinit /></stage><stage stageid="7c0891c8-54f4-4320-abce-01d59e93c142" name="Variables" type="Block"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>30</displayy><displaywidth>150</displaywidth><displayheight>150</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="e2eb899a-941d-4451-a6db-6b93dd95ca95" name="First Name" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Extracted firstname</narrative><displayx>-195</displayx><displayy>90</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="882069de-6daa-4488-a658-4e2645d4e73e" name="Last Name" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Extracted surname</narrative><displayx>-195</displayx><displayy>120</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="2d243202-52cc-4333-9d10-b1cfb7fe9f7a" name="Date Of Birth" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Extracted DOB</narrative><displayx>-195</displayx><displayy>150</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="423b0348-22da-40ae-b3be-100583772b40" name="O_Home Phone" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Output Home phone</narrative><displayx>-195</displayx><displayy>255</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="00a564a4-d863-4b06-b0e1-2fe37e3c7edc" name="O_ACH Applicable" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Whether applicable ACH has been found</narrative><displayx>-195</displayx><displayy>225</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue>False</initialvalue><private /><alwaysinit /></stage><stage stageid="79915bf2-a6a5-4e1a-b630-53cabc07bea1" name="Output" type="Block"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>195</displayy><displaywidth>150</displaywidth><displayheight>150</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="5e02c67c-ec3a-423c-85ec-bc309353a916" name="O_Fax Phone" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Output Fax phone</narrative><displayx>-195</displayx><displayy>285</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="a441f58d-6248-408a-8de2-b692ea525c9b" name="Constants" type="Block"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>360</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="1dd68336-7152-40e3-a12b-d755f0c04e38" name="O_Mobile Phone" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Output Mobile phone</narrative><displayx>-195</displayx><displayy>315</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="098d3d61-8b13-4f12-8d98-8fdf5e9c7b9b" name="5.4 Update ACH" type="SubSheetInfo"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative>Updates the telephone number of the appropriate ACH</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="701464b7-d19b-4bc3-a917-d01148172421" name="Start" type="Start"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><preconditions><condition narrative="Blank or incorrect Mobile number" /></preconditions><postconditions><condition narrative="Correct and updated mobile number" /></postconditions><narrative></narrative><displayx>15</displayx><displayy>-195</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Fax Phone" stage="I_Fax Phone" /><input type="text" name="Home Phone" stage="I_Home Phone" /></inputs><onsuccess>4eeeb877-712d-484e-ae87-8d1a64e267d2</onsuccess></stage><stage stageid="e3fc75e4-1802-4b31-b0d0-53a07a62af2a" name="End" type="End"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>585</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="725aa106-1eec-4559-a929-a9efa4a30e9b" name="Got Home Phone" type="Decision"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len(Trim([I_Home Phone]))&gt;0" /><ontrue>1af87b3e-e971-4c69-8758-e7e9dc39430d</ontrue><onfalse>f7d4d515-8118-4699-907c-c3d23c60114a</onfalse></stage><stage stageid="1af87b3e-e971-4c69-8758-e7e9dc39430d" name="Set Home Phone Indicator" type="Calculation"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>bf5b3415-7c45-4d9d-92b2-b78337f7f895</onsuccess><calculation expression="&quot;1&quot;" stage="Home Phone Indicator" /></stage><stage stageid="4107be5d-7a74-4566-a604-20d7fe52f0e7" name="Set Fax Phone Indicator" type="Calculation"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>165</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>46263dce-3710-4525-8872-87895887ecd0</onsuccess><calculation expression="&quot;1&quot;" stage="Fax Phone Indicator" /></stage><stage stageid="20e5131b-4d90-422c-87e8-8b21817cb7e8" name="Got Fax Phone" type="Decision"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>165</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len(Trim([I_Fax Phone]))&gt;0" /><ontrue>4107be5d-7a74-4566-a604-20d7fe52f0e7</ontrue><onfalse>fbd0b4bf-6b7d-4bdb-aff8-ec15fdc84074</onfalse></stage><stage stageid="d84787cf-3e73-4756-bcde-c86f6763304f" name="Home Phone Indicator" type="Data"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative>Vision+ Home Phone indicator</narrative><displayx>-195</displayx><displayy>90</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue xml:space="preserve">0</initialvalue><private /><alwaysinit /></stage><stage stageid="1361db08-6994-4b03-a0d7-753fa3f02e7d" name="Fax Phone Indicator" type="Data"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative>Vision+ Fax Phone indicator</narrative><displayx>-195</displayx><displayy>120</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue xml:space="preserve">0</initialvalue><private /><alwaysinit /></stage><stage stageid="670fb022-02f3-44db-956a-27105136648b" name="Check String" type="Data"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative>String to check</narrative><displayx>-195</displayx><displayy>150</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="364ff045-21f5-4965-870d-dadb38bd76e1" name="Command_Go To Maintenance" type="Collection"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative>Navigate commands</narrative><displayx>-195</displayx><displayy>225</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>collection</datatype><private /><alwaysinit /><collectioninfo><field name="Command" type="text" /><field name="Input Text" type="text" /><field name="Input Password" type="password" /><field name="Parameters" type="text" /></collectioninfo><initialvalue><row><field name="Command" type="text" value="Text Write" /><field name="Input Text" type="text" value="ARMN" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="9,1" /></row><row><field name="Command" type="text" value="Send Keys" /><field name="Input Text" type="text" value="{ENTER}" /><field name="Input Password" type="password" encvalue="aCpGKl8qTyp6KlgqQypZKkcqBCppKkUqWCpPKgQqeSpPKkkqXypYKk8qBCp5KkMqRypaKkYqTyplKkgqTCpfKlkqSSpLKl4qRSpYKg==:" /><field name="Parameters" type="text" value="1,0" /></row></initialvalue></stage><stage stageid="a0391f91-03ed-4e1a-96ac-2c27aef0b66f" name="I_Fax Phone" type="Data"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative>Fax phone number</narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="b3ac9a9b-c6ac-4eef-9789-053ffd12b7db" name="I_Home Phone" type="Data"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative>Home phone number</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="38316880-9c1a-49ec-9aa8-0895864fa207" name="Input" type="Block"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="3dac9e7b-f1be-412b-840e-890c9e0939ad" name="Constant" type="Block"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>195</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="f3f58e99-1725-4b26-99dd-f22b1f96d1c1" name="Variables" type="Block"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>60</displayy><displaywidth>150</displaywidth><displayheight>120</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="f3ec55a9-4f6b-4b44-91c9-07a9d509f098" name="Sleep (1)" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>465</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="1" /></inputs><onsuccess>30e761c7-af18-4364-877a-885ca3fd7581</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="c65d183b-8b28-4b4e-a34b-104802b25862" name="Update Data" type="Action"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>480</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Item ID" narrative="The ID of the work item to set the data on. This item should be locked by the calling session." expr="[G_Item ID]" /><input type="collection" name="Data" narrative="A collection with one row containing the data to be set on the item. If the item has a key value and this collection has a key value, they should match exactly." expr="[G_Item Data]" /></inputs><onsuccess>d992cfae-d6f4-4c11-a2ef-0ee547e47556</onsuccess><resource object="Blueprism.Automate.clsWorkQueuesActions" action="Set Data" /></stage><stage stageid="de43a263-81e3-41ef-a894-e4a47aa21672" name="Add to Global Item Data" type="Calculation"><subsheetid>d12139ff-715c-4ebe-8a87-3be8b5e7ec41</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>360</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>6229a8d5-5f87-44e3-a4a8-eb8c2e441636</onsuccess><calculation expression="[G_OCIS Master CID Persid]" stage="G_Item Data.OCIS Master CID Persid" /></stage><stage stageid="b6019918-5585-4d10-b6f5-c5891a1c58ba" name="2. Create Loop Data" type="SubSheetInfo"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative>Provides the ability to take each of the additional card holders data and place within a multi row collection for use within the process.</narrative><displayx>-195</displayx><displayy>-105</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="cb3e889b-20fb-4ec0-b413-9b5e6c828615" name="Start" type="Start"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><preconditions><condition narrative="Queue data loaded" /></preconditions><postconditions><condition narrative="Queue Data loaded &amp; seperate ACH collection created" /></postconditions><narrative></narrative><displayx>-30</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>af763076-9797-4e0d-b2bc-0130802a0f6b</onsuccess></stage><stage stageid="e359c12d-82fc-4005-bb8d-3dab4845eead" name="Populate ACH1" type="MultipleCalculation"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>6270c3db-65f5-4685-afc4-64c14f48e127</onsuccess><steps><calculation expression="&quot;1&quot;" stage="G_Loop Data.Client No" /><calculation expression="[G_Item Data.ACH_1_FIRST_NAME]" stage="G_Loop Data.First Name" /><calculation expression="[G_Item Data.ACH_1_LAST_NAME]" stage="G_Loop Data.Surname" /><calculation expression="[G_Item Data.ACH_1_DOB]" stage="G_Loop Data.DOB" /><calculation expression="[G_Item Data.ACH_1_CC_NUMBER_LAST_4]" stage="G_Loop Data.Last 4 CC" /><calculation expression="Replace(Replace([G_Item Data.ACH_1_MOBILE_NUMBER], &quot; &quot;, &quot;&quot;), &quot;-&quot;, &quot;&quot;)" stage="G_Loop Data.Mobile Number" /><calculation expression="False" stage="G_Loop Data.Initialled Name" /><calculation expression="False" stage="G_Loop Data.Mob No Status" /><calculation expression="False" stage="G_Loop Data.Update Status" /></steps></stage><stage stageid="af763076-9797-4e0d-b2bc-0130802a0f6b" name="Add Row" type="Action"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Collection Name" narrative="The name of the collection to act upon" expr="&quot;G_Loop Data&quot;" /></inputs><onsuccess>e359c12d-82fc-4005-bb8d-3dab4845eead</onsuccess><resource object="Blueprism.AutomateProcessCore.clsCollectionActions" action="Add Row" /></stage><stage stageid="6270c3db-65f5-4685-afc4-64c14f48e127" name="2nd ACH?" type="Decision"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len([G_Item Data.ACH_2_MOBILE_NUMBER])&gt;0" /><ontrue>2103e664-feb0-4ec5-ae08-a842dc27cf03</ontrue><onfalse>b47d488b-f542-4604-82f8-2b4d517ab68e</onfalse></stage><stage stageid="f856407e-43fc-4212-adae-b8b6eb7621b4" name="Populate ACH2" type="MultipleCalculation"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>60</displayx><displayy>105</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>5b0df06c-debc-416b-995f-fa549424f8f1</onsuccess><steps><calculation expression="&quot;2&quot;" stage="G_Loop Data.Client No" /><calculation expression="[G_Item Data.ACH_2_FIRST_NAME]" stage="G_Loop Data.First Name" /><calculation expression="[G_Item Data.ACH_2_LAST_NAME]" stage="G_Loop Data.Surname" /><calculation expression="[G_Item Data.ACH_2_DOB]" stage="G_Loop Data.DOB" /><calculation expression="[G_Item Data.ACH_2_CC_NUMBER_LAST_4]" stage="G_Loop Data.Last 4 CC" /><calculation expression="Replace(Replace([G_Item Data.ACH_2_MOBILE_NUMBER], &quot; &quot;, &quot;&quot;), &quot;-&quot;, &quot;&quot;)" stage="G_Loop Data.Mobile Number" /><calculation expression="False" stage="G_Loop Data.Initialled Name" /><calculation expression="False" stage="G_Loop Data.Mob No Status" /><calculation expression="False" stage="G_Loop Data.Update Status" /></steps></stage><stage stageid="2103e664-feb0-4ec5-ae08-a842dc27cf03" name="Add Row" type="Action"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>60</displayx><displayy>45</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Collection Name" narrative="The name of the collection to act upon" expr="&quot;G_Loop Data&quot;" /></inputs><onsuccess>f856407e-43fc-4212-adae-b8b6eb7621b4</onsuccess><resource object="Blueprism.AutomateProcessCore.clsCollectionActions" action="Add Row" /></stage><stage stageid="5b0df06c-debc-416b-995f-fa549424f8f1" name="3rd ACH?" type="Decision"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>60</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len([G_Item Data.ACH_3_MOBILE_NUMBER])&gt;0" /><ontrue>1ef88c4b-28dc-4b17-8571-5dac34358114</ontrue><onfalse>b47d488b-f542-4604-82f8-2b4d517ab68e</onfalse></stage><stage stageid="4dc3e2fe-bbe9-4dd2-85e8-1ef51ad7545c" name="Populate ACH3" type="MultipleCalculation"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>150</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>7038ed08-02c1-495c-9ad2-d03c1bfa36cb</onsuccess><steps><calculation expression="&quot;3&quot;" stage="G_Loop Data.Client No" /><calculation expression="[G_Item Data.ACH_3_FIRST_NAME]" stage="G_Loop Data.First Name" /><calculation expression="[G_Item Data.ACH_3_LAST_NAME]" stage="G_Loop Data.Surname" /><calculation expression="[G_Item Data.ACH_3_DOB]" stage="G_Loop Data.DOB" /><calculation expression="[G_Item Data.ACH_3_CC_NUMBER_LAST_4]" stage="G_Loop Data.Last 4 CC" /><calculation expression="Replace(Replace([G_Item Data.ACH_3_MOBILE_NUMBER], &quot; &quot;, &quot;&quot;), &quot;-&quot;, &quot;&quot;)" stage="G_Loop Data.Mobile Number" /><calculation expression="False" stage="G_Loop Data.Initialled Name" /><calculation expression="False" stage="G_Loop Data.Mob No Status" /><calculation expression="False" stage="G_Loop Data.Update Status" /></steps></stage><stage stageid="1ef88c4b-28dc-4b17-8571-5dac34358114" name="Add Row" type="Action"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>150</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Collection Name" narrative="The name of the collection to act upon" expr="&quot;G_Loop Data&quot;" /></inputs><onsuccess>4dc3e2fe-bbe9-4dd2-85e8-1ef51ad7545c</onsuccess><resource object="Blueprism.AutomateProcessCore.clsCollectionActions" action="Add Row" /></stage><stage stageid="7038ed08-02c1-495c-9ad2-d03c1bfa36cb" name="4th ACH?" type="Decision"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>150</displayx><displayy>285</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len([G_Item Data.ACH_4_MOBILE_NUMBER])&gt;0" /><ontrue>1ac4a1b1-0de0-4777-81cd-7b40f07e63cb</ontrue><onfalse>0b30526a-0703-4c2d-9a35-359cf9388e96</onfalse></stage><stage stageid="4a3f8159-9d02-48cd-8649-2cd5cfd4133f" name="Populate ACH4" type="MultipleCalculation"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>240</displayx><displayy>345</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b862648b-4759-4d65-9985-2ece810bf5e3</onsuccess><steps><calculation expression="&quot;4&quot;" stage="G_Loop Data.Client No" /><calculation expression="[G_Item Data.ACH_4_FIRST_NAME]" stage="G_Loop Data.First Name" /><calculation expression="[G_Item Data.ACH_4_LAST_NAME]" stage="G_Loop Data.Surname" /><calculation expression="[G_Item Data.ACH_4_DOB]" stage="G_Loop Data.DOB" /><calculation expression="[G_Item Data.ACH_4_CC_NUMBER_LAST_4]" stage="G_Loop Data.Last 4 CC" /><calculation expression="Replace(Replace([G_Item Data.ACH_4_MOBILE_NUMBER], &quot; &quot;, &quot;&quot;), &quot;-&quot;, &quot;&quot;)" stage="G_Loop Data.Mobile Number" /><calculation expression="False" stage="G_Loop Data.Initialled Name" /><calculation expression="False" stage="G_Loop Data.Mob No Status" /><calculation expression="False" stage="G_Loop Data.Update Status" /></steps></stage><stage stageid="1ac4a1b1-0de0-4777-81cd-7b40f07e63cb" name="Add Row" type="Action"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>240</displayx><displayy>285</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Collection Name" narrative="The name of the collection to act upon" expr="&quot;G_Loop Data&quot;" /></inputs><onsuccess>4a3f8159-9d02-48cd-8649-2cd5cfd4133f</onsuccess><resource object="Blueprism.AutomateProcessCore.clsCollectionActions" action="Add Row" /></stage><stage stageid="b862648b-4759-4d65-9985-2ece810bf5e3" name="5th ACH?" type="Decision"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>240</displayx><displayy>405</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len([G_Item Data.ACH_5_MOBILE_NUMBER])&gt;0" /><ontrue>ef05dce3-2f28-41fe-b427-048cdce438ef</ontrue><onfalse>e5ced2ff-18a7-498d-a622-5bc6594fb41a</onfalse></stage><stage stageid="94e0cb1b-8fb0-4368-bb57-fc8b1dae5a90" name="Populate ACH5" type="MultipleCalculation"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>465</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>fa03be85-bc94-4df2-b9cb-5709f9b23b44</onsuccess><steps><calculation expression="&quot;5&quot;" stage="G_Loop Data.Client No" /><calculation expression="[G_Item Data.ACH_5_FIRST_NAME]" stage="G_Loop Data.First Name" /><calculation expression="[G_Item Data.ACH_5_LAST_NAME]" stage="G_Loop Data.Surname" /><calculation expression="[G_Item Data.ACH_5_DOB]" stage="G_Loop Data.DOB" /><calculation expression="[G_Item Data.ACH_5_CC_NUMBER_LAST_4]" stage="G_Loop Data.Last 4 CC" /><calculation expression="Replace(Replace([G_Item Data.ACH_5_MOBILE_NUMBER], &quot; &quot;, &quot;&quot;), &quot;-&quot;, &quot;&quot;)" stage="G_Loop Data.Mobile Number" /><calculation expression="False" stage="G_Loop Data.Initialled Name" /><calculation expression="False" stage="G_Loop Data.Mob No Status" /><calculation expression="False" stage="G_Loop Data.Update Status" /></steps></stage><stage stageid="ef05dce3-2f28-41fe-b427-048cdce438ef" name="Add Row" type="Action"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>405</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Collection Name" narrative="The name of the collection to act upon" expr="&quot;G_Loop Data&quot;" /></inputs><onsuccess>94e0cb1b-8fb0-4368-bb57-fc8b1dae5a90</onsuccess><resource object="Blueprism.AutomateProcessCore.clsCollectionActions" action="Add Row" /></stage><stage stageid="fa03be85-bc94-4df2-b9cb-5709f9b23b44" name="End2" type="End"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>465</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="e5ced2ff-18a7-498d-a622-5bc6594fb41a" name="Anchor17" type="Anchor"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>405</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>fa03be85-bc94-4df2-b9cb-5709f9b23b44</onsuccess></stage><stage stageid="0b30526a-0703-4c2d-9a35-359cf9388e96" name="Anchor20" type="Anchor"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>285</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>e5ced2ff-18a7-498d-a622-5bc6594fb41a</onsuccess></stage><stage stageid="b47d488b-f542-4604-82f8-2b4d517ab68e" name="Anchor22" type="Anchor"><subsheetid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>165</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>0b30526a-0703-4c2d-9a35-359cf9388e96</onsuccess></stage><stage stageid="f5834995-e47d-4078-bc45-2880e36f8592" name="2. Create Loop Data" type="SubSheet"><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>135</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>cecb01b9-7722-4a9c-84ad-34cfe84158b1</onsuccess><processid>059ac15f-cd8e-42f1-a3e3-bba2987cd702</processid></stage><stage stageid="5b5fd74c-d65b-4ad0-bd1b-248bdd43734e" name="Loop ACH Data" type="LoopStart"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>9a7b4b67-944b-4db3-be43-b26670f3efd9</onsuccess><groupid>c1b03014-af13-4842-9c7d-cbbf205f3afe</groupid><looptype>ForEach</looptype><loopdata>G_Loop Data</loopdata></stage><stage stageid="b1d82273-c0ce-40a2-8a62-5e413ec531fb" name="Loop ACH Data" type="LoopEnd"><subsheetid>1e5325c1-b03d-4dad-8487-c5cb1fcc6d09</subsheetid><loginhibit /><narrative></narrative><displayx>-30</displayx><displayy>255</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>0cd0433a-fc8c-4d18-ac83-d23f0f1d2fce</onsuccess><groupid>c1b03014-af13-4842-9c7d-cbbf205f3afe</groupid></stage><stage stageid="958e0c59-71fd-49b8-b065-9e7127687e05" name="Reset Current Row &amp; Page" type="MultipleCalculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>41b4f628-db42-4eac-aa24-2afd09082fb3</onsuccess><steps><calculation expression="0" stage="Current Page" /><calculation expression="0" stage="Current Row" /><calculation expression="False" stage="Initialled Name" /></steps></stage><stage stageid="4255ce2b-32eb-4766-be90-8b82f8ec4c86" name="Loop ACHs" type="LoopStart"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>-75</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>958e0c59-71fd-49b8-b065-9e7127687e05</onsuccess><groupid>387b538e-a93a-4bae-9caf-24b179bdfbc1</groupid><looptype>ForEach</looptype><loopdata>G_Loop Data</loopdata></stage><stage stageid="ec9a026d-ea79-4997-8054-980e3d45cdb1" name="Loop ACHs" type="LoopEnd"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>645</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b8bcb046-9101-4686-af3a-59dec4ed1952</onsuccess><groupid>387b538e-a93a-4bae-9caf-24b179bdfbc1</groupid></stage><stage stageid="a1dadc07-fa99-4602-b10d-fb56ae669ddc" name="Found Row" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>345</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="(InStr([Prohibited Block Codes], [Block Code]) = 0 OR [Block Code] = &quot;&quot;) AND [Card Holder Code] = &quot;1&quot;" /><ontrue>70a1ca38-9886-462e-a266-c804a278adfc</ontrue><onfalse>ef817d97-d4db-4273-8ec8-adb6d9dafb03</onfalse></stage><stage stageid="e641260f-22a0-4116-91e2-30b9d941c7f0" name="Current Row ++" type="Calculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>e3334f57-d645-469e-8a47-bdbd1ab01195</onsuccess><calculation expression="[Current Row]+1" stage="Current Row" /></stage><stage stageid="34f2f8e9-e322-43eb-bce8-08105d713844" name="2.2 Go To Table" type="SubSheet"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>165</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Page" expr="[Current Page]" /></inputs><onsuccess>e641260f-22a0-4116-91e2-30b9d941c7f0</onsuccess><processid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</processid></stage><stage stageid="e3334f57-d645-469e-8a47-bdbd1ab01195" name="2.3 Read Row" type="SubSheet"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>285</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Current Row" expr="[Current Row]" /></inputs><outputs><output type="text" name="Block Code" stage="Block Code" /><output type="text" name="Card Holder Code" stage="Card Holder Code" /></outputs><onsuccess>a1dadc07-fa99-4602-b10d-fb56ae669ddc</onsuccess><processid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</processid></stage><stage stageid="880552c0-875b-4188-a1a6-bd890a279414" name="Anchor15" type="Anchor"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>225</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>e641260f-22a0-4116-91e2-30b9d941c7f0</onsuccess></stage><stage stageid="ef817d97-d4db-4273-8ec8-adb6d9dafb03" name="Empty Row" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>345</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Block Code] = &quot; &quot; AND [Card Holder Code] =  &quot; &quot;" /><ontrue>9f257c4f-6d6f-4fe1-b3cc-d2bee8ab9ddb</ontrue><onfalse>880552c0-875b-4188-a1a6-bd890a279414</onfalse></stage><stage stageid="daefc218-3b30-4659-bfde-9267a63078c6" name="More Pages" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>345</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Page Indicator] = &quot;MORE...&quot;" /><ontrue>16eacce5-03e5-4a74-9c50-1c4951bdd488</ontrue><onfalse>a5b12d1c-9a58-4103-b7c8-a1c4a3507a62</onfalse></stage><stage stageid="9f257c4f-6d6f-4fe1-b3cc-d2bee8ab9ddb" name="Read Page Indicator" type="Action"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>315</displayx><displayy>345</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="70" /><input type="number" name="y-Position" narrative="The start y position" expr="22" /><input type="number" name="String Length" narrative="Length of the string to read" expr="6" /></inputs><outputs><output type="text" name="Read Text" stage="Page Indicator" /></outputs><onsuccess>daefc218-3b30-4659-bfde-9267a63078c6</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="f1f0a5ae-4dc0-47cf-b0c6-e451ff313ead" name="5.3 Check ACH" type="SubSheet"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>465</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Current Row" expr="[Current Row]" /></inputs><outputs><output type="flag" name="ACH Applicable" stage="ACH Applicable" /><output type="text" name="Fax Phone" stage="Fax Phone" /><output type="text" name="Home Phone" stage="Home Phone" /><output type="text" name="Mobile Phone" stage="Mobile Phone" /><output type="flag" name="Name Initialled?" stage="Initialled Name" /></outputs><onsuccess>7dc9bbc3-e6b2-423f-b503-e98726b26e74</onsuccess><processid>c9ccc708-a0df-4309-8e81-393f66cf5314</processid></stage><stage stageid="a5b12d1c-9a58-4103-b7c8-a1c4a3507a62" name="ACH Found?" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Number of ACH Found] &gt; 0" /><ontrue>0dc86752-34a5-494c-b6a5-1ac5dc0fc478</ontrue><onfalse>a36fd650-ad7c-4304-9f67-66de9aaa8e6d</onfalse></stage><stage stageid="7dc9bbc3-e6b2-423f-b503-e98726b26e74" name="Found Applicable" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>510</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[ACH Applicable]" /><ontrue>1957ae80-54a1-48d1-8b05-cee54eebce8a</ontrue><onfalse>fb5f01d0-71ea-438f-a9d2-caeb276a816e</onfalse></stage><stage stageid="fb5f01d0-71ea-438f-a9d2-caeb276a816e" name="Reset Applicable Data" type="MultipleCalculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-45</displayx><displayy>510</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>3fc605d5-868e-4cc4-b670-136608ae5295</onsuccess><steps><calculation expression="False" stage="ACH Applicable" /><calculation expression="&quot;&quot;" stage="Fax Phone" /><calculation expression="&quot;&quot;" stage="Home Phone" /><calculation expression="&quot;&quot;" stage="Mobile Phone" /><calculation expression="False" stage="Updated" /></steps></stage><stage stageid="3fc605d5-868e-4cc4-b670-136608ae5295" name="Anchor16" type="Anchor"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-45</displayx><displayy>165</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>34f2f8e9-e322-43eb-bce8-08105d713844</onsuccess></stage><stage stageid="60d0c838-e69a-4ef1-9991-27895ca173e7" name="5.4 Update ACH" type="SubSheet"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>690</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Fax Phone" expr="[Fax Phone]" /><input type="text" name="Home Phone" expr="[Home Phone]" /></inputs><onsuccess>aafdbd93-85f0-4882-91b5-b98737f2fc52</onsuccess><processid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</processid></stage><stage stageid="0dc86752-34a5-494c-b6a5-1ac5dc0fc478" name="Applicable ACH Found?" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>465</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Number of Applicable ACH] &gt; 0" /><ontrue>69102b13-58fe-4431-bb35-70e42e7bd9c1</ontrue><onfalse>e0541ebd-b4df-44ef-bfc8-839340f354fa</onfalse></stage><stage stageid="8c9412fb-6d4b-48de-8cda-5f97d13bd4d5" name="Already Updated" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>630</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Mobile Phone] = Right(&quot;0&quot;&amp;[G_Loop Data.Mobile Number],11)" /><ontrue>3eccfc19-d56a-4bbe-9a87-a680be4a8ef3</ontrue><onfalse>60d0c838-e69a-4ef1-9991-27895ca173e7</onfalse></stage><stage stageid="a36fd650-ad7c-4304-9f67-66de9aaa8e6d" name="Anchor10" type="Anchor"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>570</displayx><displayy>405</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>e0541ebd-b4df-44ef-bfc8-839340f354fa</onsuccess></stage><stage stageid="3e07402b-5258-419f-8168-76ee86b22b62" name="Reset IBC" type="Action"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><narrative></narrative><displayx>-15</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>cab01e86-89f3-411e-909b-ec91e3308a19</onsuccess><resource object="COE-IBC-Basic Actions" action="Reset IBC" /></stage><stage stageid="3eceba8c-0202-4100-9096-dabd31cb9b8e" name="Block3" type="Block"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><narrative></narrative><displayx>-60</displayx><displayy>-105</displayy><displaywidth>195</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="e0a8d19e-4f1a-45fc-b47a-184b5685591b" name="Recover3" type="Recover"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>47859269-6b0e-48dc-b157-cec59452aaa4</onsuccess></stage><stage stageid="179550eb-3666-449e-85d4-627a27ec318e" name="Restart COMMAND" type="Calculation"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><narrative></narrative><displayx>195</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><onsuccess>d28b29be-43e0-4115-86d3-8f3345fc805f</onsuccess><calculation expression="&quot;RESTART&quot;" stage="G_IBC Control" /></stage><stage stageid="47859269-6b0e-48dc-b157-cec59452aaa4" name="Resume4" type="Resume"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><narrative></narrative><displayx>195</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>179550eb-3666-449e-85d4-627a27ec318e</onsuccess></stage><stage stageid="d28b29be-43e0-4115-86d3-8f3345fc805f" name="1.1 Control Applications" type="SubSheet"><subsheetid>06db150d-d3f5-4c6c-bddf-d0b8a0841b6c</subsheetid><loginhibit /><narrative></narrative><displayx>195</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>cab01e86-89f3-411e-909b-ec91e3308a19</onsuccess><processid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</processid></stage><stage stageid="586892db-8225-4198-954b-54f7cc4bf649" name="Block4" type="Block"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative></narrative><displayx>-60</displayx><displayy>-105</displayy><displaywidth>195</displaywidth><displayheight>120</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="1747b4f2-fa0e-45a3-9cd3-b58319876fe1" name="Recover4" type="Recover"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>83f6bb0a-ef3d-4e2e-a90b-300cc85eef7e</onsuccess></stage><stage stageid="83f6bb0a-ef3d-4e2e-a90b-300cc85eef7e" name="Resume5" type="Resume"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative></narrative><displayx>195</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>b85dba71-4650-4897-8a7d-b67dcb9e000c</onsuccess></stage><stage stageid="b85dba71-4650-4897-8a7d-b67dcb9e000c" name="Restart COMMAND" type="Calculation"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative></narrative><displayx>195</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><onsuccess>4865bae8-99cd-4999-8e2e-d13b74545284</onsuccess><calculation expression="&quot;RESTART&quot;" stage="G_Vision+ Control" /></stage><stage stageid="4865bae8-99cd-4999-8e2e-d13b74545284" name="1.1 Control Applications" type="SubSheet"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative></narrative><displayx>195</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>7f60d293-5a83-4eca-9e7d-891641527904</onsuccess><processid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</processid></stage><stage stageid="dfc7c6c7-ea18-44f3-b05e-0289a5b433bf" name="Exception Message" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>System exception message</narrative><displayx>-195</displayx><displayy>285</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="7e358476-3eb9-4791-a980-4db1411b168f" name="Start" type="Start"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><preconditions><condition narrative="N/A" /></preconditions><postconditions><condition narrative="N/A" /></postconditions><narrative></narrative><displayx>15</displayx><displayy>-135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>012ed732-2868-4790-806e-74ca6245f627</onsuccess></stage><stage stageid="3ff06392-8079-4736-be39-bae42b4a9787" name="Poll Wait" type="Data"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>60</initialvalue><private /><alwaysinit /></stage><stage stageid="236f2b9b-cf39-4f63-8d3b-50c2d7735f07" name="End3" type="End"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>225</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /></stage><stage stageid="23de3d99-fa41-4918-8ba2-dbed5dafe55a" name="1.1 Control Applications" type="SubSheet"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>30</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><onsuccess>0a95ffb0-ae45-4ba9-8bc8-74f2873f1850</onsuccess><processid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</processid></stage><stage stageid="77b38afa-186c-4829-88c5-bc1167e6b593" name="Wait" type="Action"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>-60</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="[Poll Wait]" /></inputs><onsuccess>012ed732-2868-4790-806e-74ca6245f627</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="a3f923e2-ec2d-4f32-bdaa-d36fa9ccc59d" name="Queue Loaded?" type="Decision"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><decision expression="[Queue Loaded]" /><ontrue>236f2b9b-cf39-4f63-8d3b-50c2d7735f07</ontrue><onfalse>e2751446-e34d-44dd-b90d-586583f37409</onfalse></stage><stage stageid="012ed732-2868-4790-806e-74ca6245f627" name="Maintain All" type="MultipleCalculation"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><onsuccess>23de3d99-fa41-4918-8ba2-dbed5dafe55a</onsuccess><steps><calculation expression="&quot;&quot;" stage="G_Vision+ Control" /><calculation expression="&quot;&quot;" stage="G_IBC Control" /></steps></stage><stage stageid="0a95ffb0-ae45-4ba9-8bc8-74f2873f1850" name="Load Queue" type="Process"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>105</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Number of Files to Load" narrative="Number of files to load (will load ALL files by default if left blank)" expr="99999" /></inputs><outputs><output type="flag" name="Queue Loaded" narrative="Whether the queue has been loaded" stage="Queue Loaded" /></outputs><onsuccess>a3f923e2-ec2d-4f32-bdaa-d36fa9ccc59d</onsuccess><processid>d03e35ba-31ad-4df5-87ee-3123242979a0</processid></stage><stage stageid="196e3524-4655-4c62-a3ff-881b984be0c0" name="Maintain All" type="MultipleCalculation"><loginhibit /><narrative></narrative><displayx>690</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><onsuccess>32d5da99-b3d0-47be-b432-046b5948e9cb</onsuccess><steps><calculation expression="&quot;&quot;" stage="G_IBC Control" /><calculation expression="&quot;&quot;" stage="G_Vision+ Control" /></steps></stage><stage stageid="ebbc5744-8502-4a24-8b6a-906916e16eb7" name="Queue Loaded" type="Data"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative>Whether the Queue was loaded</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue>False</initialvalue><private /><alwaysinit /></stage><stage stageid="ce9c9449-716b-4616-a135-39b559d6a74e" name="Variables" type="Block"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="e2751446-e34d-44dd-b90d-586583f37409" name="Stop requested?" type="Decision"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>165</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="IsStopRequested() OR [G_Item Count]&gt;= [S_Stop After Items] OR LocalTime()&gt;[S_Stop After Time]" /><ontrue>25450fb3-6fae-4c33-9c49-463c2562eebe</ontrue><onfalse>77b38afa-186c-4829-88c5-bc1167e6b593</onfalse></stage><stage stageid="25450fb3-6fae-4c33-9c49-463c2562eebe" name="Anchor18" type="Anchor"><subsheetid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>225</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>236f2b9b-cf39-4f63-8d3b-50c2d7735f07</onsuccess></stage><stage stageid="b4a207ca-029f-43ff-9fdb-2de46cb50f8c" name="10. Poll" type="SubSheet"><loginhibit /><narrative></narrative><displayx>210</displayx><displayy>0</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>3cd113e9-1a8c-4aba-aa32-a116b473f17d</onsuccess><processid>f70ac6a4-aa70-4e35-b6ed-e1ecbea5cf52</processid></stage><stage stageid="3cd113e9-1a8c-4aba-aa32-a116b473f17d" name="Stop requested?" type="Decision"><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>0</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="IsStopRequested() OR [G_Item Count]&gt;= [S_Stop After Items] OR LocalTime()&gt;[S_Stop After Time]" /><ontrue>9881247a-acde-44f2-a839-09923d428747</ontrue><onfalse>12144d88-6b75-48b1-bc67-850976994bee</onfalse></stage><stage stageid="5bb26e13-9206-4cf7-8ded-f162ec336391" name="Password" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative>System password</narrative><displayx>-195</displayx><displayy>45</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>password</datatype><initialvalueenc></initialvalueenc><private /><alwaysinit /></stage><stage stageid="e9ad5bfa-cfb8-49eb-80d7-1941dd8b863a" name="Username" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative>System username</narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="c17dcc6a-5de0-437d-bf32-3a4df91a9fdb" name="Expiry Date" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative>Credential expiry date</narrative><displayx>-195</displayx><displayy>105</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>date</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="7168d7b9-7897-4f79-9e2f-9e6ea1afe437" name="Status" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative>Credential status</narrative><displayx>-195</displayx><displayy>75</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="6b4b131e-9c1a-42c1-9186-6666748d13f9" name="Credential name" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative>Name of the credential in BP</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="a5aa0f49-c383-4314-bfd2-c385e746f116" name="I_Current Row" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative>Current row count</narrative><displayx>-195</displayx><displayy>-15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>1</initialvalue><private /><alwaysinit /></stage><stage stageid="4f107f9c-1d4a-4761-bd8a-53e04f329490" name="Note1" type="Note"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative>This page is as per the original build apart from the loop which has been added</narrative><displayx>465</displayx><displayy>-120</displayy><displaywidth>120</displaywidth><displayheight>90</displayheight><font family="Segoe UI" size="10" style="Regular" color="FF0000" /></stage><stage stageid="171cdf24-5326-49e0-90d0-f03da9598e5a" name="Variables" type="Block"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>-45</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="41a5151e-d271-47cf-a695-179021abd0b0" name="Retry Count" type="Data"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="e7c9b650-abe8-484d-abc6-60c6185240dd" name="Retry?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1155</displayx><displayy>60</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Retry Count]&lt;5" /><ontrue>90a440fa-449d-4210-be54-4a3ae04ad30a</ontrue><onfalse>225e276e-22c4-4a17-8632-437f5837c898</onfalse></stage><stage stageid="3fddba0f-5942-4c74-ac0e-cfdaf139e7bd" name="Retry?" type="Decision"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1155</displayx><displayy>435</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Retry Count]&lt;5" /><ontrue>d25f29ab-22a5-485e-80f3-d9e773e36342</ontrue><onfalse>ff4a5729-9a75-4bab-8140-a56143a69366</onfalse></stage><stage stageid="81da0f73-8a3b-4daf-9e84-9e92062d358e" name="Reset Retry" type="Calculation"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>75</displayx><displayy>240</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>d34252a2-f188-4fe3-8ee2-35581ec54354</onsuccess><calculation expression="0" stage="Retry Count" /></stage><stage stageid="ae6ec7a6-fb99-4d44-a6ad-d21e191e1889" name="Sleep (5)" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="5" /></inputs><onsuccess>f46455e3-5e92-4567-af91-d7cbd8b6a166</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="4adbadf9-57b8-4c87-ae2b-a55f4a355a04" name="Successful Updates" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>345</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="276032b7-0d3a-4b00-b733-5c987ccc5247" name="Failed Updates" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>375</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="3eccfc19-d56a-4bbe-9a87-a680be4a8ef3" name="Update Flag &amp; Count" type="MultipleCalculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-45</displayx><displayy>630</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>fb5f01d0-71ea-438f-a9d2-caeb276a816e</onsuccess><steps><calculation expression="True" stage="G_Loop Data.Update Status" /><calculation expression="[Successful Updates]+1" stage="Successful Updates" /><calculation expression="False" stage="Initialled Name" /></steps></stage><stage stageid="e0541ebd-b4df-44ef-bfc8-839340f354fa" name="Update Flag &amp; Count" type="MultipleCalculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>570</displayx><displayy>465</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>eceb225f-0c15-4ba4-874d-a58f53c3c45c</onsuccess><steps><calculation expression="False" stage="G_Loop Data.Update Status" /><calculation expression="[Failed Updates]+1" stage="Failed Updates" /><calculation expression="[Initialled Name]" stage="G_Loop Data.Initialled Name" /></steps></stage><stage stageid="a47fac8d-0274-4395-9eb7-d92d7bf83ac1" name="Number of ACH Found" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>435</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="df69e5ce-6f4c-4234-aa1f-70e2d44cc747" name="Number of Applicable ACH" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>465</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="70a1ca38-9886-462e-a266-c804a278adfc" name="Increment ACH Found" type="Calculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>405</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>f1f0a5ae-4dc0-47cf-b0c6-e451ff313ead</onsuccess><calculation expression="[Number of ACH Found]+1" stage="Number of ACH Found" /></stage><stage stageid="1957ae80-54a1-48d1-8b05-cee54eebce8a" name="Increment Applicable" type="Calculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>570</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>8c9412fb-6d4b-48de-8cda-5f97d13bd4d5</onsuccess><calculation expression="[Number of Applicable ACH]+1" stage="Number of Applicable ACH" /></stage><stage stageid="aafdbd93-85f0-4882-91b5-b98737f2fc52" name="Anchor21" type="Anchor"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-45</displayx><displayy>690</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>3eccfc19-d56a-4bbe-9a87-a680be4a8ef3</onsuccess></stage><stage stageid="71d7a79b-ec73-4611-9872-2bede6964e55" name="Set Start Time" type="Calculation"><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-150</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>5e1ced05-1fd4-4d58-b632-4539a10dcd0b</onsuccess><calculation expression="Now()" stage="Start Time" /></stage><stage stageid="f55c4842-663a-461b-8ee8-e5cce068c7ee" name="Start Time" type="Data"><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>120</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Bold" color="0000FF" /><datatype>datetime</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="b31bd38b-d064-4683-9ca9-5f556f1988bf" name="Set End Time" type="Calculation"><loginhibit /><narrative></narrative><displayx>690</displayx><displayy>-75</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>c1cdafc6-c376-4120-bf76-42f715c0b012</onsuccess><calculation expression="Now()" stage="End Time" /></stage><stage stageid="dfc6b45f-8b17-462f-9aba-aae5fb4d54a2" name="End Time" type="Data"><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>150</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Bold" color="0000FF" /><datatype>datetime</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="950af569-b4e1-4f85-bd34-07ca48e60e48" name="O_Initialled Name" type="Data"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>465</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue>False</initialvalue><private /><alwaysinit /></stage><stage stageid="62b0f3f9-1938-46ce-9231-8135c88f48fd" name="Output" type="Block"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-270</displayx><displayy>435</displayy><displaywidth>150</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="da1fd8d5-c06f-410d-88bc-df16ccfee03d" name="Initialled Name" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>495</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>flag</datatype><initialvalue>False</initialvalue><private /><alwaysinit /></stage><stage stageid="eceb225f-0c15-4ba4-874d-a58f53c3c45c" name="Anchor30" type="Anchor"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>570</displayx><displayy>525</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>69102b13-58fe-4431-bb35-70e42e7bd9c1</onsuccess></stage><stage stageid="c42cd064-d885-4b05-bfbf-971e3d3c547f" name="S_Throttle" type="Data"><loginhibit /><narrative>The process will pause after working this number of cases in order to control the stress to the production environments.</narrative><displayx>-195</displayx><displayy>285</displayy><displaywidth>150</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Bold" color="FF0000" /><datatype>number</datatype><initialvalue>50</initialvalue><exposure>Session</exposure><alwaysinit /></stage><stage stageid="c1fb4e8e-4d85-49ba-a621-6790d6e89a00" name="Pause?" type="Decision"><loginhibit /><narrative></narrative><displayx>465</displayx><displayy>60</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[S_Throttle]=[G_Item Count]" /><ontrue>fb2b0a91-6f49-45ad-888b-beb98f668130</ontrue><onfalse>12144d88-6b75-48b1-bc67-850976994bee</onfalse></stage><stage stageid="fb2b0a91-6f49-45ad-888b-beb98f668130" name="Wait" type="Action"><loginhibit /><narrative></narrative><displayx>465</displayx><displayy>135</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Tahoma" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="10" /></inputs><onsuccess>6a34f2c5-3cdc-4bea-831e-e43f9e221af7</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="6a34f2c5-3cdc-4bea-831e-e43f9e221af7" name="Increase Throttle Number" type="Calculation"><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>135</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>12144d88-6b75-48b1-bc67-850976994bee</onsuccess><calculation expression="[S_Throttle]+50" stage="S_Throttle" /></stage><stage stageid="95ebb4ab-3a35-43a4-be34-9f8d11c42ec1" name="6. Mark Item as Completed" type="SubSheet"><loginhibit /><narrative></narrative><displayx>345</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>080a8b47-b055-4474-a8b9-b9cb3c6ac073</onsuccess><processid>6f6fb598-b7c6-4705-976b-14191d9d2bab</processid></stage><stage stageid="1c010652-092e-412f-8175-e11c7ef7adab" name="End4" type="End"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>900</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="20bc4b2b-b84d-42e0-9dc6-e587761dd035" name="Loop Results" type="LoopStart"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>570</displayx><displayy>705</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>bd976210-2341-4aa1-a96e-05479b350677</onsuccess><groupid>a1a35525-96c6-421f-97f6-1e9a07ac3bfe</groupid><looptype>ForEach</looptype><loopdata>G_Loop Data</loopdata></stage><stage stageid="d6aed299-3ee1-4027-8737-3e738b848b41" name="Loop Results" type="LoopEnd"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>570</displayx><displayy>825</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>081ea4ad-abfd-4427-a3b5-42b34127658f</onsuccess><groupid>a1a35525-96c6-421f-97f6-1e9a07ac3bfe</groupid></stage><stage stageid="081ea4ad-abfd-4427-a3b5-42b34127658f" name="1 or more failed updates?" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>570</displayx><displayy>900</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len([Exception Message])&gt;0" /><ontrue>820dee1a-3c50-4feb-9737-d43a631dec32</ontrue><onfalse>1c010652-092e-412f-8175-e11c7ef7adab</onfalse></stage><stage stageid="820dee1a-3c50-4feb-9737-d43a631dec32" name="BE: Unable to update all records" type="Exception"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>705</displayx><displayy>900</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="Business Exception" detail="&quot;Exceptions have been found in 1 or more ACHs: &quot; &amp; NewLine() &amp; [Exception Message] &amp; NewLine() &amp; &quot;All other records not listed above have been updated.&quot;" /></stage><stage stageid="bd976210-2341-4aa1-a96e-05479b350677" name="Initialled Name?" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>570</displayx><displayy>765</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[G_Loop Data.Initialled Name]=True" /><ontrue>d620f5f9-f500-4ef0-81e0-5920fdccf155</ontrue><onfalse>d6aed299-3ee1-4027-8737-3e738b848b41</onfalse></stage><stage stageid="d620f5f9-f500-4ef0-81e0-5920fdccf155" name="Update Exception Message" type="Calculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>705</displayx><displayy>765</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>6d7a1d04-10a7-4764-a89d-c5f1dd82f43c</onsuccess><calculation expression="[Exception Message]&amp; NewLine() &amp; &quot;• 1 or more record with an initalled firstname found for the additional card holder &quot; &amp; [G_Loop Data.Client No]" stage="Exception Message" /></stage><stage stageid="6d7a1d04-10a7-4764-a89d-c5f1dd82f43c" name="Anchor36" type="Anchor"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>705</displayx><displayy>825</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>d6aed299-3ee1-4027-8737-3e738b848b41</onsuccess></stage><stage stageid="cc4c59a0-c9e7-469c-8090-a052d01544ab" name="Count Number of ACH's" type="Action"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>90</displayx><displayy>-120</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Collection Name" narrative="The name of the collection to act upon" expr="&quot;G_Loop Data&quot;" /></inputs><outputs><output type="number" name="Count" narrative="The number of rows counted in the collection" stage="ACH Count" /></outputs><onsuccess>4255ce2b-32eb-4766-be90-8b82f8ec4c86</onsuccess><resource object="Blueprism.AutomateProcessCore.clsCollectionActions" action="Count Rows" /></stage><stage stageid="4bf9b2bd-cd4d-4f50-8c59-54d60081d300" name="ACH Count" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>525</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="48f39e0e-c2e4-4c5a-b45b-1060eec1db9c" name="ACHs Updated" type="Data"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>555</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="69102b13-58fe-4431-bb35-70e42e7bd9c1" name="Update Success Count" type="Calculation"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>525</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>4e4606b6-8799-4681-905a-6989fd23a400</onsuccess><calculation expression="[ACHs Updated]+1" stage="ACHs Updated" /></stage><stage stageid="4e4606b6-8799-4681-905a-6989fd23a400" name="Set Custom Status" type="SubSheet"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>585</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Status Message" expr="&quot;03 - Updated ACH &quot; &amp; [ACHs Updated] &amp; &quot; of &quot; &amp; [ACH Count]" /></inputs><onsuccess>ec9a026d-ea79-4997-8054-980e3d45cdb1</onsuccess><processid>a69fe59a-cbfa-4ddb-b84f-175b62d7a2af</processid></stage><stage stageid="b8bcb046-9101-4686-af3a-59dec4ed1952" name="All updated?" type="Decision"><subsheetid>cac99af1-dcbf-48bd-b310-e90a5e99917d</subsheetid><loginhibit /><narrative></narrative><displayx>420</displayx><displayy>705</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[ACH Count]=[ACHs Updated]" /><ontrue>1c010652-092e-412f-8175-e11c7ef7adab</ontrue><onfalse>20bc4b2b-b84d-42e0-9dc6-e587761dd035</onfalse></stage><stage stageid="53f75a60-c299-4058-a752-7e57e8fbb26d" name="Anchor12" type="Anchor"><subsheetid>853c5533-4f26-4c01-976d-b19981861ac0</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>405</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>0a740bea-aab5-4774-8ad3-0227174d8346</onsuccess></stage><stage stageid="d25f29ab-22a5-485e-80f3-d9e773e36342" name="Increment Retry &amp; Set Restart" type="MultipleCalculation"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1155</displayx><displayy>330</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>83f92ca0-35fd-4be1-8829-1fd12954217a</onsuccess><steps><calculation expression="&quot;RESTART&quot;" stage="G_Vision+ Control" /><calculation expression="[Retry Count]+1" stage="Retry Count" /></steps></stage><stage stageid="90a440fa-449d-4210-be54-4a3ae04ad30a" name="Increment Retry &amp; Set Restart" type="MultipleCalculation"><subsheetid>db0a31d1-a3aa-489e-8e85-91f3deea50f6</subsheetid><loginhibit /><narrative></narrative><displayx>1155</displayx><displayy>-45</displayy><displaywidth>90</displaywidth><displayheight>60</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>2b31b5eb-2997-49f5-86d9-7e753dbd220c</onsuccess><steps><calculation expression="&quot;RESTART&quot;" stage="G_IBC Control" /><calculation expression="[Retry Count]+1" stage="Retry Count" /></steps></stage><stage stageid="f8e4b2b2-e4fb-4dc9-9bfc-8e06996ff4df" name="Navigate to Login" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>90</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="1" /><input type="number" name="y-Position" narrative="The start y position" expr="24" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;fdprodc&quot;" /></inputs><onsuccess>33bb048f-d09e-4767-b9bd-e684b20b19ab</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="33bb048f-d09e-4767-b9bd-e684b20b19ab" name="Send Keys: Enter" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>150</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>d0b5f0f1-d938-4a8a-8893-580e34c5afd5</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="87d6ef20-dd29-4552-bc22-6a272e9deba0" name="Write Text: 08019" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>360</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="25" /><input type="number" name="y-Position" narrative="The start y position" expr="6" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;08019&quot;" /></inputs><onsuccess>1d2fe131-bde1-4825-95cd-9a22c6d0cc0f</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="1084c719-77ab-4331-8bb3-f7717cc1bdca" name="Write Username" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>600</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="25" /><input type="number" name="y-Position" narrative="The start y position" expr="8" /><input type="text" name="Text to Write" narrative="The text to input" expr="[Username]" /></inputs><onsuccess>aeeccf5d-6d0b-41cc-b121-40f9225a816b</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="aeeccf5d-6d0b-41cc-b121-40f9225a816b" name="Write Password" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>660</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="25" /><input type="number" name="y-Position" narrative="The start y position" expr="10" /><input type="text" name="Text to Write" narrative="The text to input" expr="[Password]" /></inputs><onsuccess>cac36600-4c73-40cd-9f76-36c176c37312</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="cac36600-4c73-40cd-9f76-36c176c37312" name="Send Keys: Enter" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>720</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>a046f86e-9f73-49f2-b6c5-6f07b3f51e94</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="a046f86e-9f73-49f2-b6c5-6f07b3f51e94" name="Identify Page" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>780</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="2" /><input type="number" name="y-Position" narrative="The start y position" expr="1" /><input type="number" name="String Length" narrative="Length of the string to read" expr="4" /></inputs><outputs><output type="text" name="Read Text" stage="Screen Name" /></outputs><onsuccess>811ad0aa-f1e4-4f42-96db-c24f7ec84bb4</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="3c50de16-17b9-4676-a754-b82ec27d7851" name="Screen Name" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>165</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="f46455e3-5e92-4567-af91-d7cbd8b6a166" name="Anchor19" type="Anchor"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>30</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>f8e4b2b2-e4fb-4dc9-9bfc-8e06996ff4df</onsuccess></stage><stage stageid="fbb64977-8539-4ef1-aba2-9a02c386cff3" name="Block5" type="Block"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>-45</displayx><displayy>60</displayy><displaywidth>270</displaywidth><displayheight>330</displayheight><font family="Segoe UI" size="10" style="Regular" color="7FB2E5" /></stage><stage stageid="c0eca782-4627-4d81-bc32-c4964283cb72" name="Recover6" type="Recover"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>360</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>fa369a0a-9624-4008-960c-c03a4758a999</onsuccess></stage><stage stageid="fa369a0a-9624-4008-960c-c03a4758a999" name="Retry Launch?" type="Decision"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>300</displayx><displayy>360</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Retry Count] &lt; 3" /><ontrue>cd1494c7-13b1-4e19-bb0c-bf77a7280623</ontrue><onfalse>4649930b-c860-4f4d-80a7-b2e609800b1e</onfalse></stage><stage stageid="cd1494c7-13b1-4e19-bb0c-bf77a7280623" name="Resume6" type="Resume"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>435</displayx><displayy>360</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>cef81819-a356-4b28-925c-d55f49bf13b9</onsuccess></stage><stage stageid="163fe0db-bcf9-4fa3-8349-3c44decc43f2" name="Terminate" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>435</displayx><displayy>90</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>cb0a6003-ca37-4c8a-9cd0-91f20c76c079</onsuccess><resource object="COE - PCOMM - Vision Plus" action="Terminate" /></stage><stage stageid="cb0a6003-ca37-4c8a-9cd0-91f20c76c079" name="Sleep (3)" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>435</displayx><displayy>30</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="Sleep Time (Seconds)" narrative="The time (in seconds) for which to sleep" expr="3" /></inputs><onsuccess>d74f396a-73c5-4390-a221-7675eed78b3c</onsuccess><resource object="Utility - General" action="Sleep" /></stage><stage stageid="d74f396a-73c5-4390-a221-7675eed78b3c" name="Launch PCOMM" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>300</displayx><displayy>30</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Session File Path" narrative="The full path of the required session file" expr="&quot;C:\Program Files (x86)\IBM\Personal Communications\private\zSeries PCOM Session files\VisionPlus\Visionplus.ws&quot;" /></inputs><onsuccess>f46455e3-5e92-4567-af91-d7cbd8b6a166</onsuccess><resource object="COE - PCOMM - Vision Plus" action="Launch" /></stage><stage stageid="cef81819-a356-4b28-925c-d55f49bf13b9" name="Increment Retry Count" type="Calculation"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>435</displayx><displayy>150</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>163fe0db-bcf9-4fa3-8349-3c44decc43f2</onsuccess><calculation expression="[Retry Count] + 1" stage="Retry Count" /></stage><stage stageid="9735168d-7f9d-4b7f-a5da-54a2028c7395" name="Retry Count" type="Data"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>195</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>number</datatype><initialvalue>0</initialvalue><private /><alwaysinit /></stage><stage stageid="4649930b-c860-4f4d-80a7-b2e609800b1e" name="SE - Unable to Login" type="Exception"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>300</displayx><displayy>435</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="System Exception" detail="" usecurrent="yes" /></stage><stage stageid="5fb3a84c-0b2c-412b-ad10-425477398773" name="Write: AZXI" type="Action"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-75</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="9" /><input type="number" name="y-Position" narrative="The start y position" expr="1" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;AZXI&quot;" /></inputs><onsuccess>ba9aaf26-0e17-4f11-be09-01dce17e99f0</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="ba9aaf26-0e17-4f11-be09-01dce17e99f0" name="Send Keys: Enter" type="Action"><subsheetid>659dc01c-84fe-4f14-9e3a-eaf7b3f25ccd</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>7f60d293-5a83-4eca-9e7d-891641527904</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="933e4c88-562f-4125-922a-6ef82dafbdbc" name="Terminate Mainframe" type="Action"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>e141e03c-7fef-47d9-8f72-30701e0218e2</onsuccess><resource object="COE - PCOMM - Vision Plus" action="Terminate" /></stage><stage stageid="ca0487be-cb09-4de1-a719-65b49ca1a7b5" name="Kill pcsm process" type="Action"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>165</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Process Name" narrative="The name of the process to kill" expr="&quot;pcsm&quot;" /></inputs><onsuccess>eaedce9e-dc16-4730-8850-660452a14a45</onsuccess><resource object="Utility - Environment" action="Kill Process" /></stage><stage stageid="e141e03c-7fef-47d9-8f72-30701e0218e2" name="Kill PCOMM Process" type="Action"><subsheetid>d72f787b-00d1-4bd9-aa91-be39f5007ff9</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>105</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Process Name" narrative="The name of the process to kill" expr="&quot;pcsws&quot;" /></inputs><onsuccess>ca0487be-cb09-4de1-a719-65b49ca1a7b5</onsuccess><resource object="Utility - Environment" action="Kill Process" /></stage><stage stageid="2b776f05-18d3-4a0d-addb-9f7730c9af8a" name="Write: AZXI" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-135</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="9" /><input type="number" name="y-Position" narrative="The start y position" expr="1" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;AZXI&quot;" /></inputs><onsuccess>d80ef032-044f-4ccc-8f31-86f65c6c77f4</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="d80ef032-044f-4ccc-8f31-86f65c6c77f4" name="Send Keys: Enter" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-75</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>97badb9e-d15b-4273-a145-ef551b3d9506</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="f591a040-f978-4bf5-b83e-de835fe2008a" name="Write: Internal ID" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>105</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="40" /><input type="number" name="y-Position" narrative="The start y position" expr="8" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;00012000&quot;&amp;Right(Replace(Trim([G_Item Data.OCIS Master CID Persid]),&quot;+&quot;,&quot;0&quot;),11)" /></inputs><onsuccess>3536efb8-f670-40e8-93bb-aecc860788d2</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="3536efb8-f670-40e8-93bb-aecc860788d2" name="Send Keys: Enter" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>165</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>00ba3e4c-dea3-46a3-8edd-81484ec88238</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="00ba3e4c-dea3-46a3-8edd-81484ec88238" name="Read Screen" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="39" /><input type="number" name="y-Position" narrative="The start y position" expr="4" /><input type="number" name="String Length" narrative="Length of the string to read" expr="19" /></inputs><outputs><output type="text" name="Read Text" stage="Read Text" /></outputs><onsuccess>dd18741c-2150-4052-bd72-20a39acee9c1</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="342a4302-582a-4e38-bc39-f4cd0a3a9327" name="Read Text" type="Data"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>-195</displayx><displayy>15</displayy><displaywidth>120</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><datatype>text</datatype><initialvalue /><private /><alwaysinit /></stage><stage stageid="dd18741c-2150-4052-bd72-20a39acee9c1" name="Found Table?" type="Decision"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>285</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Read Text] = &quot;00012000&quot;&amp;Right(Replace(Trim([G_Item Data.OCIS Master CID Persid]),&quot;+&quot;,&quot;0&quot;),11)" /><ontrue>ac0aa981-1aa0-48cf-b938-8c3fba0822f4</ontrue><onfalse>7fa44906-1732-42db-8567-24961ef960fe</onfalse></stage><stage stageid="7fa44906-1732-42db-8567-24961ef960fe" name="BE - Customer not found in Vision+" type="Exception"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>285</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><exception type="Business Exception" detail="&quot;Customer not found in Vision+&quot;" /></stage><stage stageid="ac0aa981-1aa0-48cf-b938-8c3fba0822f4" name="Page--" type="Calculation"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>345</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>e6c8cb55-2859-4594-8ee1-e35c39a6d79f</onsuccess><calculation expression="[I_Page Increment] - 1" stage="I_Page Increment" /></stage><stage stageid="e12e66ee-e0e8-492c-9051-13fbca681784" name="End" type="End"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>465</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /></stage><stage stageid="e6c8cb55-2859-4594-8ee1-e35c39a6d79f" name="On Correct Page" type="Decision"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[I_Page Increment] &lt;= 0" /><ontrue>e12e66ee-e0e8-492c-9051-13fbca681784</ontrue><onfalse>c069d25d-e2cc-4edd-bd57-17b88e0092d2</onfalse></stage><stage stageid="c069d25d-e2cc-4edd-bd57-17b88e0092d2" name="Send Keys: F6" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[PF6]&quot;" /></inputs><onsuccess>a55e5016-1ab9-4c68-9272-10344440c3c1</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="a55e5016-1ab9-4c68-9272-10344440c3c1" name="Send Keys: Enter" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>135</displayx><displayy>345</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>ac0aa981-1aa0-48cf-b938-8c3fba0822f4</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="ea7bb54b-1451-4ab3-8129-b33969f5e770" name="Read Screen: Code Block" type="Action"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-60</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="52" /><input type="number" name="y-Position" narrative="The start y position" expr="[Y Value]+[I_Current Row]" /><input type="number" name="String Length" narrative="Length of the string to read" expr="1" /></inputs><outputs><output type="text" name="Read Text" stage="O_Block Code" /></outputs><onsuccess>a8f42e98-602e-49e7-8413-ac28f063e6c2</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="a8f42e98-602e-49e7-8413-ac28f063e6c2" name="Read Screen: Card Holder" type="Action"><subsheetid>e1f35caa-a327-4bcf-91a2-870bcd6851c8</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>0</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="78" /><input type="number" name="y-Position" narrative="The start y position" expr="[Y Value]+[I_Current Row]" /><input type="number" name="String Length" narrative="Length of the string to read" expr="1" /></inputs><outputs><output type="text" name="Read Text" stage="O_Card Holder Code" /></outputs><onsuccess>1c0de11e-f3a9-4804-84b2-7e5fe413faa9</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="ab1016e1-0f19-429d-92f5-a016df2f48aa" name="Write E" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-375</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="7" /><input type="number" name="y-Position" narrative="The start y position" expr="6 + [I_Current Row]" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;E&quot;" /></inputs><onsuccess>db0f0928-3746-4857-a232-ae65b73fdfad</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="db0f0928-3746-4857-a232-ae65b73fdfad" name="Send Keys: Enter" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-315</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>181a1a09-a926-4140-b626-9ba7fdc9fac2</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="92c5d86f-eace-476e-8183-27b4f7d57a7d" name="Read Screen: Last Name" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-75</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="20" /><input type="number" name="y-Position" narrative="The start y position" expr="5" /><input type="number" name="String Length" narrative="Length of the string to read" expr="21" /></inputs><outputs><output type="text" name="Read Text" stage="Last Name" /></outputs><onsuccess>f78c0cfa-7faa-4b2d-ada0-4da451d98231</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="0921e4e5-c3d5-47ff-91d8-209cc4b54f42" name="Name Matches?" type="Decision"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>570</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Upper(Trim([First Name])) = Upper(Trim([G_Loop Data.First Name])) AND Upper(Trim([Last Name])) = Upper(Trim([G_Loop Data.Surname]))" /><ontrue>efca0e61-a75f-4c9d-8a35-a88b8af7443f</ontrue><onfalse>c708626c-c918-4c2b-b837-b252718dedd4</onfalse></stage><stage stageid="5e74cba3-197e-4521-a1df-18c340ae810d" name="DOB Matches" type="Decision"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>690</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Trim([Date Of Birth]) = Trim([G_Loop Data.DOB]) AND Len(Trim([First Name])) &gt; 1" /><ontrue>3c606f6a-2a49-40cd-862f-30b9826455c3</ontrue><onfalse>51ea5acf-f81b-4824-88b4-e3adbc76ca42</onfalse></stage><stage stageid="efca0e61-a75f-4c9d-8a35-a88b8af7443f" name="Anchor4" type="Anchor"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>570</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>3c606f6a-2a49-40cd-862f-30b9826455c3</onsuccess></stage><stage stageid="0d8c765a-aca3-48f5-a681-ad2c9c773616" name="Applicable = True" type="Calculation"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>750</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>51ea5acf-f81b-4824-88b4-e3adbc76ca42</onsuccess><calculation expression="True" stage="O_ACH Applicable" /></stage><stage stageid="51ea5acf-f81b-4824-88b4-e3adbc76ca42" name="End5" type="End"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>750</displayy><displaywidth>60</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><outputs><output type="flag" name="ACH Applicable" stage="O_ACH Applicable" /><output type="text" name="Fax Phone" stage="O_Fax Phone" /><output type="text" name="Home Phone" stage="O_Home Phone" /><output type="text" name="Mobile Phone" stage="O_Mobile Phone" /><output type="flag" name="Name Initialled?" stage="O_Initialled Name" /></outputs></stage><stage stageid="c7354f9a-04f1-49da-9867-804edbda3f97" name="Reformat DOB" type="Calculation"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>465</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>2c140bc3-640d-42c3-baf9-1d827b2d0e39</onsuccess><calculation expression="Left([Date Of Birth], 2)&amp;&quot;/&quot;&amp;Mid([Date Of Birth], 3, 2)&amp;&quot;/&quot;&amp;Right([Date Of Birth], 4)" stage="Date Of Birth" /></stage><stage stageid="352f10c3-5e31-49bf-b2b4-4f717ad895d3" name="DOB Retireved?" type="Decision"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len([Date Of Birth])&gt;0" /><ontrue>c7354f9a-04f1-49da-9867-804edbda3f97</ontrue><onfalse>2c4f77d2-4001-41e0-9f93-371ba93daa81</onfalse></stage><stage stageid="2c140bc3-640d-42c3-baf9-1d827b2d0e39" name="Anchor23" type="Anchor"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>525</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>0921e4e5-c3d5-47ff-91d8-209cc4b54f42</onsuccess></stage><stage stageid="2c4f77d2-4001-41e0-9f93-371ba93daa81" name="Anchor25" type="Anchor"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>405</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>9a82998a-112c-4354-9dd1-050893fdaf38</onsuccess></stage><stage stageid="9a82998a-112c-4354-9dd1-050893fdaf38" name="Anchor26" type="Anchor"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>180</displayx><displayy>525</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>2c140bc3-640d-42c3-baf9-1d827b2d0e39</onsuccess></stage><stage stageid="19563be9-7ad0-4da3-b8b9-e96548a9fc4a" name="Anchor34" type="Anchor"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-90</displayx><displayy>750</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>51ea5acf-f81b-4824-88b4-e3adbc76ca42</onsuccess></stage><stage stageid="c708626c-c918-4c2b-b837-b252718dedd4" name="Initialled firstname?" type="Decision"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>630</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="Len(Trim([First Name]))&lt;2&#xA;OR&#xA;Len(Trim([G_Loop Data.First Name]))&lt;2" /><ontrue>0e07e33b-b1a0-43f4-80b1-168c73049a48</ontrue><onfalse>5e74cba3-197e-4521-a1df-18c340ae810d</onfalse></stage><stage stageid="0e07e33b-b1a0-43f4-80b1-168c73049a48" name="Anchor31" type="Anchor"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-90</displayx><displayy>630</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>0c02a61e-b3a9-4cd2-be5f-f48aadf38d9d</onsuccess></stage><stage stageid="0c02a61e-b3a9-4cd2-be5f-f48aadf38d9d" name="Set Initialled Flag" type="Calculation"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>-90</displayx><displayy>690</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>19563be9-7ad0-4da3-b8b9-e96548a9fc4a</onsuccess><calculation expression="True" stage="O_Initialled Name" /></stage><stage stageid="fbad786f-3ebb-4a69-9221-672360cd66da" name="Write: ARQN" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-195</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="9" /><input type="number" name="y-Position" narrative="The start y position" expr="1" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;ARQN&quot;" /></inputs><onsuccess>7f18e5c3-a4df-43ff-aa0e-19760d5d44ef</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="7f18e5c3-a4df-43ff-aa0e-19760d5d44ef" name="Send Keys: Enter" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-135</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>92c5d86f-eace-476e-8183-27b4f7d57a7d</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="f78c0cfa-7faa-4b2d-ada0-4da451d98231" name="Read Screen: First Name" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="20" /><input type="number" name="y-Position" narrative="The start y position" expr="6" /><input type="number" name="String Length" narrative="Length of the string to read" expr="21" /></inputs><outputs><output type="text" name="Read Text" stage="First Name" /></outputs><onsuccess>cacfb464-728f-4484-bd26-3df0fd696651</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="cacfb464-728f-4484-bd26-3df0fd696651" name="Send Keys: Enter" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>af1c9579-616a-42b7-aa4f-7315023f1f75</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="6197e93f-dcf9-4800-9538-4b2e51502aa3" name="Read Screen: DOB" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>345</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="33" /><input type="number" name="y-Position" narrative="The start y position" expr="5" /><input type="number" name="String Length" narrative="Length of the string to read" expr="8" /></inputs><outputs><output type="text" name="Read Text" stage="Date Of Birth" /></outputs><onsuccess>352f10c3-5e31-49bf-b2b4-4f717ad895d3</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="4eeeb877-712d-484e-ae87-8d1a64e267d2" name="Write ARMN" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-135</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="9" /><input type="number" name="y-Position" narrative="The start y position" expr="1" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;ARMN&quot;" /></inputs><onsuccess>457745f0-53d2-4302-8fd6-bd7f4e3fd3e6</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="7a0b62ef-9a1d-4e81-bbbc-7c5307b6d784" name="Send Keys: Enter" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>725aa106-1eec-4559-a929-a9efa4a30e9b</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="f7d4d515-8118-4699-907c-c3d23c60114a" name="Write Home Phone Indicator" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>105</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="42" /><input type="number" name="y-Position" narrative="The start y position" expr="19" /><input type="text" name="Text to Write" narrative="The text to input" expr="[Home Phone Indicator]" /></inputs><onsuccess>20e5131b-4d90-422c-87e8-8b21817cb7e8</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="bf5b3415-7c45-4d9d-92b2-b78337f7f895" name="Write Home Phone" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>105</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="17" /><input type="number" name="y-Position" narrative="The start y position" expr="19" /><input type="text" name="Text to Write" narrative="The text to input" expr="Trim([I_Home Phone])" /></inputs><onsuccess>f7d4d515-8118-4699-907c-c3d23c60114a</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="fbd0b4bf-6b7d-4bdb-aff8-ec15fdc84074" name="Write Fax Phone Indicator" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="42" /><input type="number" name="y-Position" narrative="The start y position" expr="20" /><input type="text" name="Text to Write" narrative="The text to input" expr="[Fax Phone Indicator]" /></inputs><onsuccess>e9dd9a3f-e648-403c-b491-528af7a18601</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="46263dce-3710-4525-8872-87895887ecd0" name="Write Fax Phone" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>165</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="17" /><input type="number" name="y-Position" narrative="The start y position" expr="20" /><input type="text" name="Text to Write" narrative="The text to input" expr="Trim([I_Fax Phone])" /></inputs><onsuccess>fbd0b4bf-6b7d-4bdb-aff8-ec15fdc84074</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="e9dd9a3f-e648-403c-b491-528af7a18601" name="Write Mobile Phone" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>285</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="17" /><input type="number" name="y-Position" narrative="The start y position" expr="21" /><input type="text" name="Text to Write" narrative="The text to input" expr="Trim([G_Loop Data.Mobile Number])" /></inputs><onsuccess>5671c8ab-ade2-4e4d-9270-1aaf76e8a9c7</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="5671c8ab-ade2-4e4d-9270-1aaf76e8a9c7" name="Write Mobile Phone Indicator" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>345</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="42" /><input type="number" name="y-Position" narrative="The start y position" expr="21" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;1&quot;" /></inputs><onsuccess>e6f924b9-d14d-4182-adb7-d58f6ffb7f63</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="e6f924b9-d14d-4182-adb7-d58f6ffb7f63" name="Send Keys: Enter" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>405</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>f3ec55a9-4f6b-4b44-91c9-07a9d509f098</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="30e761c7-af18-4364-877a-885ca3fd7581" name="Read Next Page" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>525</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="2" /><input type="number" name="y-Position" narrative="The start y position" expr="5" /><input type="number" name="String Length" narrative="Length of the string to read" expr="12" /></inputs><outputs><output type="text" name="Read Text" stage="Check String" /></outputs><onsuccess>e3fc75e4-1802-4b31-b0d0-53a07a62af2a</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="97badb9e-d15b-4273-a145-ef551b3d9506" name="Clear Card Number" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>-15</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="40" /><input type="number" name="y-Position" narrative="The start y position" expr="5" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;                   &quot;" /></inputs><onsuccess>e373116c-1da1-4df2-ac67-bf7e0dba3cc3</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="e373116c-1da1-4df2-ac67-bf7e0dba3cc3" name="Clear Customer Number" type="Action"><subsheetid>6dec6d5b-3df6-47fd-84d8-9b7daa67c1ce</subsheetid><loginhibit /><narrative></narrative><displayx>0</displayx><displayy>45</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="40" /><input type="number" name="y-Position" narrative="The start y position" expr="7" /><input type="text" name="Text to Write" narrative="The text to input" expr="&quot;                   &quot;" /></inputs><onsuccess>f591a040-f978-4bf5-b83e-de835fe2008a</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Write Text to Screen" /></stage><stage stageid="181a1a09-a926-4140-b626-9ba7fdc9fac2" name="Send Keys: Enter" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>-255</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>fbad786f-3ebb-4a69-9221-672360cd66da</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="dd53befe-130a-46b2-a39c-1911b8d734bc" name="Send Keys: Enter" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>285</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>6197e93f-dcf9-4800-9538-4b2e51502aa3</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="af1c9579-616a-42b7-aa4f-7315023f1f75" name="Read Screen: Home Phone" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>105</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="17" /><input type="number" name="y-Position" narrative="The start y position" expr="19" /><input type="number" name="String Length" narrative="Length of the string to read" expr="11" /></inputs><outputs><output type="text" name="Read Text" stage="O_Home Phone" /></outputs><onsuccess>6bae6d70-ffea-4e16-ba32-87cd0cbe8fb2</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="6bae6d70-ffea-4e16-ba32-87cd0cbe8fb2" name="Read Screen: Fax" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>165</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="17" /><input type="number" name="y-Position" narrative="The start y position" expr="20" /><input type="number" name="String Length" narrative="Length of the string to read" expr="11" /></inputs><outputs><output type="text" name="Read Text" stage="O_Fax Phone" /></outputs><onsuccess>3b198a1c-d517-406f-bd75-6910dd908520</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="3b198a1c-d517-406f-bd75-6910dd908520" name="Read Screen: Mobile Phone" type="Action"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><loginhibit /><narrative></narrative><displayx>30</displayx><displayy>225</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="17" /><input type="number" name="y-Position" narrative="The start y position" expr="21" /><input type="number" name="String Length" narrative="Length of the string to read" expr="11" /></inputs><outputs><output type="text" name="Read Text" stage="O_Mobile Phone" /></outputs><onsuccess>dd53befe-130a-46b2-a39c-1911b8d734bc</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="d0b5f0f1-d938-4a8a-8893-580e34c5afd5" name="Identify Page" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>210</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="number" name="x-Position" narrative="The start x position" expr="2" /><input type="number" name="y-Position" narrative="The start y position" expr="1" /><input type="number" name="String Length" narrative="Length of the string to read" expr="4" /></inputs><outputs><output type="text" name="Read Text" stage="Screen Name" /></outputs><onsuccess>3ad48bfa-9056-49eb-8d7a-e05665e4c2b8</onsuccess><resource object="COE - PCOMM - Vision Plus" action="R: Read Screen Text - Single Line" /></stage><stage stageid="3ad48bfa-9056-49eb-8d7a-e05665e4c2b8" name="On WSSN" type="Decision"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>270</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><decision expression="[Screen Name] = &quot;WSSN&quot;" /><ontrue>48290e75-300b-4a03-8ad4-44d032444582</ontrue><onfalse>6c21fb78-4dd5-441f-a750-fe683c270b32</onfalse></stage><stage stageid="48290e75-300b-4a03-8ad4-44d032444582" name="Anchor13" type="Anchor"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><narrative></narrative><displayx>15</displayx><displayy>315</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>87d6ef20-dd29-4552-bc22-6a272e9deba0</onsuccess></stage><stage stageid="6c21fb78-4dd5-441f-a750-fe683c270b32" name="Send Keys: Enter" type="Action"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><loginhibit /><narrative></narrative><displayx>150</displayx><displayy>270</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>fbcac4a2-d4df-4ae5-bd9a-d2cf53ad1e22</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="fbcac4a2-d4df-4ae5-bd9a-d2cf53ad1e22" name="Anchor32" type="Anchor"><subsheetid>31bf5df4-1d9d-49f4-92f4-b96e2e524f1d</subsheetid><narrative></narrative><displayx>150</displayx><displayy>315</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>48290e75-300b-4a03-8ad4-44d032444582</onsuccess></stage><stage stageid="457745f0-53d2-4302-8fd6-bd7f4e3fd3e6" name="Send Keys: Enter" type="Action"><subsheetid>1d426e5a-59d5-46c1-aac7-6f4eb8f1bb91</subsheetid><loginhibit /><narrative></narrative><displayx>15</displayx><displayy>-75</displayy><displaywidth>90</displaywidth><displayheight>30</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><inputs><input type="text" name="Send Keys Value" narrative="The Send Keys value" expr="&quot;[ENTER]&quot;" /></inputs><onsuccess>7a0b62ef-9a1d-4e81-bbbc-7c5307b6d784</onsuccess><resource object="COE - PCOMM - Vision Plus" action="I: Send Keys to Application" /></stage><stage stageid="3c606f6a-2a49-40cd-862f-30b9826455c3" name="Anchor37" type="Anchor"><subsheetid>c9ccc708-a0df-4309-8e81-393f66cf5314</subsheetid><narrative></narrative><displayx>180</displayx><displayy>690</displayy><displaywidth>10</displaywidth><displayheight>10</displayheight><font family="Segoe UI" size="10" style="Regular" color="000000" /><onsuccess>0d8c765a-aca3-48f5-a681-ad2c9c773616</onsuccess></stage></process>​
