custom dates in exporting queue using automateC
sarathnair
I am currently developing a monthly reporting process utilizing the AutomateC functionality. I am seeking advice on whether it is possible to specify custom date ranges for the reports. At present, I am using the "Last 31 Days" filter, which requires the process to be executed on the first day of each month to be effective. I would appreciate any guidance on how to incorporate custom dates into the process.
Additionally, I am interested in knowing if there is a way to export the report to a pre-existing template stored in a specific folder and subsequently rename the file as needed.
Here is the syntax I am currently using:
" /exportqueue " & """" &[Exports] & [Queue.Queue Name] & "_Export.csv" & """" &" /queuename " & """" & [Queue.Queue Name] & """" & " /sso "  &  " /queuefilter " & """" & [Filter] & """"
If anyone is aware of alternative methods or functionalities beyond AutomateC for exporting reports, I would be grateful for your insights.
Thank you in advance for your assistance.
Sarath
Hi @sarathnair
Have you tried "Get Report Data" option under Work Queues VBO?
Best Regards,
Sayeed Bin Abdullah
Hi @SayeedBinAbdullah,
Thanks for the response.
I am currently using "Get Report dat" Option, but the number of queue report to be exported is high and this is taking more time. So i am trying to find alternative that is quicker. Using automate c Functionality the queue report can be exported within 1 or 2 seconds. So i am looking for a solution if any, to add custom dates to that code.
Sarath
