Status: New
Hi All,
In Blue Prism System Tab -> System -> Settings, if we do any modifications currently there isn't any 'Apply' button, as all the changes are automatically implemented. If any modifications are done un-intentionally its hard to undo as the resources hardly use this page (unlike the daily usage of other (Environmental Variables or Queues).
We had an incident in this page that one of our support resources has been scrolling the mouse wheel and the options in 'Tesseract Engine' were modified and resource isn't aware that they are modified unless they are found during auditing.
Hence, with the availability of 'Apply' button those changes to get implemented unless 'Apply' button is clicked.
Thank you!
Srinivas
1 Comment
Hi @VanamalaSrinivas ,
Agree with you. But we need to restrict the access for the settings in higher environment(Production) to avoid the changes until to implement the Apply Button.
Basically only admin should access the Production environment apart from lower instances like DEV & UAT. Hope this will helps...😊
