RaviBhalia
Status: New
​Hi Team,
I am looking to automate Peer Review process for our team and one of the thing which comes to my mind is to do it through Blue prism DB or XML files of Processes and object.
IN every review we try and find below points :
Validation error count
Unused pages
Data Item
I would be like we will run this BP automation and above will be done without involving other team member to review it.
Above are the few elements which I highlighted there are more things we will e doing in peer review and exploring it as well.
is there any way we can get the above information through DB
4 Comments
HarshitRawat
Level 8
I beleive it would be difficult to do it from DB . More easier option would be to parse the release file XML and validate any criteria you want. I created a process which validates many things based on the release xml like stage logging enabled/disbaled/ Naming convention for Pages/Objects, Naming convention for scheudules/Release etc
MarkRothfield
Sign up for a free trial of Reveal RoboReview https://revealgroup.com/robosuite/roboreview/
PvD_SE
Level 12
The proposed XML option would do what you want.
ManojKumar3
How do we achieve that via process??
or any other Specify way to achieve this
