- Mark as Read
- Printer Friendly Page
The Control Room calendar currently does not function for 'working days' outside of the first and last. Financial Services would benefit greatly from an enhancement to provide working days options to these calendars.
You can set up a calendar to exclude all dates, aside from the working day you want (once you have worked out what date the working day is of each month). However, there is a huge amount of maintenance with this and therefore greater risk of error. You can also only select one date at a time (multi-select options would be good here).
I currently have a process to calculate the working day appended to the start of each of my processes; so the workers spend needless amounts of time and effort logging in and checking the working day, only to log out again with no action being taken as many processes work on just a few different working days per month.
So in summary - the idea is to have a working days option factored into the Control Room calendar and allow multi-select options for the selected dates.
