Sheela
Status: New
As BP 7.2 is moved to 64bit, could you please move Java version on Data Gateway(logstash) to 64bit Java.
Currently there is no option to choose latest version on Data Gateways.
So please make configuration more robust for updating the version on Java. This will allow to refer any latest version of Java(64 bit).
6 Comments
shekhar2023
Data-gateway should have periodic upgrade (one in a quarter) for latest java/log4j , because as the time passes and new vulnerabilities are discovered , compliant versions also need to be upgraded.
Much needed one..
jay_rawat
The configuration must be consistent and robots with the version upgrade. Many compliance issue get occur due to this.
Sathish.Rangan
Absolutely, I agree with this point
rich.cornish
Regulated Financial entities require BP components to tally with latest releases.
Could java please be upgraded as we are unable to perform certain functionalities due to compliance issues
