open workbook command not working
03-01-22 05:38 AM
Getting error while using Open workbook VBO command. It says "Unable to execute code stage"
Aswin Jagannathan
Aswin Jagannathan
12 REPLIES 12
03-01-22 10:29 AM
Hello Ashwin,
if it working for file stored in locally and not for shared drive then it may be access issue.
Are you able to open that file manually from shared path?
and the error message which you have post is the full one or there are few more line with that message?
Neeraj Kumar
Software Engineer
Neeraj Kumar
Software Engineer
03-01-22 10:33 AM
I dont think its an access issue.Given full control to that file.
Aswin Jagannathan
Aswin Jagannathan
04-01-22 09:32 AM
please check the culture setting of your VBO,
you can refer this link for updating the vbo global code http://portal.blueprism.com/customer-support/support-center#/path/1301681772
Jerin Jose
Technical Product Owner
EY
*"If you find this post helpful mark it as best answer, .*
Jerin Jose
EY
- « Previous
- 1
- 2
- Next »
