Hi Tejaskumar,
Technically it is possible if you know the document ID, but it would not necessarily be recommended as there's a risk that other processed documents may not be retrieved.
It is better to get them in the order given and if you wish to continue their processing in a different order, add each of the documents data to a queue item first.
Note - The action to get the next verified batch is with RabbitMQ, but the action to get the document data is with Decipher.
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
