AlanPalin
Status: Not Planned
Clients need the ability to print Comms letter output to different letter trays, so that headed, plain and continuation paper can be used.
UK BPO have been testing with the following product versions:
- AWD version 21.2
- AWDCommunicationsWordAdd-In version 2.5.1
- DocumentRenderer version 2.3
For EnCorr, they used MediaColor (Microsoft Word) to identify the type of paper for printing.
• If the MediaColor = blue, the document will print on plain paper
• If the MediaColor = white, the document will print on headed paper
• If the MediaColor = pink, the document will print on continuation paper
To see the MediaColor, we need to open Word > File > Options > Advanced > tick at 'Show field codes instead of their values'. (Please see attachment)
Issue:
For Communication - After we created the document on Communication, we sent the Document to print by accessing AWD portal > Manage > Data > Document Delivery
We found that the documents are printed on incorrect paper because the document are sent in .pdf format.
We understood that the documents created in communications are created as .pdf files. Printer only print the output of the document from Communication, therefore, it is in PDF format.
To summarise, the MediaColor doesn't work on PDF format. Without MediaColor (or some other solution), the letter can't print on the correct paper.
3 Comments
ustevens
MFS also requested this under Customer Care ticket CS0001600
Status changed to: Not Planned
ustevens
Per PM @Karen_Hunter, at this time, the 3rd party technology used cannot support the embedded commands when delivering the file to the printer.
Otto_Mation
Digital Worker
This idea has been updated by the SS&C Blue Prism Product Management Team
